Hello to all,
I’m doing a project on the NREL 5-MW Baseline wind turbine with TLP Configuration. I tried to extract linearized models with FAST v8 and I realized that whenever the first side-to-side tower bending-mode DOF is on, an RHP zero appears in the 2*2 transfer function matrix from inputs [generator torque; collective blade pitch] to outputs [High-speed shaft power; Platform pitch tilt rotation]. Moreover, with turning the second side-to-side tower bending-mode on, an RHP pole appears in the transfer function matrix.
By applying the GSPI controller (when second side-to-side tower bending-mode is on), FAST encounters an error:
violated in SUBROUTINE SmllRotTrans() due to a large tower deflection (ElastoDyn SetCoordSy). The
be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 3.25 s
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:InflowWind_CalcOutput:CalcOutput:IfW_TSF
FWind_CalcOutput [position=(3.77776E+08, -2.79132E+09, 2.71944E+05) in wind-file coordinates]:
Error: FF wind array was exhausted at 3.35 seconds (trying to access data at -2.07569E+07
seconds).
CalcOutputs_And_SolveForInputs:SolveOption1:ED_HD_InputOutputSolve:HydroDyn_CalcOutput: Angles in
GetSmllRotAngs() are larger than 0.4 radians.
radians.
FAST encountered an error at simulation time 3.3 of 300 seconds.
Aborting FAST.
Dear Milad,
Clearly your model is going unstable, but without knowing more about your simulation set-up, it is difficult for me to guess why. Does your model run stably without the controller enabled? Are you using the NREL 5-MW baseline turbine atop the MIT/NREL TLP or a TLP you developed yourself?
Respected sir,
i am new FAST learner …I am doing spar-torus platform ,in that spar modelling and turbine is everything according to NREL designing . so while performing this error occurs, so please guide me how to counteract this error…The Code showing error as follows :
Jonkman of NREL/NWTC for use in the IEA Annex XXIII OC3 studies. Includes modifications for the
Hywind spar.
FAST_Solution:FAST_AdvanceStates:ED_ABM4:SetCoordSy:Small angle assumption violated in SUBROUTINE
SmllRotTrans() due to a large tower deflection (ElastoDyn SetCoordSy). The solution may be
inaccurate. Simulation continuing, but future warnings from SmllRotTrans() will be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 0.675 s
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption1:ED_HD_InputOutputSolve:HydroDyn_CalcOutp
ut: Angles in GetSmllRotAngs() are larger than 0.4 radians.
radians.
FWind_CalcOutput [position=(-153.2, 111.81, 5.541) in wind-file coordinates]: FF wind array
boundaries violated: Grid too small in Y direction. Y=111.81; Y boundaries = [-85, 85]
radians.
FAST encountered an error at simulation time 0.725 of 3600 seconds.
Aborting FAST.
G:\New folder\FAST-Prog STC\STC>
Dear Ajay,
We’ve discussed this problem a bit by e-mail, but you haven’t provided any more information that would help me identify why your model is going unstable. I suggest searching here on the forum to see how others have solved similar problems in the past. I would also suggest simplifying the model to debug. E.g. does the model still go unstable with fixed generator speed and disabled control? Can you isolate which structural degree of freedom (DOF) in ElastoDyn results in the model going unstable (by disabling all DOFs but a few)?
thanks for replying…sir ,i tried with disabling few DOF’s but it still showing error…so sir i will post here the code of elastodyn
Dear Ajay,
I would not expect the model to go unstable with all structural DOFs disabled. So, I would suggest disabling all DOFs and systematically enabling them to identify the problematic DOF.
The code is running for following DOF’s :
or else its showing error os radian…so what next i do to know the kind errors ??
Dear Ajay,
Are you saying that the model runs without error if all DOFs except platform heave, roll, and pitch are enabled? And if you enable any of the platform heave, roll, and pitch DOFs, the model goes unstable? If so, this sounds like a problem with the hydrostatic restoring in the model, which has a strong effect on the heave, roll, and pitch DOFs.
thank u for reply …so sir what can i do further to eliminate the problem ??
Dear Ajay,
Assume what I said is true, you should check how you’ve defined the platform hydrostatic restoring in HydroDyn i.e. your WAMIT *.hst file for the potential-flow solution or the AddCLin matrix for the strip-theory solution. See the draft HydroDyn User’s Guide and Theory Manual for guidance: wind.nrel.gov/nwtc/docs/HydroDyn_Manual.pdf.
