We are using NREL’s FAST for designing an offshore wind farm with turbines having a diameter of 140 m. Whenever we define a blade geometry with a length that is larger than 61.5 m, we are getting the “node does not project onto line2 element” error within the FAST_InitiializeAll: InitModuleMappings (see attached screenshot).
This is the same error that shows up when the last node of the NREL 5MW rotor is at 61.5 m in the AeroDyn blade file of the CertTest-files, where it is saying: “!bjj: because of precision in the BD-AD coupling, 61.5m didn’t work, so I changed it to 61.4999m”.
Is it not possible to simulate turbines with a larger radius than 65 m or is there anything we can do in order to avoid this error?
Florian
