Respected Sir,
I am a beginner in the Field of aero-servo-hrdro-elastic simulation. I have encountered an error while simulating results using FAST platform. Please do help me to sort this out.
I have attached a file showing error on wind array boundaries. I have tried different combination of grid height and grid width. But I am receiving the same error.
Dear Rony,
An array regarding "wind array boundaries violated has been discussed many times on this forum. Please use “Search…” in the upper-right corner to see how others have solved this issue.
You haven’t stated what floating offshore wind turbine model you are using–if you are using a model NREL has provided or if you have made your own. Does it make sense for an aerodynamic analysis node of this turbine to be above 170 m above mean sea level?
