I am trying to run a simulation in OpenFAST with active tension control of mooring lines in a floating wind turbine platform. Each line has 5 segments. I am getting the following error message depending on the amplitude of the actuation:
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption1: Active tension command will make a segment shorter than the limit of half its original length.
Is there a way to change or disable the constraint on the minimum segment length?
If my understanding is correct, any commanded variation in cable length is added/subtracted from the length of the last line segment (fairlead connection). Therefore, the discretization of the cable (i.e., number of segments) limits how much the cable can be shortened.
