Alright, sorry for the delayed reply, but here I am attaching the input file and the airfoil data under turbulence. The input file is basically the first test file because all I want to see is the effect of turbulence compared to no turbulence. If you have any other ideas on how I could better see the effects (i.e. whether I should include twist or not etc) feel free to share it.
So yeah I try to run wt_perf on these files but it complains.
thanks,
rieuk
PS. Ok I can’t see where to attach files so I guess I will have to paste it here…
[color=red]
----- WT_Perf Input File -----------------------------------------------------
WT_Perf Test01 input file. UAE Phase 3 turbine (Non-dimen, English, Space, PROP-PC).
Compatible with WT_Perf v3.00f
----- Input Configuration ----------------------------------------------------
False Echo: Echo input parameters to “.ech”?
False DimenInp: Turbine parameters are dimensional?
False Metric: Turbine parameters are Metric (MKS vs FPS)?
----- Model Configuration ----------------------------------------------------
16 NumSect: Number of circumferential sectors.
5000 MaxIter: Max number of iterations for induction factor.
1.0e-6 ATol: Error tolerance for induction iteration.
1.0e-6 SWTol: Error tolerance for skewed-wake iteration.
----- Algorithm Configuration ------------------------------------------------
True TipLoss: Use the Prandtl tip-loss model?
False HubLoss: Use the Prandtl hub-loss model?
True Swirl: Include Swirl effects?
True SkewWake: Apply skewed-wake correction?
True AdvBrake: Use the advanced brake-state model?
True IndProp: Use PROP-PC instead of PROPX induction algorithm?
False AIDrag: Use the drag term in the axial induction calculation?
False TIDrag: Use the drag term in the tangential induction calculation?
----- Turbine Data -----------------------------------------------------------
3 NumBlade: Number of blades.
16.5 RotorRad: Rotor radius [length].
0.2 HubRad: Hub radius [length or div by radius].
3.5 PreCone: Precone angle, positive downwind [deg].
0.0 Tilt: Shaft tilt [deg].
0.00 Yaw: Yaw error [deg].
3.3333 HubHt: Hub height [length or div by radius].
16 NumSeg: Number of blade segments (entire rotor radius).
RElm Twist Chord AFfile PrntElem
0.225 0.000 0.0911 1 False
0.275 0.000 0.0911 1 False
0.325 0.000 0.0911 1 False
0.375 0.000 0.0911 1 False
0.425 0.000 0.0911 1 False
0.475 0.000 0.0911 1 False
0.525 0.000 0.0911 1 False
0.575 0.000 0.0911 1 False
0.625 0.000 0.0911 1 False
0.675 0.000 0.0911 1 False
0.725 0.000 0.0911 1 False
0.775 0.000 0.0911 1 False
0.825 0.000 0.0911 1 False
0.875 0.000 0.0911 1 False
0.925 0.000 0.0911 1 False
0.975 0.000 0.0911 1 t False
----- Aerodynamic Data -------------------------------------------------------
0.0019749 Rho: Air density [mass/volume].
0.0001625 KinVisc: Kinematic air viscosity
0.143 ShearExp: Wind shear exponent (1/7 law = 0.143).
False UseCm: Are Cm data included in the airfoil tables?
1 NumAF: Number of airfoil files.
“airfoils/unsteadyaeroexp/naca4421NoTurbulence.dat” AF_File: List of NumAF airfoil files.
----- I/O Settings -----------------------------------------------------------
True TabDel: Make output tab-delimited (fixed-width otherwise).
True KFact: Output dimensional parameters in K (e.g., kN instead on N)
True WriteBED: Write out blade element data to “.bed”?
True InputTSR: Input speeds as TSRs?
“fps” SpdUnits: Wind-speed units (mps, fps, mph).
----- Combined-Case Analysis -------------------------------------------------
0 NumCases: Number of cases to run. Enter zero for parametric analysis.
WS or TSR RotSpd Pitch Remove following block of lines if NumCases is zero.
----- Parametric Analysis (Ignored if NumCases > 0 ) -------------------------
3 ParRow: Row parameter (1-rpm, 2-pitch, 3-tsr/speed).
2 ParCol: Column parameter (1-rpm, 2-pitch, 3-tsr/speed).
1 ParTab: Table parameter (1-rpm, 2-pitch, 3-tsr/speed).
True OutPwr: Request output of rotor power?
True OutCp: Request output of Cp?
True OutTrq: Request output of shaft torque?
True OutFlp: Request output of flap bending moment?
True OutThr: Request output of rotor thrust?
3, 5, 2.0 PitSt, PitEnd, PitDel: First, last, delta blade pitch (deg).
78, 78, 0.0 OmgSt, OmgEnd, OmgDel: First, last, delta rotor speed (rpm).
0.2, 18, 0.5 SpdSt, SpdEnd, SpdDel: First, last, delta speeds.
*** AIR FOIL DATA ***[color=red]
AeroDyn airfoil file. Compatible with AeroDyn v13.0.
NACA4421 Airfoil, OSU data at Re=0.285 Million, Clean roughness
NREL/TP-442-7817 Appendix B, Viterna used aspect ratio=11
1 Number of airfoil tables in this file
9.0e9 Table ID parameter (Reynolds number in milllions). For efficiency, make very large if only one table.
17.5 Stall angle (deg)
-3.00 Zero lift angle of attack (deg)
0 Cn slope for zero lift (dimensionless)
0 Cn at stall value for positive angle of attack
0 Cn at stall value for negative angle of attack
4.8000 Angle of attack for minimum CD (deg)
0.0250 Minimum CD value
-90.00 -.150 1.9250
-80.00 -.463 1.8500
-70.00 -.700 1.7000
-60.00 -.834 1.4750
-50.00 -.913 1.1880
-40.00 -.775 .8000
-30.00 -.550 .5000
-20.00 -.675 .4880
-17.50 -.725 .5000
-15.00 -.725 .4950
-12.50 -.730 .4900
-10.00 -.588 .4000
-7.50 -.425 .3000
-5.00 -.188 .2130
-2.50 .050 .1250
0.00 .300 .0750
2.50 .575 .0380
5.00 .825 .0250
7.50 1.050 .0380
10.00 1.275 .0625
12.50 1.475 .0750
15.00 1.550 .1250
17.50 1.613 .2000
20.00 1.600 .2500
30.00 1.500 .5500
40.00 1.230 .9500
50.00 1.063 1.3000
60.00 .950 1.7630
70.00 .575 1.9900
80.00 .225 2.0800
90.00 -.175 2.0630
EOT
