Hi Bonnie,
First of all, thanks for your quick answers.
I have been able to acquire the dll and the library files. But when I try to simulate with Adams the “acf” or “adm” files obtained from the Fast simulation, I get the next errors:
[code]C:\Users\Nagore\Desktop\Fast v7\Prueba 5>adams2013_2_x64
| | Adams 2013.2 | |
|Action Selection Code|
|Create Adams/Solver with |
| Adams User-DLL cr-user |
|Run Adams/Solver with |
| Standard Adams executable ru-standard|
| User executable ru-user |
|Pre- or Post-process with |
| Adams/View aview |
| Adams/Car acar |
| Adams/Driveline adriveline |
| Adams/PostProcessor appt |
| Adams/Insight ainsight |
| Adams/Flex Toolkit flextk |
| Adams/Durability Toolkit durtk |
| MSC Registry Editor redit |
| MSC Registry Shell Tool rtool |
| Custom Memory Model (uconfg_user) cmm |
Enter your selection code or EXIT: ru-user
Enter name of your Adams/Solver User-DLL, or EXIT:
ADAMS.dll
Enter the name of the Adams command file or EXIT (=none):
Test01_ADAMS.acf
#. MSC Software |
## ##’ A d a m s C++ S o l v e r |
| #### [Build: 2013.2.0-CL221316] |
| ###. Version: 2013.2 |
| ####. Patch Version: None | | .###
# http://www.mscsoftware.com |
| * MSC Software Corporation * |
| * A d a m s * |
| * Automatic Dynamic Analysis of Mechanical Systems * |
| * LEGAL INFORMATION * |
| * Warning: This computer program is protected by copyright law * |
| * and international treaties. Unauthorized reproduction or * |
| * distribution of this computer program, or any portion of it, * |
| * may result in severe civil and criminal penalties. * |
| * Copyright (C) 2013 MSC Software Corporation and its licensors. * |
| * All rights reserved. * |
* Local Time: 2015-03-24 14:28:31 * |
* Host Name: Nagore1 * |
* Uname: MS Windows NT * |
* OS Info: 6.2 * |
* User: Nagore * |
* Customer ID: 0897E1FA-D938F5BC * |
* Current dir: C:\Users\Nagore\Desktop\Fast v7\Prueba 5 * |
command: FILE/MODEL=Test01_ADAMS, OUTPUT_PREFIX=Test01_ADAMS
Running NWTC Subroutine Library (v1.07.02a-mlb, 21-May-2013).
Running A2AD (v13.01.00a-bjj, 15-Feb-2012).
| Model Title |
| !ADAMS/View model name: FAST certification Test #01: AWT-27CR2 with many DOFs
wi|
command: INTEGRATOR/GSTIFF, ERROR = 0.001, HMAX = 4.000000E-03, INTERPOLATE =
ON
command: SIMULATE/DYNAMICS, END = 4.000000E-03, DTOUT = 2.000000E-02
Begin Simulation
****** Performing Dynamic Simulation using Gstiff I3 Integrator ******
---- START: WARNING ----
The data set is kinematically determinate. However, a dynamic analysis
has been requested. A kinematic analysis with the SIMULATE/KINEMATICS
command would be more efficient and possibly more accurate for some of
the computed quantities.
As requested, the simulation will continue with a dynamic analysis.
---- END: WARNING ----
The system is modelled with INDEX-3 DAEs.
The integrator is GSTIFF, CORRECTOR = original
Integration error = 1.000000E-03
Detected system force units of kilonewtons (kN).
---- START: ERROR ----
GFOSUB(11010, 1, 1) has been illegally defined. A new functional dependency on
the measure
TDISP(4000,1,1) has been encountered during execution.
---- END: ERROR ----
Error calling INFARY for hub position coordinates.
Aborting A2AD.[/code]
I want to make that simulation, so can you help me with the errors I have obtained?
Thank you very much,
Nagore
