In many time series of runs with normal and emergency stops I see unreal spikes in e.g. bending moments. For calculation of extreme values these spikes are very annoying. Can you recommend me settings in FAST (e.g. communication intervals for modules) which lead to less unreal peaks in simulation time series?
Thank you for your support.
René
Dear René,
I would not expect you to receive “unreal peaks” in the time-series output from FAST. You’ll have to clarify what problem you are seeing and how you are setting up your simulation.
after a stop of the turbine oscillations in moments and deflections are concluding. In FAST the time series looks very well but there is one (or more) time step which steps out of line (spike). During postprocessing the extreme values this faulty time step is disturbing.
So in generall concluding events generate some few time steps out of line wich are “unreal”. Attached you can see those spikes in an example time series.
I hope this will clarify my question.
René
Dear Rene,
Can you clarify what output parameter you are plotting and what features you’ve enabled in your FAST model (modules, aerodynamic options, structural degrees of freedom, controls)?
This graph shows the blade edgewise bending moment Mx.
I currently use FAST v8.16 with AeroDyn 15.04 (maybe I have to try it with AeroDyn 14).
I use the modules ElastoDyn, InflowWind, ServoDyn (without TMD), too.
Following settings for the DOFs are used:
---------------------- DEGREES OF FREEDOM -----------------------------------
False YawDOF - Yaw DOF (flag)
False PtfmSgDOF - Platform horizontal surge translation DOF (flag)
False PtfmSwDOF - Platform horizontal sway translation DOF (flag)
For AeroDyn 15.04 following settings are used:
1 WakeMod - Type of wake/induction model (switch) {0=n
2 AFAeroMod - Type of blade airfoil aerodynamics model (
1 TwrPotent - Type tower influence on wind based on pote
False TwrShadow – Calculate tower influence on wind based on
True TwrAero - Calculate tower aerodynamic loads? (flag)
False FrozenWake - Assume frozen wake during linearization?
2 SkewMod - Type of skewed-wake correction model (swit
True TipLoss - Use the Prandtl tip-loss model? (flag) [us
True HubLoss - Use the Prandtl hub-loss model? (flag) [us
true TanInd - Include tangential induction in BEMT calcu
True AIDrag - Include the drag term in the axial-inducti
True TIDrag - Include the drag term in the tangential-in
"Default" IndToler - Convergence tolerance for BEMT nonlinear s
100 MaxIter - Maximum number of iteration steps (-) [use
Control is a self-written Bladed-style DLL.
Many thanks for your help.
René
Dear René,
I would not expect you to receive spikes in the edgewise bending moment.
I would suggest you try a few things i.e. do the spikes go away if you:
- Disable unsteady airfoil aerodynamics (AFAeroMod = 1)?
- Disable your self-written Bladed-style DLL controller?
- Reduce the FAST time step (DT)?
- Add a FAST correction step (NumCrctn > 0)?
Thank you for your suggestions. I will try it.
René
