(Courtesy of @Andy.Platt)
Greetings from the OpenFAST development team!
We are happy to announce the release of version 3.5.1! This version of OpenFAST includes many bugfixes and a few improved features. Many of you will undoubtedly be happy to know that there are no input file changes with this update as this is primarily a bugfix release.
Feature improvements included in this release include the ability to visualize Morison meshes as surfaces and lines from HydroDyn, mooring line visualization from MoorDyn, new coordinate systems for nodal outputs in AeroDyn, and more SubDyn outputs (up to 99 members).
Release notes, links, and distribution:
Release notes: https://github.com/OpenFAST/openfast/releases/tag/v3.5.1
API changes: https://openfast.readthedocs.io/en/main/source/user/api_change.html
Example input files (regression tests): https://github.com/OpenFAST/r-test/tree/v3.5.1
We will be posting Windows executables to the release page in the next few days. Executables distributed through Conda and HomeBrew will also be available shortly.
Thank you for your continued use and support of OpenFAST! As always, if you find any issues, please report them on the GitHub page (https://github.com/OpenFAST/openfast/issues) or post comments to the discussion page for this release (https://github.com/OpenFAST/openfast/discussions/1823).
Happy wind turbine modeling!
- The OpenFAST development team
OpenFAST v3.5.3 has now been released!
This release includes a long awaited set of bug fixes for linearization with BeamDyn. Anyone needing to linearize with BeamDyn should not use any version of OpenFAST prior to this release.
Other notable improvements include corrections to turbine indexing when coupled to external codes such as AMR-Wind, new linearization regression tests, and new docker images.
The input files have not changed relative to the previous release.
Release notes, code, and executables: Release v3.5.3 ยท OpenFAST/openfast ยท GitHub.
Example input files and regression tests: Release v3.5.3 ยท OpenFAST/r-test ยท GitHub.
Happy modeling!
You may have missed this over the holidays, but we are happy to announce that OpenFAST v4.0.0 was released on Christmas Eve! We were anticipating the release of this version of OpenFAST for a while, which includes many architectural changes, physics improvements, and bug fixes!
Improvements and new features include:
- aerodynamics for skewed and sheared inflow, coned rotors, nacelle drag, and tail-fins;
- hydrodynamic improvements, including wave loads at the displaced position, constrained New Wave theory, wave stretching, and the splitting of the wave field (new SeaState (SS) module) from HydroDyn;
- large floating platform yaw dynamics;
- nacelle-yaw friction;
- linearization for MHK turbines;
- reduced order structural and aero modules (Simplified-ElastoDyn (SED) and AeroDisk (ADsk));
- AeroMap calculations;
- wake-added turbulence in FAST.Farm;
- fluid-structure coupling with AMR-Wind;
- an unsteady airfoil aerodynamics driver supporting 3-DOF planar motion of a generalized cross section;
- an updated Python library for OpenFAST file handling;
- revised wind and wave data handling;
- removal of AeroDyn v14;
- many bug fixes; and
- much, much more!
Note that the number of input file changes is large, so, we recommend reviewing the change logs (see links above).
Thank you for your continued use and support of OpenFAST! As always, if you find any issues, please report them on the GitHub page (Issues ยท OpenFAST/openfast ยท GitHub). General questions or comments should be asked on our forum (https://forums.nrel.gov/) or on the discussion page dedicated to this release (v4.0.0 ยท OpenFAST/openfast ยท Discussion #2590 ยท GitHub).
OpenFAST v4.1.0 has now been released!
- removes the SuperController from FAST.Farm in favor of ZeroMQ communication between ROSCO controllers;
- direct coupling of MoorDyn to SeaState;
- support for rectangular members in HydroDyn and SubDyn;
- vortex-induced vibration (VIV) capabilities in MoorDyn;
- new pyOpenFAST module for calling c-binding libraries directly from Python; and
- several bug fixes and improvements for AeroDyn, BeamDyn, MoorDyn, OpenFAST, several various c-binding libary interfaces, and GitHub actions.
Thank you for your continued use and support of OpenFAST! As always, if you find any issues, please report them on the GitHub page (Issues ยท OpenFAST/openfast ยท GitHub). General questions or comments should be asked on our forum (https://forums.nrel.gov/) or on the discussion page dedicated to this release (v4.1.0 ยท OpenFAST/openfast ยท Discussion #2873 ยท GitHub).
OpenFAST v4.2.0 has now been released!
- Cubic interpolation of wave kinematics data in HydroDyn and SeaState;
- Additional transverse drag modeling options for rectangular members in HydroDyn;
- Hub inertia improvement for 2-bladed rotors in ElastoDyn; and
- several bug fixes and improvements for FAST.Farm, AeroAcoustics within AeroDyn, ElastoDyn, InflowWind, MoorDyn, NWTC_Library, ServoDyn, TurbSim, several various c-binding libary interfaces, openfast-io Python reader, GitHub actions, tests, and linearization.
Thank you for your continued use and support of OpenFAST! As always, if you find any issues, please report them on the GitHub page (GitHub ยท Where software is built). General questions or comments should be asked on our forum (https://forums.nrel.gov/) or on the discussion page dedicated to this release (Release v4.2.0 ยท OpenFAST/openfast ยท Discussion #3174 ยท GitHub).
