Extending 10-minute wind field to 6 hours
Hello everyone.
I am new to FAST and have a problem I have been unable to solve for the past couple of days. I am trying to extend a 600s simulation to 6 hours in a .bts file.
I have downloaded TurbSim and have used the PERL script to generate 36 seeds. I renamed the PERL script accordingly and set out to run the input file. The problem is that once I decide to use the generated .bts file in a FAST simulation, my wind field runs out at 601s out of 21600s. The reason is that my input file is specified at 600s Analysis time and Usable time, which would be a standard 10-minute wind field generated by TurbSim.
My question is this: How do I extend the wind field to 21600s. I thought that the Perl script does that for me and compiles the .bts file.
Below are my Perl script and initial input file .inp. I really would appreciate any help you can offer!
TurbSim Input File. Valid for TurbSim v1.50; 17-May-2010; Example file that can be used with simulations for the NREL 5MW Baseline Turbine; note that UsableTime has been decreased in this file so that the file distributed with the FAST CertTest isn’t as large
13428 RandSeed1 - First random seed (-2147483648 to 2147483647)
RanLux RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
True WrADTWR - Output tower time-series data? (Generates RootName.twr)
630.0 AnalysisTime - Length of analysis time series [seconds]
600.0 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds) [bjj: was 630]
90.0 HubHt - Hub height [m] (should be > 0.5GridHeight)
145.0 GridHeight - Grid height [m]
145.0 GridWidth - Grid width [m] (should be >= 2
(RotorRadius+ShaftLength))
IECKAI TurbModel - Turbulence model (“IECKAI”=Kaimal, “IECVKM”=von Karman, “GP_LLJ”, “NWTCUP”, “SMOOTH”, “WF_UPW”, “WF_07D”, “WF_14D”, or “NONE”)
“1-ed3” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
“B” IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP, not used for other models)
3EWM50 IEC_WindType - IEC turbulence type (“NTM”=normal, “xETM”=extreme turbulence, “xEWM1”=extreme 1-year wind, “xEWM50”=extreme 50-year wind, where x=wind turbine class 1, 2, or 3)
default ETMc - IEC Extreme turbulence model “c” parameter [m/s]
PL WindProfileType - Wind profile type (“JET”=Low-level jet,“LOG”=Logarithmic,“PL”=Power law, or “default”, or “USR”=User-defined)
90. RefHt - Height of the reference wind speed [m]
31.0 URef - Mean (total) wind speed at the reference height [m/s]
default PC_UW - Hub mean u’w’ Reynolds stress [(m/s)^2] (or “default”)
default PC_UV - Hub mean u’v’ Reynolds stress [(m/s)^2] (or “default”)
default PC_VW - Hub mean v’w’ Reynolds stress [(m/s)^2] (or “default”)
default IncDec1 - u-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default IncDec2 - v-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default IncDec3 - w-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default CohExp - Coherence exponent (or “default”)
“C:\Users\EVGDIM\Desktop\FAST + Orcaflex\TurbSim\EventData” CTEventPath - Name of the path where event data files are located
“Random” CTEventFile - Type of event files (“random”, “les” or “dns”)
true Randomize - Randomize disturbance scale and location? (true/false)
1.0 DistScl - Disturbance scale (ratio of dataset height to rotor disk).
0.5 CTLy - Fractional location of tower centerline from right (looking downwind) to left side of the dataset.
0.5 CTLz - Fractional location of hub height from the bottom of the dataset.
10.0 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
NOTE: Do not add or remove any lines in this file!
PERL SCRIPT
RunTurbSim.pl
See Marshall Buhl’s RunNTM Perl script for help with this script.
Run a series of TurbSim tests, changing the seed for each case.
NOTICE
Look for the string “USER” for lines that you may want to change.
User-specified paths to programs and files. USER: YOU WILL DEFINITELY NEED TO CHANGE THESE.
$turbsim = “TurbSim”;
The TurbSim input/output file name:
$input_file = “C:/Users/EVGDIM/Desktop/FAST + Orcaflex/TurbSim/90m_37mps_50yr.inp”;
The Directory to place results in:
$rslt_dir = “C:/Users/EVGDIM/Desktop/FAST + Orcaflex/TurbSim/Results Seeds”;
The name of the resulting file in the results directory (will be appended with the seed number)
$rslt_file = “37mps_TurbS_CTS_50yr”;
The extensions of TurbSim output to copy to the results directory:
#@out_ext = (“inp”,“sum”,“wnd”,“cts”);
@out_ext = (“sum”,“wnd”,“cts”);
Set the number of seeds to run. Initialize the first seed. USER: YOU MAY WANT TO CHANGE THESE
$seed_1 = 816416316;
$n_seeds = 36;
Get and save the start time. Initialize other variables
$StartTime = date_time();
$n_runs = 0;
$seed_line = 4;
srand($seed_1);
Loop through all seeds.
for $i_seed ( 1..$n_seeds )
$ts_root = "${rslt_file}";
#     Create TurbSim Input File
  $in_file = "${ts_root}.inp";
  open( IN_FILE , ">$in_file" )   or die( "Can't open '$in_file'.\n"  );
  open( IN_FILE1, "$input_file" ) or die( "Can't open '$input_file'.\n" );
  $cnt = 1;
  while ( <IN_FILE1> )
      if ( $cnt == $seed_line )
          printf ( IN_FILE "%s\t%s\n", "$seed_1", "The first seed" );
      else
              print IN_FILE;
      $cnt++;
  } # while <IN_FILE1>
  close( IN_FILE  );
  close( IN_FILE1 );
Run TurbSim
  print "\n ==============================================\n";
  print   " TurbSim Seed $i_seed  = $seed_1 \n";
  print   " ==============================================\n";
  print   " Starting TurbSim on ", date_time(), ".\n";
  system( "$turbsim $ts_root.inp > NUL" );
Rename output
$root = sprintf( "%s/%s_%s", $rslt_dir, $ts_root, $i_seed);
for $i_r ( 0..$#out_ext )
  rename( "$ts_root.$out_ext[$i_r]" , "$root.$out_ext[$i_r]" );
Get next seed
$seed_1 = int( rand(2147483646) ) + 1;
$n_runs ++;
End of $i_seed loop
Done.
print “\n ============================================\n”;
if ( $n_runs > 1 )
print " After starting on $StartTime, the $n_runs batch runs\n";
print " completed on ", date_time(), “.\n\n”;
else
print " The single batch run completed on ", date_time(), “.\n\n”;
End of main function.
This routine returns the date and time in the form “dd-Mon-ccyy at hh:mm:ss”.
sub date_time
my( $sec, $min, $hour, $mday, $mon, $year, $mon_str );
($sec, $min, $hour, $mday, $mon, $year) = localtime;
$mon_str = (Jan,Feb,Mar,Apr,May,Jun,Jul,Aug,Sep,Oct,Nov,Dec)[$mon];
return sprintf( “%2.2d-%s-%4.4d at %2.2d:%2.2d:%2.2d”, $mday, $mon_str, $year+1900, $hour, $min, $sec );
END
Dear Evgeniy,
The script you are using will generate 36 unique TurbSim output (*.bts) files with which you can run 36 unique FAST simulations, each of 600 s in length. The script will not concatenate the TurbSim files into a single file for running longer FAST simulations (nor would you want to as the flow would be discontinuous where the files are concatenated.
To run longer FAST simulations, you could either run TurbSim for longer (more than 600 s) or use periodic wind data files i.e. wind is repeated periodically over the total FAST simulation length. For the latter, the ability to generate periodic wind files was introduced in TurbSim v2.00 and newer, available from here: nwtc.nrel.gov/alphas. Simply set TurbSim input UsableTime to the string, “ALL” and run TurbSim to generate periodic wind data files useable by FAST.
thank you very much for the help and fast response. The model does run now for longer periods of time.
I tried running a 3-hour simulation. Everything was ok until my simulation reached near 10 000 seconds of 10 800s and I got the following error below. Could you please advise?
[code]C:BeddoesModel:ATT
ACH: Blade #1 element #17 is supersonic! Other elements are likely supersonic a
s well.
Supersonic mach nos. will be set to 0.7 to attempt continuation.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Supersonic condition has subsided w
ith Blade #2
element #4.
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:AD14_CalcOutput:ELEMFR
C:BeddoesModel:ATT
s well.
ith Blade #2
element #4.
C:BeddoesModel:ATT
ACH: Blade #3 element #17 is supersonic! Other elements are likely supersonic a
s well.
C:BeddoesModel:ATT
ACH: Supersonic condition has subsided with Blade #1 element #4.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3 element #17 is supersonic!
Other elements
are likely supersonic as well. Supersonic mach nos. will be set to 0.7 to attemp
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3 element #16 is supersonic!
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
Other elements
t continuation.
C:BeddoesModel:ATT
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3 element #15 is supersonic!
Other elements
t continuation.
C:BeddoesModel:ATT
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3 element #14 is supersonic!
Other elements
t continuation.
WARNING: High VT velocity encountered during induction factor calculation.
Blade number 1, Element number 17
VNW = 36.185, VT = 412.7
Blade number 2, Element number 17
VNW = 30.494, VT = 405.2
Blade number 3, Element number 13
VNW = 41.093, VT = 454.81
Blade number 3, Element number 14
VNW = 40.533, VT = 516.39
WARNING: High VNB velocity encountered during induction factor calculation.
Blade number 3, Element number 15
VNW = 39.772, VNB = 130.88
WARNING: Induced velocity warning written 5 times. The message will not be
repeated, though
the condition may persist.
C:BeddoesModel:ATT
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #1 element #15 is supersonic!
Other elements
t continuation.
ith Blade #2
element #4.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #2 element #15 is supersonic!
Other elements
t continuation.
ith Blade #3
element #4.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3 element #11 is supersonic!
Other elements
t continuation.
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
FAST_x64.exe 0000000140C8F786 Unknown Unknown Unknown
FAST_x64.exe 0000000140C8DC41 Unknown Unknown Unknown
FAST_x64.exe 0000000140C8B8DD Unknown Unknown Unknown
FAST_x64.exe 0000000140C88959 Unknown Unknown Unknown
FAST_x64.exe 00000001400D6C2D Unknown Unknown Unknown
FAST_x64.exe 00000001400D55E4 Unknown Unknown Unknown
FAST_x64.exe 000000014004EAB0 Unknown Unknown Unknown
FAST_x64.exe 000000014003AD98 MAIN__ 132 FAST_Prog.f9
0
FAST_x64.exe 000000013FC8A2B6 Unknown Unknown Unknown
FAST_x64.exe 0000000141016EAC Unknown Unknown Unknown
kernel32.dll 00000000779859CD Unknown Unknown Unknown
ntdll.dll 0000000077ABA561 Unknown Unknown Unknown[/code]
Dear Evgeniy,
I’m not sure; without knowing more about your simulation settings, it’s hard to know that what the problem is. But warnings regarding “supersonic blades” have been discussed several times on this forum. Please use “Search…” in the upper right of the forum to search for “supersonic” to see how we’ve solved similar problems in the past.
thank you for your fast reply and help. Apologies for my late reply as I didn’t want to post anything before I had come up with some solution or at least positive progress. I managed to solve the problem by looking at the FAST input file .fst and extending the Checkpoint creation file “ChkptTime” from 9999 to 99999.
I did the same in the ServoDyn.dat file. I looked at all 9999 values with units of time and increased to 99999, where it made sense, given the function description in the standard input file.
The reason for doing this was the suspicious time instance at which the simulation always crashed regardless of all other inputs. The crash always occurred at 10 000s.
Given that the error I posted above for the supersonic blades, detailed one of the FAST source scripts - FAST_Prog.f90 Line 132, which deals with time step issues, as a potential source for the crash. In addition to OrcaFlex visualisation of the simulation run, up to the point before it crashed, which showed that everything was in order, my only conclusion was the way the OC3 Hywind file was designed with a 4-digit limit as the maximum simulation time possible across all modules. Going from a 4-digit max simulation time to a 5-digit limit made sense in my mind.
Does this sound as a reasonable solution to you?
Dear Evgeniy,
My guess is it was the changes you made to input parameters in ServoDyn (from 9999 to 99999 s) that solved the problem i.e. you were likely initiating a control action that you had not intended. I would not expect that the generation of a checkpoint file would cause a problem.
I’m not sure I understand your point about the FAST source code.
I simply meant to say that the following lines from the error message:
FAST_x64.exe 000000014003AD98 MAIN__ 132 FAST_Prog.f90
Made me think that something was wrong with the time step specifications. Line 132 accounts for time steps, thus I figured I had not specified the max time limit appropriately in some of the FAST modules.
Again, thank you very much for your help! :slight_smile: Have a great weekend!
