Extract blade tip torsional deformation from the Wiener-Milenković parameters in BeamDyn
I am trying to extract the blade tip torsional deformation from the outputs of BeamDyn. The parameters “TipRdxr”, “TipRDyr” and “TipRDzr” in BeamDyn output are Wiener-Milenković rotation parameters, which corresponds to c1, c2 and c3 in the equation(5.17) in BeamDyn User’s Guide. Now I can calculate the rotation tensor R(c), and then extract the Euler angles (yaw, pitch and roll) from it. My question is that the Euler angle which represents the rotation around the blade pitch axis is the blade torsional deformation?
I would be appreciated for your reply.
Best regards.
Xiaoqi
Hi Xiaoqi,
had you been able to calculate the blade tip torsional displacement in BeamDyn?
I have right now the same task.
Simon
Hi all,
is it correct that the Theta-angle (Inflow) that is available as output in AeroDyn can give the rotational deflection about blade root z-axis when substracted with the fixed aerodynamic twist and the time dependent pitch angle?
So:
Rotational deflection = Theta at node - aerodynamic twist at node - pitch angle of blade
Simon
Hi Simon,
I had has asked someone else from NREL to respond to Xiaoqi’s original post, and I don’t see that they have.
I’m not sure I fully understand how twist/torsion is defined for a curved or deflected blade (it is trivial for a straight undeflected blade). I would guess the actual twist would have to be defined by integrating the local incremental twist around the local z-axis of the blade (tangent to the curve) from the root to each cross section. I had asked for confirmation on this from others at NREL, but I have not yet received a response.
The Wiener-Milenkovic parameters output from BeamDyn define the actual orientation of each cross section relative to the undeflected orientation.
Likewise, the theta angle output from AeroDyn gives the actual orientation of the airfoil (chordline) relative to the local AeroDyn blade coordinate system (the rotation about the local z axis), which is tangent to the deflected blade in the out-of-plane deflection.
Based on my understanding of twist/torsion above, neither the Wiener-Milenkovic parameters nor theta will result in the actual twist, except for straight undeflected blades, although for curved / deflected blades, these angles will be reasonable proxies for the actual twist.
Bet regards,
