I am currently using FAST v7 to model the response of NREL 5MW offshore wind turbine under special extreme cases, in which the turbine is loss of network (idling) and the yaw and pitch systems both are out of control. The possible yaw misalignment and pitch angles are ±180° and 0-90°,respectively. The wind and wave parameters are: U=40m/s, TI=11%, Hs=8m, Tp=11s. The settings related to the yaw and pitch system in the main input files are following Dr. Jonkman’s recommendations in other forum topics.
When I run these simulations, I got the following error for the cases where pitch angle=0 (other cases, i.e. pitch angle>0, run normally). I really appreciate it if someone could help me to solve this problem. The main input file for yaw angle=60, pitch angle=0 is attached for your further check.
Patrick
[code]--------------------------------------------------------------------------------
Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf); Compatible with FAST v7.0.
False Echo - Echo input data to “echo.out” (flag)
1 AnalMode - Analysis mode {1: Run a time-marching simulation, 2: create a periodic linearized model} (switch)
630.0 TMax - Total run time (s)
0.001 DT - Integration time step (s)
0 YCMode - Yaw control mode {0: none, 1: user-defined from routine UserYawCont, 2: user-defined from Simulink} (switch)
0 PCMode - Pitch control mode {0: none, 1: user-defined from routine PitchCntrl, 2: user-defined from Simulink} (switch)
2 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 2: user-defined from routine UserVSCont, 3: user-defined from Simulink} (switch)
9999.9 TimGenOn - Time to turn on the generator for a startup (s) [used only when GenTiStr=True]
1 HSSBrMode - HSS brake model {1: simple, 2: user-defined from routine UserHSSBr} (switch)
9999.9 TiDynBrk - Time to initiate deployment of the dynamic generator brake [CURRENTLY IGNORED] (s)
9999.9 TTpBrDp(1) - Time to initiate deployment of tip brake 1 (s)
9999.9 TTpBrDp(2) - Time to initiate deployment of tip brake 2 (s)
9999.9 TTpBrDp(3) - Time to initiate deployment of tip brake 3 (s) [unused for 2 blades]
9999.9 TBDepISp(1) - Deployment-initiation speed for the tip brake on blade 1 (rpm)
9999.9 TBDepISp(2) - Deployment-initiation speed for the tip brake on blade 2 (rpm)
9999.9 TBDepISp(3) - Deployment-initiation speed for the tip brake on blade 3 (rpm) [unused for 2 blades]
9999.9 TYawManE - Time at which override yaw maneuver reaches final yaw angle (s)
60 NacYawF - Final yaw angle for override yaw maneuvers (degrees)
9999.9 TPitManE(1) - Time at which override pitch maneuver for blade 1 reaches final pitch (s)
9999.9 TPitManE(2) - Time at which override pitch maneuver for blade 2 reaches final pitch (s)
9999.9 TPitManE(3) - Time at which override pitch maneuver for blade 3 reaches final pitch (s) [unused for 2 blades]
0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
True YawDOF - Yaw DOF (flag)
0.0 RotSpeed - Initial or fixed rotor speed (rpm)
60 NacYaw - Initial or fixed nacelle-yaw angle (degrees)
63.0 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.01910 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5.0 ShftTilt - Rotor shaft tilt angle (degrees)
240.00E3 NacMass - Nacelle mass (kg)
56.78E3 HubMass - Hub mass (kg)
0.0 TipMass(1) - Tip-brake mass, blade 1 (kg)
0.0 TipMass(2) - Tip-brake mass, blade 2 (kg)
0.0 TipMass(3) - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
2607.89E3 NacYIner - Nacelle inertia about yaw axis (kg m^2)
115.926E3 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
60.0 GBoxEff - Gearbox efficiency (%)
97.0 GBRatio - Gearbox ratio (-)
28.1162E3 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
“Dummy” DynBrkFi - File containing a mech-gen-torque vs HSS-speed curve for a dynamic brake [CURRENTLY IGNORED] (quoted string)
867.637E6 DTTorSpr - Drivetrain torsional spring (N-m/rad)
6.215E6 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
2 PtfmModel - Platform model {0: none, 1: onshore, 2: fixed bottom offshore, 3: floating offshore} (switch)
“DLC6.2-yaw=60-Angle=0_1-Platform_Fixed.dat” PtfmFile - Name of file containing platform properties (quoted string) [unused when PtfmModel=0]
108 TwrNodes - Number of tower nodes used for analysis (-)
“NRELOffshrBsline5MW_Tower_Monopile_RF_Fixed.dat” TwrFile - Name of file containing tower properties (quoted string)
9028.32E6 YawSpr - Nacelle-yaw spring constant (N-m/rad)
19.16E6 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
60 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
“Dummy” FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
0.0 TBDrConN - Tip-brake drag constant during normal operation, CdArea (m^2)
0.0 TBDrConD - Tip-brake drag constant during fully-deployed operation, CdArea (m^2)
0.0 TpBrDT - Time for tip-brake to reach full deployment once released (sec)
“NRELOffshrBsline5MW_Blade.dat” BldFile(1) - Name of file containing properties for blade 1 (quoted string)
“NRELOffshrBsline5MW_Blade.dat” BldFile(2) - Name of file containing properties for blade 2 (quoted string)
“NRELOffshrBsline5MW_Blade.dat” BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
“DLC6.2-yaw=60-Angle=0_1-AeroDyn_Fixed.ipt” ADFile - Name of file containing AeroDyn input parameters (quoted string)
“Dummy” NoiseFile - Name of file containing aerodynamic noise input parameters (quoted string) [used only when CompNoise=True]
“NRELOffshrBsline5MW_ADAMSSpecific.dat” ADAMSFile - Name of file containing ADAMS-specific input parameters (quoted string) [unused when ADAMSPrep=1]
“NRELOffshrBsline5MW_Linear.dat” LinFile - Name of file containing FAST linearization parameters (quoted string) [unused when AnalMode=1]
True SumPrint - Print summary data to “.fsm” (flag)
1 OutFileFmt - Format for tabular (time-marching) output files (1: text file[.out], 2: Binary file [.outb], 3: both) (switch)
True TabDelim - Generate a tab-delimited tabular output file. (flag)
“ES10.3E2” OutFmt - Format used for tabular output except time. Resulting field should be 10 characters. (quoted string) [not checked for validity!]
30.0 TStart - Time to begin tabular output (s)
50 DecFact - Decimation factor for tabular output {1: output every time step} (-)
1.0 SttsTime - Amount of time between screen status messages (sec)
9 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
1,21,41,51,61,71,81,91,108 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
0 NBlGages - Number of blade nodes that have strain gages for output [0 to 9] (-)
5,9,13 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
OutList - The next line(s) contains a list of output parameters. See OutList.txt for a listing of available output channels, (-)
“WindVxi , WindVyi , WindVzi” - Longitudinal, lateral, and vertical wind speeds
“WaveElev” - Wave elevation at the platform reference point
“RotSpeed , GenSpeed” - Low-speed shaft and high-speed shaft speeds
“TTDspFA , TTDspSS” - Tower fore-aft and side-to-side displacements
“PtchPMzc1, PtchPMzc2, PtchPMzc3” - Pitch angle
“TwrBsFxt , TwrBsFyt , TwrBsFzt” - Fore-aft shear, side-to-side shear, and vertical forces at the mudline
“TwrBsMxt , TwrBsMyt , TwrBsMzt” - Side-to-side bending, fore-aft bending, and yaw moments at the mudline
“PtfmSurge, PtfmSway , PtfmRoll , PtfmPitch” - Platform surge, sway, roll, and pitch displacements (for use in calculating in Crunch the tower-top displacements in the inertia frame)
“YawBrFxp , YawBrFyp , YawBrFzp” - Fore-aft shear, side-to-side shear, and vertical forces at the top of the tower (not rotating with nacelle yaw)
“YawBrMxp , YawBrMyp , YawBrMzp” - Side-to-side bending, fore-aft bending, and yaw moments at the top of the tower (not rotating with nacelle yaw)
“TwHt1FLxt, TwHt1MLyt, TwHt1TDxt” - Local side-to-side and fore-aft bending moments at tower gage
“TwHt2FLxt, TwHt2MLyt, TwHt2TDxt”
“TwHt3FLxt, TwHt3MLyt, TwHt3TDxt”
“TwHt4FLxt, TwHt4MLyt, TwHt4TDxt”
“TwHt5FLxt, TwHt5MLyt, TwHt5TDxt”
“TwHt6FLxt, TwHt6MLyt, TwHt6TDxt”
“TwHt7FLxt, TwHt7MLyt, TwHt7TDxt”
“TwHt8FLxt, TwHt8MLyt, TwHt8TDxt”
“TwHt9FLxt, TwHt9MLyt, TwHt9TDxt”
“RootFxb1, RootFyb1, RootMxb1,RootMyb1” -flapwise/edgewise force or moment at blade root
“YawPzn” -Nacelle yaw angle (deg)
END of FAST input file (the word “END” must appear in the first 3 columns of this last line).
[/code]
