Dear Yinping Yang,
Are you saying that all of the intial conditions for the structural states are the same between FAST and GH Bladed? What about the controller states, such as blade pitch angle? Regardless, the start-up transients may differ between the codes, depending on the differences in theory between them. It is always wise to allow the simulation start-up transients to die out before outputting data and comparing codes.
In FAST, the start-up transients may take 30 seconds or more, depending on the choice of initial conditions, the natural frequencies in the system, and the controller settings. If the wind-inflow is steady, the system will eventually reach a steady-state condition if there is positive damping in all system modes. Setting proper initial conditions for OoPDefl, IPDefl, TTDspFA, TTDspSS, etc. can be used to reduce the length of the start-up transient, but it is typically more convient to just run the simulation longer and only output data after the start-up transients die out.
If the efficiencies FAST is using are less than the efficiencies GH Bladed is using, than certainly the power outputs predicted by the codes will differ. GenEff in FAST is used to calculate how much less the electrical power is compared to the mechanical power in the high-speed shaft (when generating power; this is reversed for motoring during generator start-up of the turbine). GBoxEff in FAST is used to calculate a friction torque in the drivetrain, which also reduces the amount of electircal power (when generating power; this is reveresed for motoring). The intial transients in the model–and anything that causes unsteadiness–can certainly lead to fluctuations in the power.
I don’t know enough about what you are doing to answer your questions regarding “electrical power is always bigger than rated power / controller does not work”.
FAST’s small angle assumption/violation will not trigger a turbine shut down. (For information regarding the small angle assumption/violation, please refer to this post: http://forums.nrel.gov/t/nrel-5mw-controls-dll-interface/183/1.) If the machine is shutting down during a gust, this must be initiated by the control system. What controller settings are you using?
The following papers show some of the latest results in which FAST, GH Bladed, and other codes are compared side-by-side. These papers were written under the IEA Annex 23 Offshore Code Comparison Collobaritive (OC3) project:
nrel.gov/docs/fy07osti/41930.pdf
nrel.gov/docs/fy08osti/42471.pdf
