Hi all, thanks for accepting me to the forum
I have just downloaded the binaries of the OpenFAST 2.2.0 version, and the first thing I am trying is to run the regression tests. I have started with the 5MW_Land_DLL_WTurb tests, except that instead of turbulent wind I am running a steady wind of 12 m.s-1 (and no other modification).
I am plotting the RPM, and I expect it to reach the rated rpm after some transients. It indeed reaches 12.1 rpm, but the transients seem to last longer than I would expect. I have compared the OpenFAST results to those obtained with another software (Ashes), the results are shown below:
I am not yet trying to figure out whether one or the other software is producing more accurate results for this particular case. Ideally, before working on that, I would like to make sure I am using FAST correctly by benchmarking my results against other results produced with OpenFAST. Does anyone know if it’s possible to access the results (as time series) of the nightly tests?
If not, my hypothesis is that the blades have a very large moment of inertia around the blade pitch axis, which causes an overshoot and large oscillations in the pitch angle (see figure below, only results with OpenFAST) and therefore in the RPM.
Any comments/thoughts on this? Can I find the moment of inertia of the blades around the pitch axis somewhere? Or maybe the OpenFAST results are just fine and those oscillations are to be expected?
Thanks a lot,
Loup
Hi Jason, nice to read you
Thanks a lot for your help, that is very useful. In reply to your comments
- I tried to run the regression tests, and finally managed to get some results after a couple of attempts. Most results fail with a tolerance of 1e-3, but the plots seem to indicate that major differences between local and baseline only occur at the beginning of the simulation. The image below is one example, illustrative of what I have been seeing for other output.
I assume there might have been some code changes between the release of OpenFAST v2.2.0 and the current baseline results? In any case, I’m happy enough with the comparison.
Good point, I hadn’t thought about that. Agree that with ElastoDyn the inertia about the pitch axis won’t affect the results
Yes, the blade pitch was initialized at 0, because that’s what I was doing in Ashes as well (so the RPM comparison between the 2 software was done with the same initial conditions, for pitch and RPM). But at this stage I think I can live with this, especially if that doesn’t strike you as wrong.
Thanks again for your reply,
Loup
Dear Loup,
Yes, I’m not too happy with the pass/fail criteria currently used in r-test From my experience, very minor changes to the source code or compile settings result in many cases “failing” even though the time-series solution appears nearly identical, and certainly within engineering accuracy. I believe Rafael Mudafort is working to improve the pass/fail criteria, but I’m not sure as to the status, as I’m not directly involved in that.
Otherwise, I’m glad you are not getting the results you expect.
