I have performed the aerodynamic design of a SSWT using the steady state BEMT equations stated in AeroDyn Theory Manual and I have then compared my own code results with WT_Perf ones obtaining a very good correlation. The turbine’s power control system is VS-FP, so in the WT_Perf model input file I entered the rotor speed in rpm for each inflow wind velocity, making the rotor speed vary linearly within a wind velocity range (so that TSR=TSRopt) until a certain point. Above it, the rotor speed was mantained constant (and TSR therefore drops).
My problem comes when trying to implement an analogous routine into FAST v8 ServoDyn module. I see that it is not posible to establish a direct relationship between inflow wind velocity and rotor speed, that, as far as I know, will in reality depend on the difference between aerodynamic and generator torque and the drive train inertia . So, my question is: is there any practical way to make the rotor speed vary linearly within a velocity range in order to mantain the TSR at its optimun value and then mantain a constant rotational speed?
I am aware that my question is due to a lack of background on wind turbine power control systems rather than a FAST implementation , so I would be grateful if you could provide me with any reference/link/biblioghraphy/topic that helps me becoming familiar with all this issue.
Thank you very much in advance,
Alvaro Olcoz Alonso
Dear Alvaro,
I can’t think of a good reference for a variable-speed, fixed-pitch turbine controller. But I’ll try to summarize my understanding:
To have the rotor speed vary linearly with wind speed (to maintain a constant tip-speed ratio) requires the standard variable-speed control law (torque = constant*omega^2). In a variable-speed, variable-pitch wind turbine, the variable-pitch controller typically operates with constant torque or constant power and there is typically a transition region (2.5) between the variable-speed controller and the variable-pitch controller whereby the torque is proportional to speed, with a fairly steep torque-speed slope. For a fixed-pitch controller, the blades should be design to stall at high wind speed and the region 2.5 torque-speed region should extend far enough so as to prevent the torque from transitioning above region 2.5. If all you want is a simple implementation, I think you could get by with the simple variable-speed control option (VSContrl = 1) available in the ServoDyn module of FAST / OpenFAST, with the rated torque and rated speed set high enough such that they are never reached.
Thank you again for your rapid answer.
I definetely think that the VSContrl=1 will work for my implementation.
Considering the region 2, I agree that I will need to set the constant value VS_Rgn2K to obtain a constant TSR and mantain Cp at its optimum value.
I know that the transition region 2 1/2 is used to achieve rated torque at rated speed for pitch regulated machines. In my case, power limitation is achieved by passive stall, and the torque-omega curve that I want to follow (AEDG locus in the attached figure) corresponds to a machine that operates at (Q=K*omega^2) in region 2 but then moves in a vertical straight line in the Q-omega graph, where, at constant rotational speed, the aerodynamic torque will be limited by passive stall aerodynamic design of the blades.
Therefore, according to my understading (please, correct me if I am wrong), I could use the region 2 1/2 to define a straight line (EDG in the fig.) with “infinite” slope. I guess that a very high rated torque (which will never be achived), the real rated rotational speed and a slip percentual factor very close to 0 will model that line. From your last post, I understood that you suggested setting the rated velocity also unreachable, but that confuses me, because it will lead to a very large region 2 1/2 with an undetermined slope.
Thank you in advance.
Very best regards.
Alvaro Olcoz Alonso
Dear Alvaro,
Yes, I agree with your comments.
ServoDyn won’t let you set VS_SlPc equal to zero, but setting it to a small value (say 1.0) will result in a fairly steep slope of the torque-speed curve in Region 2.5 (line “ED” in your graph). By my comment regarding setting the “rated torque and rated speed high”, I was referring to point “D” in your graph. The simple variable-speed control option (VSContrl=1) will result in constant torque for speeds above point “D”, rather than following the linear region back down to point “G” in your graph. I don’t think this would be very realistic, so, I would set point “D” far to the top of your graph such that point “D” will not be reached (ensuring that the line “ED” is what you want).
Very best regards
Alvaro Olcoz
