Tower strike while using the latest OpenFAST version in IEA 15MW model
Recently, I discovered that it is possible to compare the results of OpenFAST and Bladed on the IEA-15-240RWT benchmark. The documentation is available at IEA_15MW_240_RWT — NREL/turbine-models power curve archive 0 documentation, and the project repository is at GitHub - IEAWindSystems/IEA-15-240-RWT: 15MW reference wind turbine repository developed in conjunction with IEA Wind . With this in mind, I began my attempt. To avoid issues, I gradually enabled the computational modules one by one. Everything worked fine when I only set CompElast and CompInflow to 1. However, when I tried to further set CompAero to 2, OpenFAST reported an error and returned the following error log:
D:\LFC\IEA-15-240-RWT-master\OpenFAST\IEA-15-240-RWT-Monopile>openfast_x64.exe IEA-15-240-RWT-Monopile.fst
OpenFAST
Copyright (C) 2025 National Renewable Energy Laboratory
Copyright (C) 2025 Envision Energy USA LTD
OpenFAST-v4.1.2
Compile Info:
 - Compiler: Intel(R) Fortran Compiler 2021
 - Architecture: 64 bit
 - Precision: single
 - OpenMP: No
 - Date: Aug 06 2025
 - Time: 19:22:48
Execution Info:
 - Date: 12/29/2025
 - Time: 14:31:39+0800
OpenFAST input file heading:
    IEA 15 MW offshore reference model monopile configuration
 Running ElastoDyn.
 Running InflowWind.
 Running AeroDyn.
   AeroDyn: projMod: 1
   Projection: legacy (NoSweepPitchTwist), BEM: legacy (2D)
FAST_InitializeAll:ED_Init:ED_ReadInput:ReadBladeInputs:ReadBladeFile:The ElastoDyn Blade file,
.\../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat, DISTRIBUTED BLADE PROPERTIES table
contains the PitchAxis column.  This column is unused and will be removed in future releases
 Time: 0 of 300 seconds.
FAST_Solution:FAST_UpdateStates:FAST_AdvanceStates:AD_UpdateStates:BEMT_UpdateStates(node 1,
blade 1):ComputeTau:Rotor-averaged axial induction factor is greater than 0.5; limiting
time-varying tau1. This message will not be repeated though the condition may persist.
Warning: SkewedWakeCorrection encountered a large value of chi (90.343 deg), so the yaw
correction will be limited. This warning will not be repeated though the condition may persist.
See the AD chi output channels, and consider turning off the Pitt/Peters skew model (set
SkewMod=1) if this condition persists.
FAST_Solution:FAST_UpdateStates:CalcOutputs_And_SolveForInputs:SolveOption2:AD_CalcOutput:RotCalcO
utput:BEMT_CalcOutput(node 5, blade 3):UA_CalcOutput:UA_BlendSteady:Temporarily turning off UA
due to high angle of attack or low relative velocity. This warning will not be repeated though
utput:BEMT_CalcOutput(node 50, blade 2):UA_CalcOutput:Mach number exceeds 0.3. Theory is invalid.
FAST_Solution:FAST_UpdateStates:FAST_AdvanceStates:AD_UpdateStates:BEMT_UpdateStates:UpdatePhi(nod
e 7, blade 2):BEMT_UnCoupledSolve:There is no valid value of phi for these operating conditions:
Vx = 1.5731, Vy = -18.289, rlocal = 18.262, theta = 0.21681, geometric phi = 3.0558. This warning
will not be repeated though the condition may persist. (See GeomPhi output channel.)
FAST_Solution:FAST_UpdateStates:FAST_AdvanceStates:ED_ABM4:ED_CalcContStateDeriv:SetCoordSy:Small
angle assumption violated in SUBROUTINE SmllRotTrans() due to a large blade deflection (ElastoDyn
SetCoordSy). The solution may be inaccurate. Simulation continuing, but future warnings from
SmllRotTrans() will be suppressed.
 Additional debugging message from SUBROUTINE SmllRotTrans(): 6.665 s
ED_CalcContStateDeriv:SetCoordSy:Small angle assumption violated in SUBROUTINE SmllRotTrans() due
to a large blade deflection (ElastoDyn SetCoordSy). The solution may be inaccurate. Simulation
continuing, but future warnings from SmllRotTrans() will be suppressed.
 Time: 10 of 300 seconds.  Estimated final completion at 14:37:43 (in 0.004 days).
** WARNING: Tower strike. **  This warning will not be repeated though the condition may persist.
FAST_Solution:FAST_UpdateStates:FAST_AdvanceStates:AD_UpdateStates:SetInputs:SetDisturbedInflow:Tw
rInfl:Tower strike.
 OpenFAST encountered an error at simulation time 10.875 of 300 seconds.
 Aborting OpenFAST.
I don’t understand what caused this issue, because apart from disabling some modules in the FEATURE SWITCHES AND FLAGS section, I haven’t made any other changes. Everything else uses the default settings from the GitHub repository. From the error report, it seems that the blades might have experienced unstable vibrations at that point.
BTW: I tried this case in still air, but the Tower strike happened again.
All best wishes,
Xingyu
Dear @Xingyu.Liu,
From the messages that you shared, it looks like you are running a simulation with aerodynamics, but without wind turbine control through ServoDyn enabled. For such a set up, you’d need to disable the generator degree of freedom in ElastoDyn (GenDOF = FALSE) to avoid rotor overspeed that can trigger other simulation problems; have you done that?
Dear @Jason.Jonkman ,
Thank you for your quick reply! It worked after I set the GenDOF = FALSE. So then I tried to enable the ServoDyn. At first, I set Linearize = True, and the OpenFAST abort with the message followed:
OpenFAST
OpenFAST-v4.1.2
Compile Info:
 - Precision: single
 - OpenMP: No
 - Date: Aug 06 2025
 - Time: 19:22:48
Execution Info:
 - Date: 12/30/2025
 - Time: 10:13:40+0800
 Running ElastoDyn.
 Running InflowWind.
 Running AeroDyn.
   AeroDyn: projMod: 1
 Running ServoDyn.
FAST_InitializeAll:SrvD_Init:ValidatePrimaryData:PCMode must be 0 for linearization.
ValidatePrimaryData:VSContrl must be 0 or 1 for linearization.
 OpenFAST encountered an error during module initialization.
 Aborting OpenFAST.
So I thought maybe set Linearize = False will be a good idea to test, however, it still didn’t work, and come with new errors:
OpenFAST
OpenFAST-v4.1.2
Compile Info:
 - Precision: single
 - OpenMP: No
 - Date: Aug 06 2025
 - Time: 19:22:48
Execution Info:
 - Date: 12/30/2025
 - Time: 10:14:27+0800
 Running ElastoDyn.
 Running InflowWind.
 Running AeroDyn.
   AeroDyn: projMod: 1
 Running ServoDyn.
 Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows).
FAST_InitializeAll:SrvD_Init:BladedInterface_Init:The dynamic library
/home/runner/miniconda3/envs/test/lib/libdiscon.so could not be loaded. Check that the file
exists in the specified location and that it is compiled for 64-bit applications.
 Aborting OpenFAST.
The path /home/runner/miniconda3/envs/test/lib/libdiscon.so looks like a Linux style path, but I ran the OpenFAST on the Windows environment.
All best wishes,
Xingyu
It seems that I didn’t download the ROSCO properly, this could be solved by download a libdiscon.dll and put it under the root path. However, Releases · NREL/ROSCO only offered .dll based on 32bit. And I just downloaded one here: https://github.com/NREL/ROSCO/releases/download/v2.2.0/libdiscon.dll.
It solved some problem, but the OpenFAST still didn’t worked.
OpenFAST
OpenFAST-v4.1.2
Compile Info:
 - Precision: single
 - OpenMP: No
 - Date: Aug 06 2025
 - Time: 19:22:48
Execution Info:
 - Date: 12/30/2025
 - Time: 11:39:03+0800
 Running ElastoDyn.
 Running InflowWind.
 Running AeroDyn.
   AeroDyn: projMod: 1
 Running ServoDyn.
Using legacy Bladed DLL interface.
At line 59 of file D:\bld\rosco_1615353392809\work\src\ReadSetParameters.f90 (unit = 89, file = '.\IEA-15-240-RWT-Monopile_DISCON.IN')
Fortran runtime error: Bad integer for item 1 in list input
UPDATE: 2. Installing ROSCO toolset — ROSCO 2.10.3 documentation
Follow the guidance above, a suitable libdiscon.dll file could be generated, however, the OpenFAST still abort unormally. With the message below:
OpenFAST
OpenFAST-v4.1.2
Compile Info:
 - Precision: single
 - OpenMP: No
 - Date: Aug 06 2025
 - Time: 19:22:48
Execution Info:
 - Date: 12/30/2025
 - Time: 14:07:10+0800
 Running ElastoDyn.
 Running InflowWind.
 Running AeroDyn.
   AeroDyn: projMod: 1
 Running ServoDyn.
Running ROSCO-2.10.1
A wind turbine controller framework for public use in the scientific field
Developed in collaboration: National Renewable Energy Laboratory
                            Delft University of Technology, The Netherlands
 ROSCO Warning: Did not find VS_FBP in input file.  Using default value of            0
 ROSCO Warning: Did not find SU_Mode in input file.  Using default value of            0
 ROSCO Warning: Did not find correct size F_NotchFreqs in input file.  Using default value of [   0.0000000000000000      ]
 ROSCO Warning: Did not find correct size F_NotchBetaNum in input file.  Using default value of [   0.0000000000000000      ]
 ROSCO Warning: Did not find correct size F_NotchBetaDen in input file.  Using default value of [   0.0000000000000000      ]
 ROSCO:SetParameters:ParseInput_Dbl_Opt:Missing or default values are not allowed for F_VSRefSpdCornerFreq. Please check control modes.
FAST_Solution0:CalcOutputs_And_SolveForInputs:SolveOption2:SrvD_CalcOutput:DLL_controller_call:ROS
 ROSCO:
 OpenFAST encountered an error during simulation initialization.
 Aborting OpenFAST.
All best wishes,
Xingyu
It looks like you’re pointing to an older ROSCO input in ServoDyn. Please try the input for v2.10 here.
Hi @Daniel.Zalkind ,
Thank you! Finally this case worked!!
All best wishes,
Xingyu
I hope this message finds you well. I found that in Wind turbine aeroelastic stability in OpenFAST https://docs.nrel.gov/docs/fy24osti/88266.pdf, Pietro showed a Campbell diagram with Natural frequencies and elastic damping ratios of 2RE, which means 2nd rotor edgewise. However, in ELASTODYN input file, it seems that I can only define the First edgewise blade mode DOF. May I ask how this is achieved? Do I need to perform the linearization myself, or is it sufficient to configure the corresponding settings in OpenFAST?
All best wishes,
Xingyu
Dear @Xingyu.Liu,
The paper you refer to uses BeamDyn to model structural dynamics of the blades, not ElastoDyn.
Thank you for pointing that out. I’ve rerun the simulation with the BeamDyn module, but it seems the results still only include FlapDOF1, FlapDOF2, and EdgeDOF.
All best wishes,
Xingyu
Dear @Xingyu.Liu,
I believe the 2nd edgewise blade-bending mode has a higher frequency than what you are plotting.
I also see that your results are quite noisy, suggesting that you don’t have converged results.
Thank you for this suggestion, indeed, the 2nd edgewise mode could be found at around 2.2
And for the converged issue, I changed the OutFmt to make it more accurate – I think it looks much better.
But there are still some discrepancies with the literature above. May I ask if there are any additional parts that need to be noted?
!!UPDATED!! it is because of the gravity, the literature case ignored the influence of the gravity, which means that the gravity was set as 0. The results then becomes below.
All best wishes,
Xingyu
Dear @Xingyu.Liu,
I’m glad you now get the results you expect!
Thank you! Given the relatively reasonable results I have achieved previously, I have proceeded with reproducing the thesis—this time I attempted to enable the AeroDyn module, but it seems to have led to a series of other errors. Currently, the modules I have enabled are
2                      CompElast   - Compute structural dynamics (switch) {1=ElastoDyn; 2=ElastoDyn + BeamDyn for blades; 3=Simplified ElastoDyn}
1                      CompInflow  - Compute inflow wind velocities (switch) {0=still air; 1=InflowWind; 2=external from ExtInflow}
2                      CompAero    - Compute aerodynamic loads (switch) {0=None; 1=AeroDisk; 2=AeroDyn; 3=ExtLoads}
1                      CompServo   - Compute control and electrical-drive dynamics (switch) {0=None; 1=ServoDyn}
0                      CompSeaSt   - Compute sea state information (switch) {0=None; 1=SeaState}
0                      CompHydro   - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
0                      CompSub     - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn; 2=External Platform MCKF}
0                      CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
0                      CompIce     - Compute ice loads (switch) {0=None; 1=IceFloe; 2=IceDyn}
0                      MHK         - MHK turbine type (switch) {0=Not an MHK turbine; 1=Fixed MHK turbine; 2=Floating MHK turbine}
Initially, I set Calsteady=True, but this run resulted in the following error message:
FAST_Solution:FAST_UpdateStates:FAST_AdvanceStates:B3::BD_GA2:BD_DynamicSolutionGA2:Solution does not converge after the maximum number of iterations
OpenFAST encountered an error at simulation time 167.1 of 300 seconds.
Aborting OpenFAST.
Therefore, for the second run, I set Calsteady=False. This time, the simulation completed successfully, but the results are as shown in the figure below, which appear to differ significantly from the results in the thesis. Could you advise on where the issue might be in the settings? Thank you!
All best wishes,
Xingyu
Dear @Xingyu.Liu,
By “thesis”, are you referring to our 2024 TORQUE paper that you cited earlier?
Your ACDC results don’t look at all converged, probably because of setting CalcSteady = FALSE. Instead of that, I would suggest reducing the time step or adding a correction step to resolve the convergence error you are receiving from BeamDyn.
