Dear OpenFAST team,
I’m running different simulations in OpenFAST in order to understand how the global time step (DT) influences in terms of stability.
My simulation runs stably with DT=0.005 s. Since my goal was to achieve a smoother controller response, I increased it:
- With DT=0.006 s, the simulation still runs fine. From that value upwards, the simulation stops: it doesn’t crash with an explicit error but simply stops progressing.
When this happened to me, I searched the forum for a similar problem, which led me to this thread: PTDM implementation - #15 by Emanuel.Rergis . After reading it, I understood two things;
- The standard rule for an optimal DT is DT<1/(10*f_max)
- Increasing NumCrctn to 1 or more may allow the use of larger time steps. However, even when I set NumCrctn=1 (keeping DT>0.006), the simulation still stops (the 0.005 and 0.006 DT simulations were run dith NumCrctn=0 successfully).
In parallel, I noticed that the log prints this warning when the DT is higher than 0.006:
BEMT_UpdateStates: UA_UpdateStates: Divergent states in UA HGM model
So, I would like to ask:
When you refer to f_max, do you mean the highest frequency of the entire system, regardless of the component?
Could you please clarify how DT and NumCrctn interact numerically? Are there recommended or practical ranges for NumCrctn when increasing DT?
Could this warning message be linked to an inadequate DT - NumCrctn combination?
Any recommendation would be appreciated.
Kepa
