Reduced speed OpenFAST v4+ vs v3.5.2
Hello all,
I’ve recently updated my openFAST version from v3.5.2 to v4.1.0 and I’ve noticed a big drop in computational speed. On two different machines the time ratio went down with more than a factor 3 from v3.5.2 to v4.1.0:
  • Machine one: Sim/CPU = 4.80 → 1.48
  • Machine two: Sim/CPU = 2.11 → 0.48
For both machines and both versions similar simulations were performed (same time step and interpolation order, same/similar modules, IEA 15MW vs IEA 22MW turbine).
I tried both with the precompiled binaries and self-compiled (speed-optimised) binaries, but this gave almost no difference.
Is this expected behaviour or is there something that I can fix/improve?
Victor Rappe
Dear @Victor.Rappe,
Can you share your solver settings and which modules you have enabled (or perhaps just share the OpenFAST primary (.fst) input file)?
Dear @Jason.Jonkman,
Thank you for the quick response. You can find the .fst files at the end of this post. I have found a reason for the difference in simulation speed. The v3.5.2 input file had the number of correction iterations (NumCrctn) equal to zero, while v4.1.0 had it equal to one. Putting this to zero, significantly speeds up the simulations.
The additional beamdyn blade input files in v4.1.0 had only a limited impact on the solver speed.
However, even with these changes the v4.1.0 is still slower compared to v3.5.2:
  • Machine one: Sim/CPU = 4.80 → 2.80
  • Machine two: Sim/CPU = 2.11 → 1.20
Victor
V3.5.2
------- OpenFAST INPUT FILE -------------------------------------------
True                  Echo        - Echo input data to <RootName>.ech (flag)
"FATAL"                AbortLevel  - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
50.0                   TMax        - Total run time (s)
0.025                  DT          - Integration time step (s)
2                      InterpOrder - Interpolation order for input/output time history (-) {1=linear, 2=quadratic}
0                      NumCrctn    - Number of correction iterations (-) {0=explicit calculation, i.e., no corrections}
99999.0                DT_UJac     - Time between calls to get Jacobians (s)
1000000.0              UJacSclFact - Scaling factor used in Jacobians (-)
      1   CompElast       - Compute structural dynamics (switch) {1=ElastoDyn; 2=ElastoDyn + BeamDyn for blades}
      1   CompInflow      - Compute inflow wind velocities (switch) {0=still air; 1=InflowWind; 2=external from OpenFOAM}
      2   CompAero        - Compute aerodynamic loads (switch) {0=None; 1=AeroDyn v14; 2=AeroDyn v15}
      1   CompServo       - Compute control and electrical-drive dynamics (switch) {0=None; 1=ServoDyn}
      1   CompHydro       - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
      0   CompSub         - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn; 2=External Platform MCKF}
      3   CompMooring     - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
      0   CompIce         - Compute ice loads (switch) {0=None; 1=IceFloe; 2=IceDyn}
      0   MHK             - MHK turbine type (switch) {0=Not an MHK turbine; 1=Fixed MHK turbine; 2=Floating MHK turbine}
9.81                   Gravity     - Gravitational acceleration (m/s^2)
1.225                  AirDens     - Air density (kg/m^3)
1025                   WtrDens     - Water density (kg/m^3)
1.464e-05              KinVisc     - Kinematic viscosity of working fluid (m^2/s)
335                    SpdSound    - Speed of sound in working fluid (m/s)
103500                 Patm        - Atmospheric pressure (Pa) [used only for an MHK turbine cavitation check]
1700                   Pvap        - Vapour pressure of working fluid (Pa) [used only for an MHK turbine cavitation check]
200                     WtrDpth     - Water depth (m)
0                      MSL2SWL     - Offset between still-water level and mean sea level (m) [positive upward]
"IEA-15-240-RWT-UMaineSemi_ElastoDyn.dat"    EDFile          - Name of file containing ElastoDyn input parameters (quoted string)
""                     BDBldFile(1) - Name of file containing BeamDyn input parameters for blade 1 (quoted string)
""                     BDBldFile(2) - Name of file containing BeamDyn input parameters for blade 2 (quoted string)
""                     BDBldFile(3) - Name of file containing BeamDyn input parameters for blade 3 (quoted string)
"IEA-15-240-RWT_InflowFile.dat"    InflowFile      - Name of file containing inflow wind input parameters (quoted string)
"IEA-15-240-RWT-UMaineSemi_AeroDyn15.dat"  AeroFile     - Name of file containing aerodynamic input parameters (quoted string)
"IEA-15-240-RWT-UMaineSemi_ServoDyn.dat"    ServoFile       - Name of file containing control and electrical-drive input parameters (quoted string)
"IEA-15-240-RWT-UMaineSemi_HydroDyn.dat"      HydroFile       - Name of file containing hydrodynamic input parameters (quoted string)
"none"                 SubFile         - Name of file containing sub-structural input parameters (quoted string)
"IEA-15-240-RWT-UMaineSemi_MoorDyn.dat"      MooringFile     - Name of file containing mooring system input parameters (quoted string)
"none"                 IceFile         - Name of file containing ice input parameters (quoted string)
False                  SumPrint    - Print summary data to "<RootName>.sum" (flag)
1.0                    SttsTime    - Amount of time between screen status messages (s)
99999.0                ChkptTime   - Amount of time between creating checkpoint files for potential restart (s)
0.1                    DT_Out      - Time step for tabular output (s) (or "default")
0.0                    TStart      - Time to begin tabular output (s)
3                      OutFileFmt  - Format for tabular (time-marching) output file (switch) {1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both}
True                   TabDelim    - Use tab delimiters in text tabular output file? (flag) {uses spaces if false}
"ES10.3E2"             OutFmt      - Format used for text tabular output, excluding the time channel.  Resulting field should be 10 characters. (quoted string)
False                  Linearize   - Linearization analysis (flag)
False                  CalcSteady  - Calculate a steady-state periodic operating point before linearization? [unused if Linearize=False] (flag)
3                      TrimCase    - Controller parameter to be trimmed {1:yaw; 2:torque; 3:pitch} [used only if CalcSteady=True] (-)
0.001                  TrimTol     - Tolerance for the rotational speed convergence [used only if CalcSteady=True] (-)
0.01                   TrimGain    - Proportional gain for the rotational speed error (>0) [used only if CalcSteady=True] (rad/(rad/s) for yaw or pitch; Nm/(rad/s) for torque)
0                      Twr_Kdmp    - Damping factor for the tower [used only if CalcSteady=True] (N/(m/s))
0                      Bld_Kdmp    - Damping factor for the blades [used only if CalcSteady=True] (N/(m/s))
2                      NLinTimes   - Number of times to linearize (-) [>=1] [unused if Linearize=False]
30.000000, 60.000000   LinTimes    - List of times at which to linearize (s) [1 to NLinTimes] [used only when Linearize=True and CalcSteady=False]
1                      LinInputs   - Inputs included in linearization (switch) {0=none; 1=standard; 2=all module inputs (debug)} [unused if Linearize=False]
1                      LinOutputs  - Outputs included in linearization (switch) {0=none; 1=from OutList(s); 2=all module outputs (debug)} [unused if Linearize=False]
False                  LinOutJac   - Include full Jacobians in linearization output (for debug) (flag) [unused if Linearize=False; used only if LinInputs=LinOutputs=2]
False                  LinOutMod   - Write module-level linearization output files in addition to output for full system? (flag) [unused if Linearize=False]
0                      WrVTK       - VTK visualization data output: (switch) {0=none; 1=initialization data only; 2=animation}
1                      VTK_type    - Type of VTK visualization data: (switch) {1=surfaces; 2=basic meshes (lines/points); 3=all meshes (debug)} [unused if WrVTK=0]
True                  VTK_fields  - Write mesh fields to VTK data files? (flag) {true/false} [unused if WrVTK=0]
1                     VTK_fps     - Frame rate for VTK output (frames per second){will use closest integer multiple of DT} [used only if WrVTK=2]
V4.1.0
Generated with AeroElasticSE FAST driver
False                  Echo        - Echo input data to <RootName>.ech (flag)
0.025                   DT          - Recommended module time step (s)
1                      NumCrctn    - Number of correction iterations (-) {0=explicit calculation, i.e., no corrections}
1                      CompElast   - Compute structural dynamics (switch) {1=ElastoDyn; 2=ElastoDyn + BeamDyn for blades; 3=Simplified ElastoDyn}
1                      CompInflow  - Compute inflow wind velocities (switch) {0=still air; 1=InflowWind; 2=external from ExtInflow}
2                      CompAero    - Compute aerodynamic loads (switch) {0=None; 1=AeroDisk; 2=AeroDyn; 3=ExtLoads}
1                      CompSeaSt   - Compute sea state information (switch) {0=None; 1=SeaState}
300                    WtrDpth     - Water depth (m)
"IEA-22-280-RWT-Semi_ElastoDyn.dat" EDFile      - Name of file containing ElastoDyn input parameters (quoted string)
"../IEA-22-280-RWT/IEA-22-280-RWT_BeamDyn.dat"  BDBldFile(1) - Name of file containing BeamDyn input parameters for blade 1 (quoted string)
"../IEA-22-280-RWT/IEA-22-280-RWT_BeamDyn.dat"  BDBldFile(2) - Name of file containing BeamDyn input parameters for blade 2 (quoted string)
"../IEA-22-280-RWT/IEA-22-280-RWT_BeamDyn.dat"  BDBldFile(3) - Name of file containing BeamDyn input parameters for blade 3 (quoted string)
"../IEA-22-280-RWT/IEA-22-280-RWT_InflowFile.dat" InflowFile  - Name of file containing inflow wind input parameters (quoted string)
"IEA-22-280-RWT-Semi_AeroDyn15.dat" AeroFile    - Name of file containing aerodynamic input parameters (quoted string)
"IEA-22-280-RWT-Semi_ServoDyn.dat" ServoFile   - Name of file containing control and electrical-drive input parameters (quoted string)
"IEA-22-280-RWT-Semi_SeaState_PotMod.dat"    SeaStFile   - Name of file containing sea state input parameters (quoted string)
"IEA-22-280-RWT-Semi_HydroDyn_PotMod.dat" HydroFile   - Name of file containing hydrodynamic input parameters (quoted string)
"IEA-22-280-RWT-Semi_MoorDyn.dat" MooringFile - Name of file containing mooring system input parameters (quoted string)
10.0                   SttsTime    - Amount of time between screen status messages (s)
1                      OutFileFmt  - Format for tabular (time-marching) output file (switch) {1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both 1 and 2, 4: uncompressed binary [<RootName>.outb, 5: both 1 and 4}
0.0                    Twr_Kdmp    - Damping factor for the tower [used only if CalcSteady=True] (N/(m/s))
0.0                    Bld_Kdmp    - Damping factor for the blades [used only if CalcSteady=True] (N/(m/s))
2                      VTK_type    - Type of VTK visualization data: (switch) {1=surfaces; 2=basic meshes (lines/points); 3=all meshes (debug)} [unused if WrVTK=0]
False                  VTK_fields  - Write mesh fields to VTK data files? (flag) {true/false} [unused if WrVTK=0]
10.0                   VTK_fps     - Frame rate for VTK output (frames per second){will use closest integer multiple of DT} [used only if WrVTK=2]
