OpenFAST Aeroacoustics Inconsistency: Turbulent Inflow Noise
The IEA_LB_RWT model itself doesn’t show this output inconsistency. I was able to figure out the source of error; I was using a TIGrid smaller than the disc area.
You can see this error if you use a grid spacing of 90m with the IEA_LB_RWT model.
To check my understanding of the TIGrid definition, is this how the following grid file should look like?
Total Grid points In Y (lateral), Starts from - radius goes to + radius+
4
Total Grid points In Z (vertical), Starts from bottom tip (hub-radius)
3
Grid spacing In Y (lateral)
40
Grid spacing In Z (vertical)
60
0.1200 0.1200 0.1200 0.1200
0.1100 0.1100 0.1100 0.1100
0.1000 0.1000 0.1000 0.1000
Best,
Sheyma
