Dear Jason:
Hi, sorry to bother you, but I got a confusing problem when I am using FAST-orcaflex coupling. And the situation is that I have no clue about what the problem excatly is. So…
Here are my questions:
- I used the Turbsim and generated a wind field for 10 seeds with Uhub=24m/s and the turbulence Intensity 0.12 and the related Hs=8m, Tz=8.5. Using the Hywind control system DISCON_OC3Hywind_x64.dll, I set the initial blade pitch as 0.
After the simulations were done, I checked the .out file and found out the bldpitch was like the attachment.
This kind of cycle continued and there was no error or warning reported during the simulation. This was found in some seeds yet not in the others. Meanwhile, this phenomenon was also found in the wind speed 22.4m/s related sea state and the wind speed 25.5m/s related sea states, but not in the sea state whose wind speed are low.
so what is this about?
- During the coupling simulation, I encountered this error:
Fwind_calcOutput [position=<NaN,NaN,NaN> in wind-file coordinates]: Error: FF wind array was exhausted at 6654 seconds .
I guessed that this is because the wind field grid is too small, but I am not sure about it.
