Hi, I have a slight problem in running openfast_toolbox with the latest versio of OpenFAST and IEA 15WM UMaine. I konw the cause, but not sure what the solution is.
OpenFAST version: 4.0.2
IEA 15MW UMaine semisub: downloaded few days ago
I set up a spreadsheet to run a series of analyses with openfast_toolbox, and everything goew well up to this point:
Running InflowWind.
FAST_InitializeAll:InflowWind_Init:InflowWind_ParseInputFileInfo:ParseSiAry:
>> A fatal error occurred when parsing data from
"WorkingDir/IEA-15-240-RWT/IEA-15-240-RWT_InflowFile_0_3_3.dat".
>> The "RotorApexOffsetPos" array was not assigned valid REAL values on line #59.
>> The text being parsed was :
"0.0 RotorApexOffsetPos - Offset of the lidar from hub height (m)"
OpenFAST encountered an error during module initialization.
Aborting OpenFAST.
I checked the file IEA-15-240-RWT_InflowFile.dat that I have in the IEA/IEA-15-240-RWT, and at line #59 I have the following:
0.0 0.0 0.0 RotorApexOffsetPos - Offset of the lidar from hub height (m)
but when OpenFAST toolbox copy this file in the WorkingDir, at line 59 I have this:
So, it seems that the openfast_toolbox script is stripping the Y/Z offset values (0.0 0.0 ) from RotorApexOffsetPos , leaving only 0.0 . This violates OpenFAST’s requirement for three values in array-type parameters. The issue seems to stem from how the script parses and writes input files, particularly for multi-value entries.
Has anyone encountered this error?
Also, not sure why the parameters of the LIDAR are read even if I set SensorType to 0.
@Andrew.Russell maybe can help?
Maurizio
