Dear Jason
I have three questions.
①What is ADAMSView?
②Even if I set SaveGrphcs to true in ADAMSFile, the .gra file is not generated.
Is there anything else I need to set?
(Fast V7,Analyzed by test14.)
③Where is the natural frequency output?
Dear Jason
①What is ADAMSView?
Dear @Kazuya.Nishiyama,
Here are my answers:
SaveGrphcs = TRUE does not cause FAST to generate the .gra file, but rather will tell ADAMS to generate the .gra file when the ADAMS simulation is run.FYI: Please note that I have not used ADAMS in many years, so, I doubt I can be much use. I would contact MSC for ADAMS-specific questions.
Dear Jason.
Thank you for your response.
Is there a way to output natural frequencies in FAST-v7?
FAST v7 can expert a linear state-space representation of the turbine, assuming quasi-steady aerodynamics. From the linearized state matrix “A”, you can compute the full-system natural frequencies through an eigenanalysis.
That said, OpenFAST’s linearization capabilties are vastly superior to those of FAST v7, so, I would suggest upgrading to OpenFAST.
Is the process in the order of FAST, MBC, Excel, and then eigenvalue analysis as described in other topics?
We are going with Fast-v7 because we want to use the SEISMIC function.
There are many forum posts that explain the use of FAST v7 + MBC3 + Eigenanalysis for determination of full-system natural frequencies and mode shapes. However, this process is much more convenient in OpenFAST through the Automated Campbell Diagram Code, which automates the process and visualizes the modes: GitHub - OpenFAST/acdc: ACDC: Automated Campbell Diagram Code.
We’ve also discussed how to include Seismic effects in OpenFAST: [Question]How to perform seismic load analysis.
Dear Jason
I should still use openfast.
I still don’t understand the mass, stiffness, damping matrix and the creation of force vectors, so I will study it.
