Can Elastodyn directly consider hydrodynamic loads
I am confused whether Elastodyn can directly consider hydrodynamic loads?
For offshore turbine fixed by monopile, I know we can use Subdyn to model monopile and tower modelled in Elastodyn can be mounted on monoplie. And Subdyn can consider hydrodynamic loads through mapping.
But I guess I can use Elastodyn to model the combination of tower and monopile if I know the combination’s mode shape. But I am not sure whether the hydrodynamic loads in Hydrodyn can be correctly mapped to Elastodyn.
The reason I want to only use Elastodyn is because:
  1. Elastodyn is more efficient than Subdyn.
  2. The damping definitions are different between Elasotdyn and Subdyn. Elastodyn adopts critical damping ratio. While Subdyn uses a combination of CB damping and Rayleigh damping. I want to avoid using different damping.
Ran
Dear @Ran.Tu,
Neither FAST v8 nor OpenFAST support a mesh-mapping between the tower of ElastoDyn and HydoDyn. So, without changing the source code, if you want the hydrodynamic loads to be applied to a flexible substructure, you must enable and represent the substructure in SubDyn.
Thank you Jason,
Now I am simulating offshore fixed wind turbine supporting by monopile. When I use Subdyn to simulate monopile, the time increment in .fst file should decrease to 0.000625 to avoid divergence. For all modules (including Aerodyn15, servodyn, elastodyn), I used the default time increment (identical to 0.000625). It took a lot of time to complete the simulation as such small time increment was adopted.
  1. So I am wondering if there are some skills which could speed up the calculation?
  2. What is the linear algebra solver adopted by OpenFAST? I know there are some open source linear algebra packages, i.e. lapack, Eigen, PETSc and Trilinos, which are powerful and can be introduced into OpenFAST. It seems that Map++ has adopted lapack. But I am not sure whether other modules also adopt some efficient linear algebra solvers.
    update: After roughly looking at Subdyn source code, I found Subdyn also adopts lapack
Ran
Dear @Ran.Tu,
The time step you are using seems quite small. How did you determine that this time step is needed? How many Craig-Bampton modes have you enabled in SubDyn and what is the highest Craig-Bampton mode frequency? Some guidance for setting up an offshore model in OpenFAST with SubDyn enabled are given here:
Regarding linear algebra solvers, this likely depends on which module you are asking about, but I agree that LAPACK is likely the most frequently used.
Dear Jason:
I modelled a 30m long monopile in Subdyn. The outer diameter of the monopile is 6m, and the thickness is 0.06m. The monopile is splited into 3 members. And each member is further divided into 3 elements. Timoshenko beam is adopted. Below is my damping:
             3   FEMMod      - FEM switch: element model in the FEM. [1= Euler-Bernoulli(E-B);  2=Tapered E-B (unavailable);  3= 2-node Timoshenko;  4= 2-node tapered Timoshenko (unavailable)]
             3   NDiv        - Number of sub-elements per member
True             CBMod       - [T/F] If True perform C-B reduction, else full FEM dofs will be retained. If True, select Nmodes to retain in C-B reduced system.
             4   Nmodes      - Number of internal modes to retain (ignored if CBMod=False). If Nmodes=0 --> Guyan Reduction.
             1   JDampings   - Damping Ratios for each retained mode (% of critical) If Nmodes>0, list Nmodes structural damping ratios for each retained mode (% of critical), or a single damping ratio to be applied to all retained modes. (last entered value will be used for all remaining modes).
             1   GuyanDampMod - Guyan damping {0=none, 1=Rayleigh Damping, 2=user specified 6x6 matrix}
  0.000, 0.010   RayleighDamp - Mass and stiffness proportional damping  coefficients (Rayleigh Damping) [only if GuyanDampMod=1]
             6   GuyanDampSize - Guyan damping matrix (6x6) [only if GuyanDampMod=2]
   0.0000e+00   0.0000e+00   0.0000e+00   0.0000e+00   0.0000e+00   0.0000e+00
   0.0000e+00   0.0000e+00   1.4625e+06   0.0000e+00   0.0000e+00   0.0000e+00
After running simulation, I got below information:
Running SubDyn.
   Fixed bottom case detected
   Performing Craig-Bampton reduction 60 DOFs -> 4 modes + 6 DOFs
   Using static improvement method for gravity and ext. loads
   SubDyn recommended dt: 0.00090 - Current dt: 0.00063 - Max frequency:   55.764
   Calculating Full System Modes for output files
   Exporting Summary file
As you can see, the recommended dt = 0.00090. So I choose 0.000625 to avoid divergency. Below is some subdyn infomation. Hope it can reflect something…
#Eigenfrequencies [Hz] for full system, with reaction constraints (+ Soil K/M + SoilDyn K0)
Full_frequencies: # 1 x 54
  - [   6.319104E+00,   6.319104E+00,   2.676944E+01,   2.946952E+01,   2.946952E+01,   4.315620E+01,   6.096864E+01,   6.096864E+01,   8.112554E+01,   8.678901E+01,   8.678901E+01,   1.060086E+02,   1.060086E+02,   1.191718E+02,   1.191718E+02,   1.279464E+02,   1.279464E+02,   1.307861E+02,   1.334173E+02,   1.334173E+02,   1.364113E+02,   1.364113E+02,   1.379490E+02,   1.988829E+02,   2.223937E+02,   2.653209E+02,   3.206279E+02,   3.375798E+02,   3.756434E+02,   3.756434E+02,   4.128127E+02,   4.277356E+02,   4.380972E+02,   4.380972E+02,   4.813307E+02,   5.227480E+02,   5.227480E+02,   5.246536E+02,   5.442274E+02,   6.008514E+02,   6.008514E+02,   6.628179E+02,   6.628179E+02,   6.655137E+02,   7.081735E+02,   7.081735E+02,   7.391388E+02,   7.391388E+02,   7.578514E+02,   7.578514E+02,   7.759746E+02,   7.764889E+02,   7.764889E+02,   8.458174E+02,]
#Frequencies of Guyan modes [Hz]
GY_frequencies: # 1 x 6
  - [   6.391218E+00,   6.391218E+00,   2.948010E+01,   4.752618E+01,   5.409784E+01,   5.409784E+01,]
#Frequencies of Craig-Bampton modes [Hz]
CB_frequencies: # 1 x 4
  - [   2.778162E+01,   2.778162E+01,   5.374285E+01,   5.576394E+01,]
Update:
In Subdyn theory, I found:
Until full-system linearization is made available, experience has shown that it is sufficient to enable all C-B modes up to 10 Hz (the natural frequencies of the C-B modes are written to the SubDyn summary file)
I do not fully understand. But for my model, the lowest frequency of C-B frequency is 27.78 Hz which is larger than 10 Hz. Does it mean there is no need to retain 4 modes? But how many modes should I retain?
Ran
Dear @Ran.Tu,
Our recommended rule of thumb for choosing the time step is DT = 1/(10 * fmax), where fmax is the highest natural frequency of the model in Hz. In your case, this would be DT = 1/10*55.76 Hz ) = 0.0017 s. (I’m not fully sure why SubDyn recommends using half this value). Regardless, I would think 0.000625 s would be plenty small, assuming you don’t have much higher frequencies in ElastoDyn. Have you applied 1 correction step (NumCrctn = 1 in the OpenFAST primary input file), which is often required when enabling SubDyn per the modeling guidance I linked to above?
Regardless, I agree with the SubDyn documentation recommendation of keeping only the lowest-frequency Craig-Bampton, less than 10 Hz. In your case, it means you should be able get by without any Craig-Bampton modes, Nmodes = 0 in SubDyn, which means that you’ll likely be able to increase the time step quite a bit.
Thank you Jason.
  1. For NumCrctn, I have tried 0 and 1. All the results except reaction force in z axis does not change. Does NumCrctn refer to SIM? After reading Subdyn theory, I found SIM ( Static-Improvement Method) will influence the calculation of gravity and bouyancy.
I checked the Subdyn modeling consideration. And I found for the RK4 and ABM4 methods, DT = 1/(10 * fmax). But for the AB4 method, the recommended time step is half DT. Weird thing is I have chose ABM4. As you can see below:
False            Echo        - Echo input data to "<rootname>.SD.ech" (flag)
"DEFAULT"        SDdeltaT    - Local Integration Step. If "default", the glue-code integration step will be used.
             3   IntMethod   - Integration Method [1/2/3/4 = RK4/AB4/ABM4/AM2].
True             SttcSolve   - Solve dynamics about static equilibrium point
False            GuyanLoadCorrection - Include extra moment from lever arm at interface and rotate FEM for floating.
After reading more of Subdyn modeling consideration, I get some questions:
3. It said:
however, for tubular towers, the structural model in ElastoDyn tends to be more accurate because ElastoDyn considers geometric nonlinearities not treated in SubDyn.
I am confused by “geometric nonlinearities” of Elastodyn. Here do you mean P-delta effect? In my understanding, P-delta effect will lead to extra moment because of the offset between undeflected position and deflected position. But according to subdyn theory, P-delta effect can be accounted by enabling GuyanLoadCorrection.
  1. It said:
    If FAST is run with SubDyn but not HydroDyn, the water depth will be automatically set to 0 m. This will influence the calculation of the reaction loads. Reactions are always provided at the assumed mudline, therefore, they would not be correctly located for an offshore turbine as a result.
My understanding is still water level is always located at z = 0. If Hydrodyn is turned off, the water depth will be automatically set to 0 m. That is to say, mudline is located at z = 0 ( the same with still water level). And OpenFAST always assumes reaction force located at mudline (z = 0). But if I set reaction point at z=-20 in Subdyn file, this discrepancy (I manually set z of reaction point = -20, but OpenFAST assume z of reaction point = 0) will lead to incorrect calculation.
In Subdyn summary file, I get Mbbt and Kbbt. Does Mbbt and Kbbt refer to MBB and KBB respectively shown in above figure?
Der @Ran.Tu,
Here are my responses:
  1. No, I was referring to the number of correction steps (NumCrctn) specified in the OpenFAST primary input file, which is independent of the static improvement method (SIM) within SubDyn. The OpenFAST glue code implements a loose-coupling approach based on a predictor-corrector formulation, with NumCrctn determining the number of correction steps. For most models with SubDyn enabled, we typically recommend setting NumCrctn = 1.
  2. Looking at the SubDyn source code, I see that the “SubDyn recommended dt” is calculated as 1/(20 * freq_max), regardless of the integrator specified. I would have expected this to be 1/(10 * freq_max). Regardless, it is in the ballpark.
  3. The P-delta effect is one term. The other term is the “axial shortening” of the tower–that is, the downwards deflection of the tower associated with transverse deflection because the tower does not stretch when deflected transversely. This effect is important for gravitational destiffening associated with large tower-top mass. (For blades, this effect is important for centrifugal stiffening). This term is accounted for in ElastoDyn, but not SubDyn. Despite ElastoDyn using mode shapes as shape functions, ElastoDyn does consider several geometric nonlinear terms that improve its accuracy for small and moderate deflections relative to what a purely linear model would calculate.
  4. This statement from the SubDyn manual is just a warning regarding how to interpret the reaction load write outputs from SubDyn (ReactMxss, etc.) when HydroDyn is disabled for an offshore wind turbine. Please note that as of OpenFAST v3.1 and newer, however, the WtrDpth is now specified in the OpenFAST primary input file, and so, can be set nonzero even when HydroDyn is disabled. So, I’m not sure this statement from the SubDyn manual is really valid anymore for newer versions of OpenFAST.
  5. Yes, except that the “t” in the names (Mbbt and Kbbt) refer to the versions of M_BB and K_BB with a tilde, i.e., after the boundary constraints are applied (see: 4.2.5.6. SubDyn Theory — OpenFAST v3.3.0 documentation).
Thank you Jason for the explanation,
Now I am studying the subdyn source code. And I arise two questions during reading the code.
  1. In FEM.f90, subroutine ElemK_Beam and ElemM_Beam calculate beam element mass matrix and beam element stiffness matrix respectively. They both depends on directional cosine matrix. During simulation, elements will diplace/deform, and can change directional cosine matrix, leading to a change of both beam element mass matrix and beam element stiffness matrix. So I am curious that will beam element mass matrix and beam element stiffness matrix be updated during simulation? Even for the lumped forces and moments due to gravity, will it be updated?
  2. In SD_FEM.f90, I found Subdyn can consider both SSI matrix and soil matrix. I know SSI matrix is inputted for reaction point. But I don’t find where soil matrix (it is called Init%Soil_K in code) is inputted in subdyn primary file.
Dear @Ran.Tu,
Regarding (1), what you describe is a geometric nonlinear effect (the deflection impacting the mass and stiffness matrices) not considered in SubDyn.
Regarding (2), Soil_K is an initialization input to SubDyn, i.e., an input defined by the calling program. When SubDyn is coupled to OpenFAST, Soil_K is set by OpenFAST (and is not currently set in OpenFAST v3.2). Once the SoilDyn pull request is merged in (SoilDyn -- soil dynamics module by andrew-platt · Pull Request #986 · OpenFAST/openfast · GitHub), Soil_K will be an initialization output of SoilDyn and transferred as an initialization input to SubDyn through the OpenFAST glue code.
Dear @Jason.Jonkman ,
I am currently studying the primary input file of SubDyn in OpenFAST (v3.5.3). After reading through this forum, I still have a few questions regarding certain parameters, as listed below:
  1. The “geometric nonlinearities” of ElastoDyn include the “P-delta” effect and “axial shortening”, as you stated in this forum in September 2022. In contrast, SubDyn’s “GuyanLoadCorrection” refers only to the “P-delta” effect.
  2. The functions “GuyanLoadCorrection” and “Guyan Reduction” are independent of each other. When GuyanLoadCorrection = true, Guyan Reduction may be either true or false; when NModes = 0, Guyan Reduction is performed.
  3. Section 6.5.5 “Static-Improvement Method” of the SubDyn User’s Guide and Theory Manual is always executed and has no control switch.
Dear @Yangyang.Li,
Here are my responses.
  1. I agree.
  2. I disagree. SubDyn always performs a reduction of the full FEA formulation, which decomposes the FEA degrees of freedom (DOFs) into Guyan modes (those associated with motion of the interface joint), internal Craig-Bampton modes (with the interface joint fixed), and internal static modes. Whether the DOFs associated with the Guyan modes are enabled is determined by the ElastoDyn platform DOFs. The number of Craig-Bampton modes is determined by NModes.
  3. I disagree. The static modes are enabled by setting SttcSolve = TRUE.
FYI: The GuyanLoadCorrection input was removed from the SubDyn input file as of OpenFAST v4.0 and is now always TRUE by default.
Thank you for your prompt responses. I still have some questions based on the SubDyn User’s Guide and Theory Manual, and I am not sure whether my understanding is correct:
  1. Internal static modes refer to the interface-node modes calculated using Equation (30) on page 44, while Guyan modes and Craig–Bampton modes correspond to Φ_R and Φ^m in Equation (25) on page 43. These are based on the 3 modal components of the FEA decomposition in SubDyn, as you explained.
  2. The first 8 CB_frequencies (Hz) and my inferred mode directions are listed in the table below with Nmodes = 8. Here, x1 and y1 refer to the first-order translational modes in the x and y directions, respectively, while z1 refers to the torsional mode. In this case, displacements induced by modes higher than the 3rd order are neglected in the x/y directions (only 3 modes are considered), and displacements induced by modes higher than the 2nd order are neglected in the z direction (only 2 modes are considered). The case corresponds to Test #21: NREL 5.0 MW Baseline Offshore Turbine with OC4 Jacket.
Dear @Yangyang.Li,
Regarding (1), I disagree. The static modes are the modes not accounted for in the Guyan and Craig-Bampton modes and are only represented statically within SubDyn. If there are N total FEA DOFs, 6 of which are Guyan modes and NModes of which are Craig-Bampton modes, then there will be N - 6 - NModes static modes in the system. The details are explained in the SubDyn documentation on readthedocs here: 4.7.6. SubDyn Theory — OpenFAST v4.1.2 documentation (which is updated a bit from the originally published SubDyn User’s Guide and Theory Manual).
Regarding (2), I have not checked your model interpretation and you haven’t explained how you interpreted the mode shapes. It would be easiest to to do this by visualizing the Craig-Bampton modes via Emmanuel Branlard’s vis3Danim tool: Mode shape visualization.
Thank you for your prompt responses. I still have some questions as follows.
I assume the mode directions of the frequencies as shown in the table below, rather than relying on my own inference. From this, it can be concluded that displacements induced by modes higher than the third order are neglected in the x/y directions (in practice only three modes are considered), while those induced by modes higher than the second order are neglected in the z direction (in practiceonly two modes are considered). The notation used in the table and the case analyzed are the same as stated in my previous question.
Dear @Yangyang.Li,
You don’t need to assume the mode directions as these can be determined, made easy through the vis3Danim tool I linked to above.
Dear @Jason.Jonkman
Thank you for your prompt responses. Using Emmanuel Branlard’s viz3Danim tool, the inferred mode directions of the frequencies are approximately as shown in the table below (since this is based on 3D visualization, the inference may not be entirely correct, so please disregard it if inaccurate). My main concern is the following questions, and I am not sure whether my understanding is correct:
In this case, it can be concluded that displacements induced by modes higher than the third order are neglected in the x/y directions (in practice, only three modes are considered), while those induced by modes higher than the second order are neglected in the z direction (only two modes are considered). The notation in the table and the case analyzed are the same as before.
Dear @Yangyang.Li,
Can you share your .json file so that I can confirm your interpretation of the CB modes?
Thank you for your prompt responses. The .json file can be accessed via the following Google Drive link: https://drive.google.com/file/d/1UCun04ObipZDG0B6ETpqFO2ibeDxZvpJ/view?usp=sharing
. The case corresponds to Test #21: the NREL 5.0 MW Baseline Offshore Turbine with an OC4 Jacket with the structural parameters left unmodified.
PS: I would, however, prefer that you focus on my previous question regarding the possible conclusion that higher-order modes may have been neglected.
Dear @Yangyang.Li,
Thanks for sharing your .json file. By reviewing this file, I agree with your interpretation of C-B modes 1 and 2, but disagree with the others. C-B modes 3, 4, and 6 appear to be internal bulging modes, mode 5 appears to be internal twisting, and modes 7-8 correspond to the second bending modes in x and y.
So, I disagree with your language about which modes are considered and neglected, but your idea is correct in that modes not enabled are neglected in the C-B solution. That said, the higher modes can still be considered statically if you’ve set SttcSolve = TRUE in SubDyn.
