Dear Dr. Jonkman,
I aim to run a simulation on the OC4 DeepCWind Semi Submersible model, by including ice loads on the floating substructure. Current forces would be desirable too to account for the mooring system, even though IceDyn does not run when HydroDyn is activated (nevertheless, this is not a requirement at this point). However, it is my understanding that the IceDyn module is designed to simulate ice loads on fixed-bottom structures (as explicitly stated in the IceDyn site). Furthermore, it is clear that IceDyn does not run
Is there any suggestion on how to go about running such simulation? id est, to couple the ice loads on that floating model? Will this option be implemented in the future?
I thank you beforehand for your input on this.
