Dear @Jason.Jonkman,
Excuse me. Is there any way to transform the sectional loads in local coordinate system (such as N1Fxl, N1Fyl, N1Fzl, N1Mxl, N1Myl, N1Mzl, which are output by BeamDyn) to the blade coordinate system (r)?
In my understanding N1Fxl et al. accounts for the local structural pretwist and the local deflection of the blade, but I can’t obtain the local deflection.
Maybe the Sectional Partial Loads (debugging) from OutListParameters. xlsx can help to solve that, but they are not available output channels.
Thank you for your time and patience.
Dear @Baoxuan.Wang,
You can output the sectional angular/rotational deflection Wiener-Milenkovic parameters (relative to the undeflected orientation) at Node 1 expressed in the blade coordinate system (r) (N1RDxr, N1RDyr, N1RDzr for output node 1 etc.). These can be used to calculate the local rotation tensor as documented here: 4.2.4.5. BeamDyn Theory — OpenFAST v3.3.0 documentation. Premultiplication of the local loads (N1Mxl, N1Myl, N1Mzl for output node 1 etc.) by this rotation tensor will transform the loads to r.
Thank you for your fast reply.
So, does this transformation process from l to r not need to consider StrcTwst ?
Dear @Baoxuan.Wang,
Good point. The Wiener-Milenkovic parameters only account for the elastic rotations, so, the transformation above will result in loads in a coordinate system aligned with the undeflected structural axes. If your structural axes include the effect of structural twist (through BeamDyn input initial_twist), then you’ll have to apply an additional transformation if you want to express the loads in a coordinate system without this twist.
For the Sectional Loads outputs from BeamDyn, I find that the values of Fxr, Fyr and Fzr are 0 at the last station (tip station)(such as B1N132_Fxr=B1N132_Fyr=B1N132_Fyr=0, and station_total is set to 132 in my BeamDyn input file).
However, the values of Mxr, Myr and Mzr at tip station are not equal to 0 (such as B1N132_Mzr), which makes me confused. Is this reasonable?
I want to ask for your help so as to know how the reaction moment at the tip section is calculated in BeamDyn.
Thanks in advance.
Dear @Baoxuan.Wang,
Is the moment at the tip small relative to the moment at more inboard blade stations? Perhaps there is some residual aerodynamic applied moment being transferred from AeroDyn to BeamDyn?
It sounds like your BeamDyn model is highly discretized. And presumably you are using trapezoidal quadrature (quadrature = 2 in BeamDyn). What blade discretization are you using in AeroDyn? Does the result improve if you finely discretize AeroDyn? What if you make the AeroDyn blade and BeamDyn blade meshes the same such that the internal mesh-mapping is one-to-one?
Thank you for your constant help.
In fact, in my case, it seems not small, espeacially for Mz, as you can see as follows:
Additionally, I also run the certification test (5MW_Land_BD_DLL_WTurb) with 19 NumBlNds in AERODYN and 49 stations to compare, whose results are as follows.
quadrature= 2 in BeamDyn). What blade discretization are you using in AeroDyn?
In AeroDyn, I didn’t change the origin blade discretization which is the origin NRELOffshrBsline5MW_AeroDyn_blade.dat in NRELOffshrBsline5MW_OC3Hywind_AeroDyn15.dat.
I only modified the beamdyn files as follows.
--------- BEAMDYN with OpenFAST INPUT FILE -------------------------------------------
SNL 5.0 MW Offshore blade input for Beamdyn with 131 stations written by SFY 20221207.
---------------------- SIMbaselineULATION CONTROL --------------------------------------
False Echo - Echo input data to “.ech”? (flag)
True QuasiStaticInit - Use quasi-static pre-conditioning with centripetal accelerations in initialization? (flag) [dynamic solve only]
0 rhoinf - Numerical damping parameter for generalized-alpha integrator
2 quadrature - Quadrature method: 1=Gaussian; 2=Trapezoidal (switch)
“DEFAULT” refine - Refinement factor for trapezoidal quadrature (-) [DEFAULT = 1; used only when quadrature=2]
“DEFAULT” n_fact - Factorization frequency for the Jacobian in N-R iteration(-) [DEFAULT = 5]
“DEFAULT” DTBeam - Time step size (s)
“DEFAULT” load_retries - Number of factored load retries before quitting the simulation [DEFAULT = 20]
500 NRMax - Max number of iterations in Newton-Raphson algorithm (-) [DEFAULT = 10]
“DEFAULT” stop_tol - Tolerance for stopping criterion (-) [DEFAULT = 1E-5]
“DEFAULT” tngt_stf_fd - Use finite differenced tangent stiffness matrix? (flag)
“DEFAULT” tngt_stf_comp - Compare analytical finite differenced tangent stiffness matrix? (flag)
“DEFAULT” tngt_stf_pert - Perturbation size for finite differencing (-) [DEFAULT = 1E-6]
“DEFAULT” tngt_stf_difftol - Maximum allowable relative difference between analytical and fd tangent stiffness (-); [DEFAULT = 0.1]
True RotStates - Orient states in the rotating frame during linearization? (flag) [used only when linearizing]
---------------------- GEOMETRY PARAMETER --------------------------------------
1 member_total - Total number of members (-)
132 kp_total - Total number of key points (-) [must be at least 3]
1 132 - Member number; Number of key points in this member
kp_xr kp_yr kp_zr initial_twist
(m) (m) (m) (deg)
0.000000E+00 0.000000E+00 0.000000E+00 1.331000E+01
0.000000E+00 0.000000E+00 0.010000E+00 1.331000E+01
0.000000E+00 0.000000E+00 1.500000E-01 1.331000E+01
0.000000E+00 0.000000E+00 3.500000E-01 1.331000E+01
0.000000E+00 0.000000E+00 4.500000E-01 1.331000E+01
0.000000E+00 0.000000E+00 5.500000E-01 1.331000E+01
0.000000E+00 0.000000E+00 6.500000E-01 1.331000E+01
0.000000E+00 0.000000E+00 7.500000E-01 1.331000E+01
0.000000E+00 0.000000E+00 9.000000E-01 1.331000E+01
0.000000E+00 0.000000E+00 1.185000E+00 1.331000E+01
0.000000E+00 0.000000E+00 1.435000E+00 1.331000E+01
0.000000E+00 0.000000E+00 1.550000E+00 1.331000E+01
0.000000E+00 0.000000E+00 1.800000E+00 1.331000E+01
0.000000E+00 0.000000E+00 2.250000E+00 1.331000E+01
0.000000E+00 0.000000E+00 2.750000E+00 1.331000E+01
0.000000E+00 0.000000E+00 3.250000E+00 1.331000E+01
0.000000E+00 0.000000E+00 3.800000E+00 1.331000E+01
0.000000E+00 0.000000E+00 4.300000E+00 1.331000E+01
0.000000E+00 0.000000E+00 4.750000E+00 1.331000E+01
0.000000E+00 0.000000E+00 5.250000E+00 1.331000E+01
0.000000E+00 0.000000E+00 5.750000E+00 1.331000E+01
0.000000E+00 0.000000E+00 6.250000E+00 1.331000E+01
0.000000E+00 0.000000E+00 6.665000E+00 1.331000E+01
0.000000E+00 0.000000E+00 6.915000E+00 1.331000E+01
0.000000E+00 0.000000E+00 7.250000E+00 1.331000E+01
0.000000E+00 0.000000E+00 7.750000E+00 1.331000E+01
0.000000E+00 0.000000E+00 8.250000E+00 1.331000E+01
0.000000E+00 0.000000E+00 8.750000E+00 1.331000E+01
0.000000E+00 0.000000E+00 9.250000E+00 1.331000E+01
0.000000E+00 0.000000E+00 9.750000E+00 1.331000E+01
0.000000E+00 0.000000E+00 1.012500E+01 1.331000E+01
0.000000E+00 0.000000E+00 1.037500E+01 1.325500E+01
0.000000E+00 0.000000E+00 1.075000E+01 1.308500E+01
0.000000E+00 0.000000E+00 1.125000E+01 1.286000E+01
0.000000E+00 0.000000E+00 1.175000E+01 1.264000E+01
0.000000E+00 0.000000E+00 1.225000E+01 1.241500E+01
0.000000E+00 0.000000E+00 1.275000E+01 1.219000E+01
0.000000E+00 0.000000E+00 1.325000E+01 1.197000E+01
0.000000E+00 0.000000E+00 1.375000E+01 1.175000E+01
0.000000E+00 0.000000E+00 1.417500E+01 1.156000E+01
0.000000E+00 0.000000E+00 1.442500E+01 1.145500E+01
0.000000E+00 0.000000E+00 1.475000E+01 1.135500E+01
0.000000E+00 0.000000E+00 1.525000E+01 1.120500E+01
0.000000E+00 0.000000E+00 1.575000E+01 1.105500E+01
0.000000E+00 0.000000E+00 1.625000E+01 1.090500E+01
0.000000E+00 0.000000E+00 1.675000E+01 1.075500E+01
0.000000E+00 0.000000E+00 1.725000E+01 1.060500E+01
0.000000E+00 0.000000E+00 1.775000E+01 1.045500E+01
0.000000E+00 0.000000E+00 1.822500E+01 1.027000E+01
0.000000E+00 0.000000E+00 1.872500E+01 1.012000E+01
0.000000E+00 0.000000E+00 1.925000E+01 1.000500E+01
0.000000E+00 0.000000E+00 1.975000E+01 9.855000E+00
0.000000E+00 0.000000E+00 2.025000E+01 9.705000E+00
0.000000E+00 0.000000E+00 2.075000E+01 9.555000E+00
0.000000E+00 0.000000E+00 2.125000E+01 9.405000E+00
0.000000E+00 0.000000E+00 2.175000E+01 9.255000E+00
0.000000E+00 0.000000E+00 2.227500E+01 9.095000E+00
0.000000E+00 0.000000E+00 2.277500E+01 8.945000E+00
0.000000E+00 0.000000E+00 2.325000E+01 8.805000E+00
0.000000E+00 0.000000E+00 2.375000E+01 8.655000E+00
0.000000E+00 0.000000E+00 2.430000E+01 8.490000E+00
0.000000E+00 0.000000E+00 2.480000E+01 8.340000E+00
0.000000E+00 0.000000E+00 2.525000E+01 8.210000E+00
0.000000E+00 0.000000E+00 2.575000E+01 8.065000E+00
0.000000E+00 0.000000E+00 2.632500E+01 7.890000E+00
0.000000E+00 0.000000E+00 2.682500E+01 7.740000E+00
0.000000E+00 0.000000E+00 2.725000E+01 7.615000E+00
0.000000E+00 0.000000E+00 2.775000E+01 7.460000E+00
0.000000E+00 0.000000E+00 2.825000E+01 7.305000E+00
0.000000E+00 0.000000E+00 2.875000E+01 7.155000E+00
0.000000E+00 0.000000E+00 2.925000E+01 7.005000E+00
0.000000E+00 0.000000E+00 2.975000E+01 6.850000E+00
0.000000E+00 0.000000E+00 3.025000E+01 6.695000E+00
0.000000E+00 0.000000E+00 3.062500E+01 6.580000E+00
0.000000E+00 0.000000E+00 3.087500E+01 6.505000E+00
0.000000E+00 0.000000E+00 3.125000E+01 6.400000E+00
0.000000E+00 0.000000E+00 3.175000E+01 6.255000E+00
0.000000E+00 0.000000E+00 3.225000E+01 6.110000E+00
0.000000E+00 0.000000E+00 3.275000E+01 5.965000E+00
0.000000E+00 0.000000E+00 3.325000E+01 5.820000E+00
0.000000E+00 0.000000E+00 3.375000E+01 5.680000E+00
0.000000E+00 0.000000E+00 3.425000E+01 5.535000E+00
0.000000E+00 0.000000E+00 3.467500E+01 5.410000E+00
0.000000E+00 0.000000E+00 3.492500E+01 5.340000E+00
0.000000E+00 0.000000E+00 3.525000E+01 5.250000E+00
0.000000E+00 0.000000E+00 3.575000E+01 5.105000E+00
0.000000E+00 0.000000E+00 3.625000E+01 4.960000E+00
0.000000E+00 0.000000E+00 3.675000E+01 4.820000E+00
0.000000E+00 0.000000E+00 3.725000E+01 4.675000E+00
0.000000E+00 0.000000E+00 3.775000E+01 4.530000E+00
0.000000E+00 0.000000E+00 3.825000E+01 4.390000E+00
0.000000E+00 0.000000E+00 3.872500E+01 4.255000E+00
0.000000E+00 0.000000E+00 3.997500E+01 3.925000E+00
0.000000E+00 0.000000E+00 4.125000E+01 3.595000E+00
0.000000E+00 0.000000E+00 4.175000E+01 3.465000E+00
0.000000E+00 0.000000E+00 4.225000E+01 3.335000E+00
0.000000E+00 0.000000E+00 4.277500E+01 3.200000E+00
0.000000E+00 0.000000E+00 4.402500E+01 2.935000E+00
0.000000E+00 0.000000E+00 4.525000E+01 2.690000E+00
0.000000E+00 0.000000E+00 4.575000E+01 2.595000E+00
0.000000E+00 0.000000E+00 4.625000E+01 2.500000E+00
0.000000E+00 0.000000E+00 4.682500E+01 2.385000E+00
0.000000E+00 0.000000E+00 4.732500E+01 2.285000E+00
0.000000E+00 0.000000E+00 4.775000E+01 2.200000E+00
0.000000E+00 0.000000E+00 4.825000E+01 2.105000E+00
0.000000E+00 0.000000E+00 4.875000E+01 2.010000E+00
0.000000E+00 0.000000E+00 4.925000E+01 1.910000E+00
0.000000E+00 0.000000E+00 4.975000E+01 1.815000E+00
0.000000E+00 0.000000E+00 5.025000E+01 1.720000E+00
0.000000E+00 0.000000E+00 5.075000E+01 1.620000E+00
0.000000E+00 0.000000E+00 5.112500E+01 1.550000E+00
0.000000E+00 0.000000E+00 5.162500E+01 1.455000E+00
0.000000E+00 0.000000E+00 5.225000E+01 1.330000E+00
0.000000E+00 0.000000E+00 5.275000E+01 1.235000E+00
0.000000E+00 0.000000E+00 5.325000E+01 1.140000E+00
0.000000E+00 0.000000E+00 5.375000E+01 1.040000E+00
0.000000E+00 0.000000E+00 5.433500E+01 9.250000E-01
0.000000E+00 0.000000E+00 5.483500E+01 8.300000E-01
0.000000E+00 0.000000E+00 5.525000E+01 7.550000E-01
0.000000E+00 0.000000E+00 5.575000E+01 6.650000E-01
0.000000E+00 0.000000E+00 5.625000E+01 5.750000E-01
0.000000E+00 0.000000E+00 5.675000E+01 4.850000E-01
0.000000E+00 0.000000E+00 5.720000E+01 4.050000E-01
0.000000E+00 0.000000E+00 5.770000E+01 3.400000E-01
0.000000E+00 0.000000E+00 5.825000E+01 2.850000E-01
0.000000E+00 0.000000E+00 5.875000E+01 2.400000E-01
0.000000E+00 0.000000E+00 5.925000E+01 1.950000E-01
0.000000E+00 0.000000E+00 5.981500E+01 1.400000E-01
0.000000E+00 0.000000E+00 6.031500E+01 9.500000E-02
0.000000E+00 0.000000E+00 6.075000E+01 6.000000E-02
0.000000E+00 0.000000E+00 6.125000E+01 2.000000E-02
0.000000E+00 0.000000E+00 6.150000E+01 0.000000E+00
---------------------- MESH PARAMETER ------------------------------------------
3 order_elem - Order of interpolation (basis) function (-)
---------------------- MATERIAL PARAMETER --------------------------------------
“SNL5MWBDBlade132_SfyWbx.dat” BldFile - Name of file containing properties for blade (quoted string)
---------------------- PITCH ACTUATOR PARAMETERS -------------------------------
False UsePitchAct - Whether a pitch actuator should be used (flag)
200 PitchJ - Pitch actuator inertia (kg-m^2) [used only when UsePitchAct is true]
2E+07 PitchK - Pitch actuator stiffness (kg-m^2/s^2) [used only when UsePitchAct is true]
500000 PitchC - Pitch actuator damping (kg-m^2/s) [used only when UsePitchAct is true]
---------------------- OUTPUTS -------------------------------------------------
“ES10.3E2” OutFmt - Format used for text tabular output, excluding the time channel.
9 NNodeOuts - Number of nodes to output to file [0 - 9] (-)
1,2,3,4,5,6,7,8,9 OutNd - Nodes whose values will be output (-)
“RootFxr, RootFyr, RootFzr”
“RootMxr, RootMyr, RootMzr”
“TipRDxr, TipRDyr, TipRDzr”
“TipTDxr, TipTDyr, TipTDzr”
---------------------- NODE OUTPUTS --------------------------------------------
99 BldNd_BlOutNd - Blade nodes on each blade (currently unused)
OutList - The next line(s) contains a list of output parameters. See OutListParameters.xlsx, BeamDyn_Nodes tab for a listing of available output channels, (-)
“Fxr”
“Fyr”
“Fzr”
“Mxr”
“Myr”
“Mzr”
“TDxr”
“TDyr”
“TDzr”
------- BEAMDYN V1.00.* INDIVIDUAL BLADE INPUT FILE --------------------------
SNL 5.0 MW Offshore baseline blade input for Beamdyn with 131 stations written by SFY 20221207.
---------------------- BLADE PARAMETERS --------------------------------------
132 station_total - Number of blade input stations (-)
1 damp_type - Damping type: 0: no damping; 1: damped
---------------------- DAMPING COEFFICIENT------------------------------------
mu1 mu2 mu3 mu4 mu5 mu6
1.0E-03 1.0E-03 1.0E-03 0.0014 0.0022 0.0022
---------------------- DISTRIBUTED PROPERTIES---------------------------------
0.000000
3.087068E+09 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 3.083361E+09 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 1.285728E+10 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 1.779378E+10 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 1.828113E+10 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 1.076730E+101.047926E+03 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 1.047926E+03 0.000000E+00 0.000000E+00 0.000000E+00 -0.000000E+00
0.000000E+00 0.000000E+00 1.047926E+03 -0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 -0.000000E+00 1.501780E+03 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 1.501737E+03 0.000000E+00
0.000000E+00 -0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 3.003518E+030.000162
0.000000E+00 -0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 3.003518E+030.002439
2.551162E+09 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 2.518838E+09 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 1.482989E+10 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 2.056501E+10 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 2.106312E+10 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 1.072970E+101.081919E+03 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 1.081919E+03 0.000000E+00 0.000000E+00 0.000000E+00 -0.000000E+00
0.000000E+00 0.000000E+00 1.081919E+03 -0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 -0.000000E+00 1.550523E+03 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 1.550443E+03 0.000000E+00
0.000000E+00 -0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 3.100966E+03
…1.000000
6.141300E+05 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 1.535704E+07 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 6.053185E+08 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 4.447249E+07 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 2.923733E+06 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 1.276538E+062.645346E+01 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 -2.592398E+00
0.000000E+00 2.645346E+01 0.000000E+00 0.000000E+00 0.000000E+00 -7.274426E-01
0.000000E+00 0.000000E+00 2.645346E+01 2.592398E+00 7.274426E-01 0.000000E+00
0.000000E+00 0.000000E+00 2.592398E+00 2.764406E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 7.274426E-01 0.000000E+00 1.516806E-01 0.000000E+00
-2.592398E+00 -7.274426E-01 0.000000E+00 0.000000E+00 0.000000E+00 2.916087E+00
According to your suggestions, I am going to add NumBlNds in NRELOffshrBsline5MW_OC3Hywind_AeroDyn15.dat based on DISTRIBUTED BLADE AERO DYNAMIC PROPERTIES as follows:
Look forward to your further guidance.
Dear @Baoxuan.Wang,
Indeed it looks like the moments at the tip are smaller than at more inboard sections of the blade, but just not as low as you expect. Let me know what you find if you choose to add aerodynamic nodes so that the aerodynamic discretization is more aligned with the structural discretization.
I do see that you have offsets of the aerodynamic nodes from the pitch axis (nonzero BlCrvAC and BlSwpAC in the AeroDyn blade input file). This means that the aerodynamic forces will generate pitching moments on top of any aerodynamic pitching moment about the aerodynamic center. You can always quantify the contribution of the offsets versus direct pitching moment by disabling one or the other. To disable the offsets, set BlCrvAC = BlSwpAC = 0. To disable the direct pitching moment, set UseBlCm = False in the AeroDyn input file.
