Hi
I am new to this forum. I run FAST8 considering monopile configuration with stochastic wind speed of 18mps generated from TurbSim. Simulation is getting terminated normally but while running, there is some blank space appearing in the command window. I am not able to understand the reason. Please help me.
I have attached the copy of command window.
Running FAST (v8.16.00a-bjj, 27-Jul-2016), compiled as a 64-bit application using single precision linked with NWTC Subroutine Library (v2.09.00, 23-Jul-2016)
Heading of the FAST input file:
FAST Certification Test #19: NREL 5.0 MW Baseline Wind Turbine with OC3 Monopile RF
Configuration, for use in offshore analysis
Running ElastoDyn (v1.04.00a-bjj, 26-Jul-2016).
Running AeroDyn14 (v14.05.01a-bjj, 25-Jul-2016).
Running InflowWind (v3.03.00, 26-Jul-2016).
Opening InflowWind input file: .\NRELOffshrBsline5MW_InflowWind.dat
Reading a 21x21 grid (170 m wide, 5 m to 175 m above ground) with a characteristic wind speed of 18 m/s. This full-field file was generated by TurbSim (v1.06.00, 21-Sep-2012) on 04-Jan-2017 at 08:45:55.
Processed 66945 time steps of 100-Hz full-field data (669.44 seconds).
Running ServoDyn (v1.06.00a-bjj, 26-Jul-2016).
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows, 14-Oct-2015).
Running HydroDyn (v2.05.01, 27-Jul-2016).
Calculating second order difference frequency wave kinematics.
Calculating second order sum frequency wave kinematics.
Running SubDyn (v1.03.00, 11-Apr-2016).
Calculating Internal Modal Eigenvectors
Timestep: 0 of 60 seconds.
Jonkman of NREL/NWTC for use in the IEA Annex XXIII OC3 studies.
Total Real Time: 3.7195 minutes
Total CPU Time: 3.7032 minutes
Simulation CPU Time: 0.53612 minutes
Simulated Time: 1 minutes
Time Ratio (Sim/CPU): 1.8652
FAST terminated normally.
thanks
Shilpa
