Dear Younes,
Nice video
From the plots, it looks like the turbine and/or controller of T2 are not reacting as expected when the wake from T1 hits T2. The error you are receiving seems to be triggered by the large (and negative) generator speed.
I gather you are using the OpenFAST model of NREL 5-MW baseline turbine. Did you change the controller DLL or OpenFAST models in any way (other than, say, file names/paths and initial conditions)?
The figure heading says Test #26; are you modeling the blades with BeamDyn? If so, does switching from BeamDyn to ElastoDyn solve the problem?
Thank you a lot, you spotted the issues!
For the DLL controller, I was using the same DLL file for both turbines, which created an interference between their control behaviors. Each turbine WT{i} must have its own ServoDyn_WT{i} and DLL_WT{i} files.
For the blade modeling, I switched from BeamDyn to ElastoDyn and it worked.
Thank you again for the help!
Kindest regards
Younes
Have the FAST.Farm Userâs Guide and Theory Manuel be published ? Or could you send me the newest version about it ?
Jiaping.Cui
I could not find the âSuper Controllerâ file(s) in the Fast.Farm folder downloaded from git (github.com/jjonkman/OpenFAST/tree/f/fast-farm). How can I have it? Is it the right location to have the latest version of Fast.Farm?
In addition, Is there any document/tutorial to show how to compile (with Linux) and use âSuper Controllerâ?
Hamid
Dear Jiaping,
Yes, the FAST.Farm Userâs Guide and Theory Manuel has now been finalized and published. Here: nrel.gov/docs/fy21osti/78485.pdf.
Dear Hamid,
The FAST.Farm source code now fully supports the functional super controller. And the super controller interface is documented in the FAST.Farm Userâs Guide and Theory Manual. A template of the super controller source code (SC_DLL.f90) is located in the modules\supercontroller\src directory of the repository. And a template of the source code at the turbine level (DISCON_SC.f90) is located in the reg_tests\r-test\glue-codes\fast-farm\5MW_Baseline\ServoData\DISCON directory of the repository. Moreover, my post dated Mar 18, 2021 above attaches a simple implementation example that should further clarify how it works.
My branch of FAST.Farm that you linked to is the source of the active pull request of FAST.Farm into OpenFAST: github.com/OpenFAST/openfast/pull/584. This should be merged into the dev branch of OpenFAST very soon (hopefully today).
In page 61 of the user FAST.Farm manual, it is stated three methods in defining the weighting factors to compute the spatial average of the disturbed wind velocity across a wake plane (equation 6.34 and 6.35). I am wondering if the wake plane at OutDist=0m will give the spatial average wind velocity on the wind turbine rotor, and if one of the weighting three methods can be selected somehow in the FAST.Farm input files.
Kindest regards
Younes
Dear Younes,
Iâm not sure what you mean when you ask, âI am wondering if the wake plane at OutDist=0m will give the spatial average wind velocity on the wind turbine rotor?â; please clarify.
Regarding the three spatial averaging methods, the three options can be selected via FAST.Farm input Mod_Meander, which DEFAULTs to Mod_Meander = 3 (windowed jinc).
Are there sample input files for FAST.Farm v2?
If so, can you share them with me?
Thanks in advance,
Eduardo
Dear Eduardo,
By FAST.Farm v2, I assume you mean the version of FAST.Farm that was recently merged into the dev branch of OpenFAST: github.com/OpenFAST/r-test/tree ⌠/fast-farm.
Iâve used the files you mentioned but I get this when I try to run FAST.Farm with them
FAST.Farm
Copyright (C) 2017 National Renewable Energy Laboratory
Copyright (C) 2017 Envision Energy USA LTD
FAST.Farm-v2.1.0-153-g559532b4
Compile Info:
- Architecture: 64 bit
- Precision: single
- Date: Aug 05 2019
- Time: 12:47:42
Execution Info:
- Date: 04/28/2021
- Time: 14:55:36+0200
Heading of the FAST.Farm input file:
Sample FAST.Farm input file
Running AWAE.
Running InflowWind.
Farm_Initialize:Farm_ValidateInput:OutFmt produces a column width of 10 instead of 14 characters.
Farm_Initialize:For efficiency, NumPlanes has been reduced to the number of time steps (134).
Farm_Initialize:AWAE_Init:InflowWind_Init:InflowWind_ReadInput:Invalid numerical input for file
"Downloads\TSinflow\InflowWind.dat" occurred while trying to read HWindSpeed.
Aborting FAST.Farm.
Iâve enabled the ECHO flag in both the .fstf file and the InflowWind.dat file.
For the .fstf the echo seems to be OK, but for the inflow I get
T Echo - Echo the input file data
3 WindType - switch for wind file type (1=steady; 2=uniform; 3=binary TurbSim FF; 4=binary Bladed-style FF; 5=HAWC format; 6=User defined)
0.0000E+00 PropagationDir - Direction of wind propagation (meteoroligical direction)
0 NWindVel - Number of points to output the wind velocity (0 to 9)
WindVxiList - List of coordinates in the inertial X direction (m)
WindVyiList - List of coordinates in the inertial Y direction (m)
WindVziList - List of coordinates in the inertial Z direction (m)
Which is weird because NWindVel should be 1, not 0
Do you have any idea of what might be the cause of this problem and how to fix it?
Thanks in advance,
Eduardo
Dear Eduardo,
The version of FAST.Farm you are running is older than the input files you are using. The input files in the r-test I linked to are compatible with the newest version of OpenFAST and FAST.Farm in the dev branch of OpenFAST. Youâll need to recompile FAST.Farm using the source code files from this dev branch to use the corresponding r-test input files.
Dear Jason:
I met some problems when i try to do simulation using â5MW_OC3Spar_DLL_WTurb_WavesIrr.fstâ which download from the r-test, the error information is :
[code] Heading of the FAST.Farm input file:
FAST Certification Test #24: NREL 5.0 MW Baseline Wind Turbine with OC3 Hywind Configuration,
for use in offshore analysis
Farm_Initialize:Farm_ReadPrimaryFile:Invalid logical input for file
â.\5MW_OC3Spar_DLL_WTurb_WavesIrr.fstâ occurred while trying to read UseSC.
Aborting FAST.Farm.
[/code]
I donât know how to find and define the âUseSCâ, is that mean supercontroller? But i do compile the newest version of the Farm.
By the way i wanna know whether i can use more than two turbines in this simulation like exampleâNeutral_8mps_3MWâ, i mean what i need to do is add some similiar code as followed?
1000.0 1000.0 0.0 "OpenFAST\NRELOffshrBsline5MW_WT1.fst" 921.0 925.0 5.0 10.0 10.0 10.0
1308.0 1170.0 0.0 "OpenFAST\NRELOffshrBsline5MW_WT2.fst" 1229.0 1095.0 5.0 10.0 10.0 10.0
1616.0 1340.0 0.0 "OpenFAST\NRELOffshrBsline5MW_WT3.fst" 1537.0 1265.0 5.0 10.0
Wish for your reply .
Thanks.
Yours, Jundong.
Dear Jundong
I might have an idea about your issue. If I understand well your error, you are trying to run â5MW_OC3Spar_DLL_WTurb_WavesIrr.fstâ file using FAST.Farm. But FAST.Farm takes â.fstfâ files as input and not â.fstâ files. The â.fstfâ files define the wind farm configuration, while the â.fstâ files define the wind turbine configuration (that OpenFAST uses to compute the power, loads and other outputs). So in your case, you should use âTSinflow.fstfâ file instead. âUseSCâ can be set to True or False if you want to use the Super Controller. In the system command, you should write something like that:
C:\LocationOfFastFarm\FAST.Farm_x64.exe C:\LocationOfTheFSTFfile\TSinflow.fstf
For increasing the number of turbines, you can do it by setting âNumTurbinesâ variable in the âTSinflow.fstfâ file to the number of turbines you want in the park, then specify their locations, the â.fstâ files that each one of them uses, and the high-resolution grid around them like you did in your similar code.
I hope this helps and please correct me if Iâm wrong or it doesnât work.
Kindest regards
Younes
Thanks, Younes, for your response to Jundongâs question, which I agree with.
Just one point of clarification: we often use the extension âfstâ for the OpenFAST primary input file and âfstfâ for the FAST.Farm primary input file, but the software do not require these extensions.
Thanks,Jason and Younes,for your reponse to my questions, and i am sorry for making such errorâŚ
I solved it this problem by wrting a new âfstfâ file,but i have two more questions:
- When try to use the super controller, I donât kown why i failed, i have compiled the last-version(I think use Fast-Farm.sln is enough,right
). Nevertheless, I found âSC_DLL.slnâ in vs-build and completed the compilation, but the situation did not get better,the error information is followed:
Farm_Initialize:SC_Init:The procedure sc_end in file .\SC_DLL.dll could not be loaded.
- I temporarily gave up the call of SC, but i got an error information:
[code]OpenFAST input file heading:
Running ElastoDyn.
Running AeroDyn.
Farm_Initialize:Farm_ValidateInput:OutFmt produces a column width of 10 instead of 20 characters.
Farm_Initialize:For efficiency, NumPlanes has been reduced to the number of time steps (101).
Farm_Initialize:T1:Farm_InitFAST:FWrap_Init:FAST_InitializeAll:AD_Init:ParsePrimaryFileInfo:ParseI
nVar:
A fatal error occurred when parsing data from
â.\openfast\NRELOffshrBsline5MW_OC3Hywind_AeroDyn15.datâ.
The variable âTwrShadowâ was not assigned valid INTEGER value on line #9.
The text being parsed was :
âTrue TwrShadow - Calculate tower influence on wind based on downstream
tower shadow? (flag)â
Aborting FAST.Farm.[/code]
The distressing thing is that this problem occurs no matter if I change the Flag to âTrueâ or keep it to âFalseâ.
It also indicate something wrong with ElastoDyn input file, I just use the default âOC3Hywindâ series of dat files in r-test.
If you have any ideas, I would be very grateful, and if you need ech file, i can provide it.
Jundong
Dear Jundong and Jason,
Thank you for your reply and I am glad to help you a bit.
For the 1. question, I donât know either where the issue is sorry
. Maybe try to compile the super controller alone using the sc_dll.f90 file?
For the 2nd question, I had the same issue when updating FAST.Farm. If you look at the error, it says:
nVar:
â.\openfast[b]NRELOffshrBsline5MW_OC3Hywind_AeroDyn15.dat[/b]â.
So FAST.Farm has issues with the AeriDyn15.dat file in line #9, where it expects an INTEGER for the variable TwrShadow , and not a boolean True or False anymore. Try to put 0 instead for False (or 1 for True). You can look at the updated files here and compare them with what you have now (compare your .dat files with those updated here):
github.com/OpenFAST/r-test/tree ⌠m/TSinflow
If Iâm not wrong, you will have also issues with the ServoDyn of each turbine since it has been updated as well.
I hope this helps you a bit
I have a question as well regarding the âInflowWind INPUT fileâ of FAST.Farm. When I use a steady wind field (WindType=1), everything works smoothly. But I want a wind speed that changes in time, so I try to use a uniform wind file (.hh file) as follows:
!UAE Phase VI (Ames) wind for for a simple power curve.
!Time Wind Wind Vert. Horiz. Vert. LinV Gust
! Speed Dir Speed Shear Shear Shear Speed
0.0 8.0 0.0 0.0 0.0 0.0 0.0 0.0
210.0 8.0 0.0 0.0 0.0 0.0 0.0 0.0
210.01 10.0 0.0 0.0 0.0 0.0 0.0 0.0
9999.9 10.0 0.0 0.0 0.0 0.0 0.0 0.0
But I keep getting the following error even after updating FAST.Farm:
FAST.Farm
Copyright (C) 2021 National Renewable Energy Laboratory
Copyright (C) 2021 Envision Energy USA LTD
FAST.Farm-Unversioned from 4d598b2ce513b12103a0ed7f484a8cf5b8324f89
Compile Info:
- Compiler: Intel(R) Fortran Compiler 1910
- Precision: single
- OpenMP: No
- Date: May 08 2021
- Time: 10:06:37
Execution Info:
- Date: 05/09/2021
- Time: 21:09:08+0200
Running AWAE.
Running InflowWind.
Running Super Controller.
Running WakeDynamics.
Running FASTWrapper (v1.00.00, 7-Feb-2017).
Running OpenFAST.
FAST Certification Test #26: NREL 5.0 MW Baseline Wind Turbine (Onshore)
Running ElastoDyn.
Running AeroDyn.
AD15 Nodal Outputs: Nodal output section of AeroDyn input file not found or improperly formatted.
Skipping nodal outputs.
Running InflowWind.
Running ServoDyn.
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows, ).
Using legacy Bladed DLL interface.
FAST_InitializeAll:SrvD_Init:BladedInterface_Init:Error opening BLADED interface DLL. Checking
for legacy DLL.
Running OpenFAST.
Running ElastoDyn.
Running AeroDyn.
Running InflowWind.
Running ServoDyn.
for legacy DLL.
Running OpenFAST.
Running ElastoDyn.
Running AeroDyn.
Running InflowWind.
Running ServoDyn.
for legacy DLL.
Running OpenFAST.
Running ElastoDyn.
Running AeroDyn.
Running InflowWind.
Running ServoDyn.
for legacy DLL.
Running OpenFAST.
Running ElastoDyn.
Running AeroDyn.
Running InflowWind.
Running ServoDyn.
for legacy DLL.
Time: 0 of 400 seconds.
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
FAST.Farm_x64.exe 00007FF7F2F57678 Unknown Unknown Unknown
FAST.Farm_x64.exe 00007FF7F30FA1DA Unknown Unknown Unknown
FAST.Farm_x64.exe 00007FF7F30FFA25 Unknown Unknown Unknown
FAST.Farm_x64.exe 00007FF7F2F31476 Unknown Unknown Unknown
FAST.Farm_x64.exe 00007FF7F578444E Unknown Unknown Unknown
FAST.Farm_x64.exe 00007FF7F5C7FDB4 Unknown Unknown Unknown
KERNEL32.DLL 00007FFD18367034 Unknown Unknown Unknown
ntdll.dll 00007FFD19FE2651 Unknown Unknown Unknown
Any suggestions to overcome the issue please?
Kindest regards
Younes
Dear Jundong,
Regarding your first question, Iâve now fixed a small bug in the sc_dll.f90 that would have otherwise caused problems running the super controller compiled with Intel Fortran on Windows. You can find the fix in the following pull request, which I expect will get merged in soon: github.com/OpenFAST/openfast/pull/746. Iâve also fixed this in the super controller attached to my post dated Mar 18, 2021 attached. Thanks for reporting the problem.
Dear Younes.
Thank you for answering Jundongâs questions.
Iâm not sure what the problem is. All you did between the FAST.Farm simulation that runs and the one that errors out is change the WindType in InflowWind? Iâm afraid the error message is not providing any useful information. I suggest compiling in debug mode and trying again; hopefully this will provide more information that can be used to identify the problem.
Dear Jason:
Thanks for your help that i can use supercontroller after add the code you given.
But i still met the problem followed:
Running ElastoDyn.
Running AeroDyn.
nVar:
As i said before,the distressing thing is that this problem occurs no matter if I change the Flag to âTrueâ or keep it to âFalseâ.
I noticed that there is already a pull request called âShared Moorings updates for FAST.Farmâ on the Git Hub. Is it used to solve this problem?
Jundong
Dear Jundong,
I thought Younes answered your question regarding TwrShadow well. TwrShadow was changed from a TRUE/FALSE flag to an integer input in the dev branch of OpenFAST, i.e.:
0 TwrShadow - Calculate tower influence on wind based on downstream tower shadow (switch) {0=none, 1=Powles model, 2=Eames model}
The pull request titled âShared Mooring Updates for FAST.Farmâ is for new functionality for floating offshore wind farms.
Dear Jason
Sorry I ignored this part of the informationâŚ
Thanks !
Dear Younes
Sorry for not being able to grasp your suggestion in time, thank you very much for your help!
Kindest regards
Jundong
