Hi Jason,
Thanks for your reply.
I have run the model again, this time with GenDOF switched off, and then on.
There doesn’t seem to be any major difference between results, only that when GenDOF is off the simulation aborts at 83.513 seconds and when GenDOF is turned on the simulation aborts at 187.47 seconds.
The error messages received in each case are also slightly different, and are pasted below for further information.
(Note: The images presented and discussed below are from results obtained when GenDOF is switched OFF)
The platform motions seem fine, however platform roll does increase with time. Is this to be expected?
Something funny seems to happen to values, such as roll above and the platform acceleration and rotor speed values shown below, just before the simulation aborts at time t=83.5s. Do you know what might be the cause of this discontinuity?
Regarding the basic response characteristics of the turbine, blade pitch remains constant at 3.83 degrees, as set in the initial condition section of ElastoDyn to match the 12.0 m/s wind speed outlined in Table 7.1 of ‘Definition of a 5MW Reference Wind Turbine for Offshore System Development’.
Rotor speed varies slightly but remains centered around the initial rotor speed of 12.1 rpm.
Any further suggestions would be greatly appreciated.
Thanks and regards,
Stephen Lynch
GenDOF Turned Off Error Message
OpenFAST
Copyright (C) 2021 National Renewable Energy Laboratory
Copyright (C) 2021 Envision Energy USA LTD
See the “LICENSE” file distributed with this software for details.
OpenFAST-v3.0.0
Compile Info:
- Compiler: Intel(R) Fortran Compiler 1900
- Architecture: 64 bit
- Precision: single
- OpenMP: No
- Date: Jun 23 2021
- Time: 21:25:05
Execution Info:
- Date: 08/01/2021
- Time: 21:23:11+0100
OpenFAST input file heading:
FAST Certification Test #24: NREL 5.0 MW Baseline Wind Turbine with OC3 Hywind Configuration,
for use in offshore analysis
Running ElastoDyn.
Running AeroDyn.
AD15 Nodal Outputs: Nodal output section of AeroDyn input file not found or improperly formatted.
Skipping nodal outputs.
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 1, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 2, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 3, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 4, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 1, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 2, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 3, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 4, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 1, blade 3)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 2, blade 3)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 3, blade 3)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 4, blade 3)
Running InflowWind.
Reading a 31x31 grid (145 m wide, 17.5 m to 162.5 m above ground) with a characteristic wind
speed of 12 m/s. This full-field file was generated by TurbSim (v2.00.07a-bjj, 14-Jun-2016) on
26-Jul-2021 at 15:18:48.
Processed 12600 time steps of 20-Hz full-field data (period of 630 seconds).
Running ServoDyn.
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows, ).
Using legacy Bladed DLL interface.
Running HydroDyn.
MAP++ environment properties (set externally)…
Gravity constant [m/s^2] : 9.81
Sea density [kg/m^3] : 1025.00
Water depth [m] : 320.00
Vessel reference position [m] : 0.00 , 0.00 , 0.00
Time: 0 of 300 seconds.
FAST_Solution0:CalcOutputs_And_SolveForInputs:SolveOption2:SrvD_CalcOutput:DLL_controller_call:Run
ning with torque and pitch control of the NREL offshore 5MW baseline wind turbine from DISCON.dll
as written by J. Jonkman of NREL/NWTC for use in the IEA Annex XXIII OC3 studies. Includes
modifications for the Hywind spar.
Time: 83 of 300 seconds. Estimated final completion at 21:25:29.
The BEM solution is being turned off due to low TSR. (TSR = 1.6644). This warning will not be
repeated though the condition may persist. (See GeomPhi output channel.)
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:RotCalcOutput:BEMT_CalcOutput(node 5,
blade 3):UA_CalcOutput:UA_BlendSteady:Temporarily turning off UA due to high angle of attack or
low relative velocity. This warning will not be repeated though the condition may persist.
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:RotCalcOutput:BEMT_CalcOutput(node 12,
blade 1):UA_CalcOutput:Mach number exceeds 0.3. Theory is invalid. This warning will not be
violated in SUBROUTINE SmllRotTrans() due to a large platform displacement (ElastoDyn
SetCoordSy). The solution may be inaccurate. Simulation continuing, but future warnings from
SmllRotTrans() will be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 83.519 s
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:RotCalcOutput:BEMT_CalcOutput(node 7,
blade 3):UA_CalcOutput:Mach number exceeds 1.0. Equations cannot be evaluated.
OpenFAST encountered an error at simulation time 83.513 of 300 seconds.
Aborting OpenFAST.
GenDOF Turned on Error Message:
OpenFAST
OpenFAST-v3.0.0
Compile Info:
- Precision: single
- OpenMP: No
- Date: Jun 23 2021
- Time: 21:25:05
Execution Info:
- Date: 08/02/2021
- Time: 12:27:30+0100
Running ElastoDyn.
Running AeroDyn.
Running InflowWind.
Running ServoDyn.
Running HydroDyn.
Time: 187 of 300 seconds. Estimated final completion at 12:29:52.
Warning: SkewedWakeCorrection encountered a large value of chi (97.239 deg), so the yaw
correction will be limited. This warning will not be repeated though the condition may persist.
See the AD15 chi output channels, and consider turning off the Pitt/Peters skew model (set
SkewMod=1) if this condition persists.
FAST_Solution:FAST_AdvanceStates:AD_UpdateStates:BEMT_UpdateStates:UpdatePhi(node 12, blade
3):BEMT_UnCoupledSolve:There is no valid value of phi for these operating conditions: Vx =
2.1687, Vy = -20.1, rlocal = 40.434, theta = 0.14786, geometric phi = 3.0341. This warning will
not be repeated though the condition may persist. (See GeomPhi output channel.)
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:RotCalcOutput:BEMT_CalcOutput(node 17,
blade 2):UA_CalcOutput:Mach number exceeds 0.3. Theory is invalid. This warning will not be
The BEM solution is being turned off due to low TSR. (TSR = -0.42085). This warning will not be
Additional debugging message from SUBROUTINE SmllRotTrans(): 187.47 s
blade 2):UA_CalcOutput:Mach number exceeds 1.0. Equations cannot be evaluated.
OpenFAST encountered an error at simulation time 187.47 of 300 seconds.
Aborting OpenFAST.
