Turbulent wind for DLC 1.4 (ECD gust)
I’m trying to create a turbulent wind case for a DLC1.4 simulation. Here are the steps I followed so far:
  • Used the windtools TurbSim class to load a “baseline” turbulent wind file (github.com/NREL/windtools/blob/ … nthetic.py) to an array.
  • Then I summed an ECD gust with the previous loaded array.
  • Wrote back the results to a BTS file
  • Run two fast simulations: one with the baseline wind and the other with the modified wind file.
The results are the following:
blue: modified file
orange: baseline turbulent file
The ECD gust I superimposed starts only at 50s, so I was expecting the the Wind1VelX and Wind1VelY signals were exactly the same until that time and the Z component to be equal at all times, since I didn’t modified it. But I got this kind of “noise” in the velocity signals. I’ve already checked the Vslope and Voffset parameters to convert the wind speed from float to int when writing the binary file, and I can assure they´re not the problem.
The other check I made was to compare the velocities read directly from the bts file with the output from fast. The following fig. shows this for the baseline turbulent file I’m using:
These are the x-component of the grid point (14,14) and the openfast Wind1VelX channel configured at hub-height. My grid is 30x30 points, 0.05 s time step and the fast outputs are 0.025s. Again we see the “noisy” signal. I was not expecting the two lines to be exactly equal in this case, since the output from fast is a interpolation between various grid points, but the magnitude of that difference surprised me.
Is this behaviour expected? There is something fundamentally wrong with the approach I followed to modify the turbulent wind file? Is there a better way to do it?
Pedro
Dear Pedro,
I’m not familiar with the synthetic.py Python script you are using, so, I can’t really comment on that.
But I do question what you are trying to do. Normally the Extreme Coherent Gust with Direction Change (ECD) load case 1.4 is run with deterministic wind rather than with turbulent wind. That is in OpenFAST, one would generally use the uniform wind file format, WindType = 2, in InflowWind based on a uniform wind file generated, e.g., with NREL’s IECWind preprocessor. Is there a reason you are not simulating DLC 1.4 this way?
Hi Pedro,
I have not used the python tools in the way that you’ve described either. I wrote the TurbSim class to read inflow data into a convenient python format. If I had to wager a guess, I would think that your original input data were periodic and your modified file with the coherent gust did not account for this. I never wrote a BTS writer because it was easier to write out HAWC-style full-field files as described in the InflowWind manual.
Good luck with your problem if you haven’t yet resolved it!
Cheers,
Eliot
Hi Jason,
My reason for simulating DLC 1.4 with turbulent wind is because of section 7.4.1 of IEC61400-1 (2019) :
In my case the gust causes the controller to fire a shutdown due to reaching maximum yaw error. So I need to simulate with a turbulent wind to be sure that the shutdown behaviour will be the same as in the deterministic wind.
Are you aware of another mean of compliance with this paragraph?
Eliot: Unfortunately I did’nt solve solve this problem yet. Currently it’s on hold, but if sometime I overcome it I’ll come back here to register the solution
Thanks Jason and Eliot for your attention.
Dear Pedro,
Interesting; I don’t recall seeing that stated in the -1, but there it is stated clearly (also in the 2005 version and offshore -3, which I’m more familiar with). I’m not actually sure how this is normally handled because I’m not aware of any aero-elastic tool that supports the simulation of discrete wind direction gusts or direction changes together with full-field turbulence. This would be a good question for a certification body.
Hi Pedro and Jason,
I have been through this thread the conversation is very much interesting. May I know if there are any further proceedings in this case ?
Chaitanya
Hi Chaitanya,
I have not followed up yet, but I support the development of the IEC 61400-3-2 floating wind design standard and I’ll ask that question at an upcoming meeting.
Hi Jason,
Ive downloaded IECWind to create the dlcs .wind data. Now I was wondering if its possible to simulate turbulent wind situations instead of steady wind flow with IECWind?
Also I was not to sure about the results for the ECD gusts since I was expecting the wind in x direction to decrease, Ive attached the ECD-r+2.0. Maybe you can have a look at it.
Thank you, best regards,
5MWLand_ECD-r+2.0
Dear @Veith.Hieber,
IECWind is a simple code for generating the deterministic gusts specified in IEC (ECD, EOG, EDC, etc.). If you want to generate turbulent wind, use TurbSim instead.
I would expect the vector magnitude of the ECD gust to increase over time, the specific X/Y components may increase/decrease as the direction changes quickly.
Thank you, Ive generated wind data for turbulent wind in turbsim before, I havent figured out how to set up eg a ECD data set on turbsim though. Might need some extra work on that.
Sorry I couldnt quite follow, would you say the graph looks reasonable then?
Dear @Veith.Hieber,
TurbSim is used to generate turbulent wind without deterministic gusts and IECWind is used to generate deterministic gusts without turbulence.
