Dear Jonkman,
when I searched the keyword “strain” in the OutListParameters file, it seems to that there is only the strain of the shaft and rotor. In the forum, I found that ElastoDyn.dat may own these parameters. What’s the meaning of TwrGagNd and NBlGages? How to get the output of strain in blades and the tower? Thank you.
Gaoshuai WANG
0 TStart - Time to begin tabular output (s) (currently unused)
10, 19, 28 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
5, 9, 13 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
