Hello
I am running FAST and generating the .wnd file in turbsim for full field. i.e. velocity profile for grid area and tower height below the grid. Mean wind speed at 80m height (simplified Vestas 1.65 MW turbine model ) is 50 m/s. I am using time step 0.01.
The turbsim and fast runs normally and I do get .bts files (falg = true) . But I get the warning message : Coherent turbulence time step file can not be generated.
My very very basic understanding is that the coherent structures and interaction of fluid flow is boundary level turbulence problem.
I am not sure if the warning message could have any impact on the results. Any help is or suggestion would help. I appreciate your precious time.
Atul.Patil
Student , FSU
