I’m using OpenFAST v3.0.0 (precompiled) on a Win 10 x64 machine to run the IEA 15-240-RWT-UMaineSemi floating wind turbine (downloaded from the IEAWindTask37 github repository). This is my first run with OpenFAST so I’m using all the given values in this reference turbine.
When executing OpenFAST, MoorDyn is giving the next error (full output next): OpenFAST_command_output.txt (2.72 KB)
Running MoorDyn (v1.01.02F, 8-Apr-2016).
MD_Init: Opening MoorDyn input file: C:\Users\gerar\OpenFAST_precompiled
(v3.0.0)\examples\IEA-15-240-RWT\OpenFAST\IEA-15-240-RWT-UMaineSemi\IEA-15-240-RWT-UMaineSemi_Mo
orDyn.dat
FAST_InitializeAll: MD_Init:MDIO_ReadInput:Failed to read line data for Line 1
OpenFAST encountered an error during module initialization.
Aborting OpenFAST.
I’ve opened MoorDyn’s input (MoorDyn.dat) and ECHO files (MD.ech, both attached), from where one can see that OpenFAST doesn’t get to read the “Line Properties” section correctly, however, after comparing it with other recent public reference models (such as the COREWIND ActiveFloat Semisub and WindCrete spar), I have no clue why OpenFAST is throwing this error.
MoorDyn_input.txt (3.99 KB)
MoorDyn_echo.txt (745 Bytes)
Any help or guidance would be much appreciated.
Many thanks,
Gerard Avellaneda
