Hi Jason,
I am trying to build the AERODYN , NWTC library and YAWDYN codes using Visual studio with INTEL VISUAL FORTRAN 2020. You sent me YAWDYN “yd_v1216” source files before and I downloaded the AeroDyn and NWTC library from the link “Historical NWTC repositories · GitHub” . However, when i build the codes i had some problems with the actual and dummy arguments mismatch in type and numbers of different parts of the codes. Specifically, I had errors like these when building Brent.f90 code :
error #6633: The type of the actual argument differs from the type of the dummy argument. [AFINFO] -
error #6784: The number of actual arguments cannot be greater than the number of dummy arguments. [UNCOUPLEDERRFN]
I need help to fix these kind of errors. I know that i do not need this new version of AERODYN to compile YAWDYN. But i am doing this with the purpose of using FAST v7 after working with YAWDYN. As I need to access the furling functions in FAST v7. But for the moment if you could also send me the AERODYN and NWTC libraries that are compatible with this version of YAWDYN this will also help this time.Thanks.
best regards,
Mohamed
