Dear Jonkman & Buhl,
Thanks you for activating my account.
I want to get natural frequencies using FAST. As a test case I am using Test14 (FAST certification Test #14: WindPACT 1.5 MW Baseline with many DOFs and system linearization). I have few queries.
1.In Campbell Diagram.xls, I want to plot natural frequencies wrt speed. However I am not getting the relation between 1st sheet (Campbell Diagram) & 2nd sheet (0 rpm). I have attached the CampbellDiagram_24May_Test14.xls file for your ready reference. I want to know the locations in the 2nd sheet from where the values are to be given in the 1st sheet (The assumed sequence is given in 1st sheet based on some other test cases; however couldn’t found the commonality).
2.The damping value which I am getting is very low. Just want to know whether by changing the files of tower & blade to Baseline_Tower.dat & Baseline_Blade.dat in Test14.fst will serve the purpose?
3.I am assuming that by running the default Test14.fst (National Wind Technology Center's Information Portal | Wind Research | NREL), the output I am getting is at 0 rpm. Just want to know how to get results for varying speeds.
4. The CalcStdy is by default False. For my purpose is it right? Also advice for any other change in the default Test14.fst (National Wind Technology Center's Information Portal | Wind Research | NREL),which I am using to calculate natural frequencies.
I would appreciate your help.
Tejas
CampbellDiagram_24May_Test14.xls (273 KB)
Dear Tejas,
The CampbellDiagram.xls workbook does not automate the generation of the Campbell diagram. There is no direct link between the “CampbellDiagram” worksheet and the other sheets. Instead, to generate the CampbellDiagram, you should linearize FAST about many different rotor speeds, analyze each rotor speed in a separate worksheet, than manually copy (or link) the natural freqeuncies to the CampbellDiagram worksheet.
Test14 from the FAST Certest was developed as a quite a simple linearization without structural damping, without gravity, without a spinning rotor, and without aerodynamics. You can certainly add these effects through augmentation of the input files. Please see for the FAST User’s Guide for information on how to set up FAST for different operational conditions.
If you are not certain that the initial conditions you’ve set result in a model that is in equilibrium, you should CalcStdy to True to ensure that FAST calculates a proper equilibrium position to linearize about.
Thanks for the quick reply.
The part I am strugling is to find “manually copy (or link) the natural freqeuncies to the CampbellDiagram”. Not getting the locations in the 2nd sheet from where the values are to be given in the 1st sheet. I have attached the CampbellDiagram_24May_Test14.xls file for your ready reference.
Tejas
Dear Tejas,
The first mode in the “0 RPM” worksheet is the 1st tower side-to-side bending mode, so, you’d take this mode’s natural frequency (0.4094 Hz) and enter it into the corresponding element of the table on the “CampbellDiagram” worksheet. Repeat for all the modes for all desired rotor speeds.
Thanks for the quick reply again.Actualy, I want to know the natural frequency of Drive train.
To my understanding, the maximum mode shape magnitude decides the natural frequency. For example, in the attached “CampbellDiagram_24May_Test14.xls sheet 0 RPM”, for 1st tower fore-aft bending mode, the mode shape magnitude is maximum for 2nd mode, hence the natural frequency of the tower fore-aft bending is 0.4099 Hz (2nd mode).
Likewise, I have tabulated below the natural frequencies for all 8 modes given in CampbellDiagram. Please let me know whether my understanding is right?
Natural Frequencies (Hz)
1st Tower FA 0.4099213
1st Tower SS 0.4093595
1st Blade Flap (collective) 1.2582042
1st Blade Edge (collective) 1.8822899
1st Drivetrain 18.4578402
2nd Tower FA 2.8704495
2nd Tower SS 3.1030379
2nd Blade Flap (collective) 3.8814336
Tejas
Dear Tejas,
I agree with your intrepretation of all of the modes except for the 1st blade edge (collective), which I would interpret as 1.706 Hz, and the 2nd blade flap (collective), which I would interpret as 3.784 Hz. Please see my May 16, 2011 post in the forum topic found here for a description on how the MBC3 script changes the mode descriptions for the blades (from individual blades to collective/cosine/sine): Eigenanalysis FAST.
Thanks a lot for the quick reply again. The explaination certianly helps.
With Regards,
Tejas
I have a question about Campbell diagram.
Does Natural Frequency vary with Rotor Speed or it keep constant ?
Can I revise the rotor speed in my .fst file and then through MBC3 output to campbell diagram If it vary with Rotor Speed?
Is it correct?
Jason. Lai
Yes, the rotor speed can influence the natural frequencies of a wind turbine. The rotor speed likely has a strong influence on the blade natural frequences (flap and edge bending) and less influence on the support structure frequencies.
The process for calculating natural frequencies at different rotor speeds using FAST/MBC3 and plotting the Campbell diagram is discussed in the posts of this forum topic above.
I am trying to get the natural frequencies of the tower and blade. So I started with linearization analysis with FAST V7 and post process the results with MBC & CampbellDiagram.xls. I linearized FAST at different rotor speed (0 -10 RPM), analyze them and got the Campbell Diagram. I found something strange at RPM=4 for my model: second Tower FA natural frequency dropped down dramatically at 4 RPM. I checked the inputs for CampbellDiagram at 4 RPM and found the following:
At 4 RPM, the order of the index number for MBC_ModeShapeMagnitude changed. For other rotor speeds, the order is 48 47 46 45 … 38 37 36 35 (14 DOFs), but for 4 RPM, the order is 48 47 46 45 … 38 36 35 37. Does this order affect the result?
Just to confirm my understanding of the CampbellDiagram.xls. Here is how I find the natural frequency for each DOF: Find the cell with green background for each DOF (each row) .Then go up to find the natural frequency corresponding to the cell with green background in the same column, which is the natural frequency I used in my plot. e.g. at 4 RPM sheet in my attached excel file, the natural frequency for 2nd DOF ( Tower 1st SS) is 0.17667 Hz. Am I doing this in the right way?
Thanks very much!
jinsong
Dear Jinsong,
I tried to download the attachment from your post, but the download is blank; I don’t believe the file has been uploaded correctly. Can you reattach it? (I’m afraid I can’t answer your question without viewing the file.)
Thanks for your help!
I reattached the file in this post. Please try to download again to see if it works.
jinsong
CampbellDiagram.xls (1.26 MB)
Dear Jinsong,
The green background and red bold font in the worksheets are simply aids to help you interpret the results. Because a cell is highlighted green doesn’t guarantee that the corresponding column is the natural frequency for the given row. I see in your results at 4rpm that you’ve actually identified 0.18492 Hz as the natural frequency of both the 1st and 2nd tower fore-aft bending modes. However, this is not possible – both modes can’t have the same frequency. I would call the 0.18492-Hz mode at 4rpm the 1st tower fore-aft bending mode. I would call the 2.0851-Hz mode at 4rpm the 2nd tower fore-aft bending mode.
Please note that I see you’ve used the same frequency for multiple modes in other places in the spreadsheet. For example, at 0rpm, I see you’ve identified the 0.27128-Hz mode both as the drivetrain torsion and 1st blade edgewise bending mode, but I would call the 0.27128-Hz mode the drivetrain torsion mode and the 1st blade edgewise bending mode is at 0.63-0.64 Hz.
Thanks very much for your help with the Campbell Diagram. I think I got the idea how the excel works now. Really appreciate your help!
Jinsong
I am trying to plot the Campbell Diagram for the 15 MW IEA Semisubmersible test case using the CampbellDiagram excel workbook available within this forum. The MBC3 output data based on the linearization results (Please see attached linearization output file) were obtained using OpenFAST (v2.4.0) for 0-14 rpm following the same procedure described in “FAST modularization framework for wind turbine simulation: full-system linearization”, Torque 2016 paper. I have enabled all except the Teeter, DrTrain, and Generator DOFs. I can see that the natural frequencies for the platform DOFs are being nicely picked while the tower and blade DOFs are not rightly picked. I see the same columns (e.g.: K7 and M7 for 0 rpm ) are being picked for the tower and blade DOFS. Please see attached the CampbellDiagram excel workbook. Based on my understanding gained from the forum, I see the maximum values of the mode shape for both the rows and columns are useful in identifying the full system natural frequencies. But it is not very clear to me how to pick the natural frequencies as the maximum values of the mode shape for most of the rows (DOFs) pick the same column. I would like to know if there is anything wrong with the linearization results from OpenFAST or is it a postprocessing issue. Just for the information, I had no problem following this procedure in generating the Campbell Diagram for the 5MW Land-based and OC4 Semisubermisble cases.
Your help is highly appreciated.
CampbellDiagram.xlsm (550 KB)
15MW_Semi-0.1.lin.txt (109 KB)
Dear Srinivasa,
Well, I don’t have the time to process this spreadsheet for you. It certainly takes time and expertise to interpret the Eigenanalysis results, especially for coupled floating wind turbine models. If the full system is too difficult to interpret, I would suggest working up the complexity in steps, e.g., start with fewer DOFs enabled. Can you properly identify all modes with a fixed base? For the floating system, it may help to start with a rigid RNA (no yaw, drivetrain, or blade DOFs enabled) before enabling these flexibilities later. And ensure that your results at 0 rpm and no aerodynamics make sense before moving on to cases with rotor rotation and aerodynamics enabled.
Thanks for your reply. I provided the spreadsheet for the sake of supporting my query related to picking the full system frequencies when the maximum values of the modes shapes highlighted with green backgrounds refer to the same column (natural frequency). A similar question was asked in this forum (Eigenanalysis FAST) in the past. Although I do agree with your reply to this question, I do not understand how the phase values are being used in the spreadsheet to pick the right modes in case of a DOF belonging to a certain natural frequency when there are many mode shape magnitudes with green background. I thought the right mode for a DOF (say tower) is first picked by finding out the maximum value (green cell) along its row and then the value in the corresponding column gives the natural frequency. In case, if the several modes contain green cells pointing to the same column then I should look for the column with the maximum value (red cell) in the same row as the DOF. But this seems not always true. Please let me know if this is true.
I do agree it certainly takes time and expertise to interpret the Eigenanalysis results and as a non-expert, I am trying to learn the techniques followed in this community from the discussions here in the forum. I understand how linearization and MBC transformation are used to compute the full-system natural frequencies, mode shape vectors, and damping ratios for offshore wind turbines as nicely described here (FAST Modularization Framework for Wind Turbine Simulation: Full-System Linearization and User’s Guide to MBC3) but nowhere I found information on the procedure used in the spreadsheet. It would be really helpful if you can refer to any report/article where I can find technical information related to this procedure.
In fact, I have already tried linearization i) for the tower only DOFs with all other DOFs disabled, ii) for the tower, blades only DOFs enabled without any aerodynamics and rotor rotation. In the first case, I can see the spreadsheet is able to pick the right modes as there are only 4 dofs. However, for the second case, I see the spreadsheet is not picking up the right modes. Moreover, I cannot rely on the first case results to identify the modes for the second case as the mode magnitudes for the tower changes. I do have some idea about the values of the natural frequencies for the 1st tower modes and platform DOFs based on my simulations run using BModes and white-noise excitation PSDs. The problem is in picking the modes for the blades as their natural frequencies are closely spaced.
Dear Srinivasa,
We did not publish a report on how to use the CampbellDiagram spreadsheet. The green highlighting and red bold font are not guaranteed to pinpoint the correct mode, but they are there just to help focus your eyes on terms that are likely important for proper interpretation. For example, a tower fore-aft bending mode likely has a lot of blade-flapwise deflection, so, the red bold element need not be the tower mode. The simpler models are easier to interpret, and once you have a rough idea of the natural frequencies of key modes, the more sophisticated models are easier to interpret because some modes can be identified quickly.
The MBC scripts have recently been updated (available in the MATLAB toolbox: github.com/OpenFAST/matlab-toolbox) and the Excel spreadsheet is now automatically generated from MATLAB, eliminating the need for the old CampbellDiagram.xls spreadsheet, which required manual copying/pasting from MATLAB. In the new auto-generated spreadsheet, each eigenvector is normalized so that the maximum element is unity and with the DOF contributions to each mode sorted from largest to smallest (rather than green and red highlighting). This further helps with interpretation, but still requires skill and effort. OpenFAST v2.4 also now supports mode shape visualization (through the generation of VTK files), which also helps a lot with interpretation. Some documentation of this functionality is also available in the ReadMe file of the MATLAB Toolbox.
Thanks for the reply. If I understood you correctly the green/red bold fonts pinpoint pairs of tightly coupled DOFs. For example, if I know the 1st tower FA mode frequency apriori then I can use the green/red bold fonts to identify the 1st blade flapwise mode. Am I right?
I did use these MATLAB scripts for 5MW and 15MW semisubmersible cases but the interpretation of the modes still requires visual inspection as you pointed out. In fact, I posted a query (in June 2020) related to the mode identification using the MATLAB scripts (Question #1 for turbulence fields (points outside of field)) for the 5MW case, then you replied that manual interpretation is still needed.
To my knowledge, the features related to the automatic generation of excel spreadsheet and mode identification were previously available but not fully functional (at least in my case when I tried using them on Mac). I think the creation of Campbell_Summary file with information related to the coupled DOFs is a more recent update. However, it is confusing to use this information for mode picking. For example (see attached a screenshot of my Campbell_Summary file for the 15MW case), for 0 rpm the 8th DOF (with frequency=0.428Hz has last column " ED 1st FLAP cos - " while 1 rpm (frequency=0.428Hz) has the last column “ED 1st EDGE coll. - ED 2nd FLAP cos - ED 1st tower FA - ED 1st FLAP sin - ED Platform horizontal sway translation DOF - ED 1st FLAP coll.” It is not very clear to me how a mode with 0.428Hz shows different coupled DOFs contributions. This information for the same DOF is not consistent for higher rpm as well. Can you please explain how this can be possible?
Regards
Dear Srinivasa,
The green and red highlighting are just guides, but because a cell is highlighted doesn’t guarantee a specific mode.
I’m not familiar with a “Campbell_Summary” file, but this appears to be the operating point (OP) rather than the mode shapes. Instead, I would expect the auto-generated Excel spreadsheet to look something like the following:
