HI Jason,
yes, I can run the r-test: IEA_LB_RWT-AeroAcoustics without any issue.
That is why I am driving crazy:-)
Davide
HI Jason,
Davide
Dear Davide,
You could start with the model that is working and update it file-by-file (or line-by-line within a file, if needed) with the model data that is not working until you isolate the error.
Dear @Davide.DiPasquale
I saw your inquiry post in 2021 on the forum, and Iām sorry to bother you. I am currently doing research on the aerodynamic noise of wind turbines, using the code downloaded on GitHub from IEAL_LB-RWT AeroAcoustics. It calculates that the wind turbine used is 3.4MW, and I would like to use it in the analysis of an offshore semi-submersible 5MW wind turbine. After changing the file, I encountered a similar problem when running the program as you encountered at the time. May I ask if there is any good solution to this problem?
Looking forward to your reply.Thank you in advance!
