Digital Control Implementation using FAST
Hello, i am new in using FAST so need some clearance on some topics. i hope i could get some guidance from the forum
I am implementing digital control in simulink using FAST NREL 5MW Onshore wind turbine. Given DT=0.005sec(which is my sampling time Ts as well) do i have to sample the outputs y[k] further coming from turbine in order to apply to my digital controller as controlled variables using a sampling time Ts? Actually i am confused in the inputs and outputs of the plant. Are they digital if DT=Ts or i do have to use A/D further.
Thankx in advance
Dear Mahum,
I’m not sure I really understand your question, but the FAST S-Function block essentially treats the wind turbine as a discrete-time system based on a time step of DT.
Thankx alot…this was the info i was looking for
