Hello everyone,
I’m new to OpenFast and i was wondering if OpenFast :
1- Can do calculation in frequency domain ? In other words, OpenFast output can be a stress PSD ?
2- Is it possible to replace TMDs built in OpenFast by other types ? Also, is it possible to change the position of the TMD ? If yes, does it require a lot of coding ?
Thank you in advance
Dear @Jason.Jonkman ,
Thank you for your reply.
I have input files compatible with OpenFast v2.1 and i’m usin these same files for OpenFast v3.0
Obviously, i’m gettin error.
Is there any solution for updating the file maybe ?
Thank u in advance,
Best Regards
Dear @Riad.Elhamoud,
The online readthedocs documentation describes the changes to the input files between each version of OpenFAST: 4.1.2. API changes between versions — OpenFAST v3.3.0 documentation.
If you use MATLAB, the MATLAB Toolbox have scripts to aid in upgrading input files from old to new versions: matlab-toolbox/ConvertFASTversions at main · OpenFAST/matlab-toolbox · GitHub. I don’t see that these have been updated in a while, but the functionality is generally applicable and may help you get automate the process a bit.
Thank u for your reply.
I will try this toolbox. Frankly, i took input files for OC3 Hywind for example and i managed to change all parameters.
But i obtained an error. I didn’t know how to fix it. Here is the error i obtained:
Running ElastoDyn.
FAST_InitializeAll:ED_Init:ED_ReadInput:ReadPrimaryFile:Invalid numerical input for file
“.\WINDCRETE_GC_IEA-15-240-RWT_ElastoDyn-Copy.dat” occurred while trying to read BldGagNd.
** OpenFAST encountered an error during module initialization.**
** Simulation error level: FATAL ERROR**
** Aborting OpenFAST.**
I tried to put BldGagNd to zero but always i’m gettin the same error.
BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
My guess is that you have formatting error elsewhere in the file. As with any input file formatting issue, I would suggest enabling the Echo option to debug.
