I’m using:
- Adams 2008
- Intel Visual Fortran 2013
- Microsoft Visual Studio 2010
- Fast
I’m triying to create de .dll with de CompileLinkA2AD.bat, mi script is:
[code]ECHO OFF
REM ----------------------------------------------------------------------------
REM                   set compiler internal variables
REM    You can run this bat file from the IVF compiler’s command prompt (and not
REM    do anything in this section). If you choose not to run from the IVF command
REM    prompt, you must call the compiler’s script to set internal variables.
REM    TIP: Right click on the IVF Compiler’s Command Prompt shortcut, click
REM    properties, and copy the target (without cmd.exe and/or its switches) here:
REM …
REM See this forum topic for instructions and help with setting the compiler
REM internal variables in this script:
REM    Instructions for Compiling FAST
REM …
REM IF “%INTEL_SHARED%”==“” CALL “CALL “C:\Archivos de programa\Intel\Composer XE 2013\bin\IFORTVARS.bat”
IF “%INTEL_SHARED%”==”" CALL “C:\Archivos de programa\Intel\Composer XE 2013\bin\IFORTVARS.bat” ia32
REM -------------------- LOCAL VARIABLES ---------------------------------------
SET ROOT_NAME=ADAMS
REM -------------------- LOCAL PATHS ------------------------------------------
REM --USERS WILL NEED TO EDIT THESE PATHS TO POINT TO FOLDERS ON THEIR LOCAL MACHINES:
REM A2AD_Loc     is the location of the ADAMS-to-AeroDyn source files.
REM AeroDyn_Loc  is the location of the AeroDyn source files.
REM Wind_Loc     is the location of the InflowWind souce files.
REM FAST_LOC     is the location of the FAST source files: FFTMod.f90, HydroCalc.f90, fftpack.f, UserSubs.f90, and possibly PitchCntrl_ACH.f90, UserVSCont_KP.f90, and/or BladedDLLInterface.f90.
REM NWTC_Lib_Loc is the location of the NWTC subroutine library files.
REM NOTE: DO NOT USE QUOTATION MARKS HERE (AROUND THE PATH NAMES)
REM       OR THE FILE CONCATENATION BELOW WILL NOT WORK
SET NWTC_Lib_Loc=C:\Documents and Settings\Lucia\Escritorio\PROYECTO\NWTC_Lib\source
SET AeroDyn_Loc=C:\Documents and Settings\Lucia\Escritorio\PROYECTO\AERODYN\Source
SET Wind_Loc=C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source
SET FAST_Loc=C:\Documents and Settings\Lucia\Escritorio\PROYECTO\FAST\Source
SET A2AD_Loc=C:\Documents and Settings\Lucia\Escritorio\PROYECTO\ADAMSADAMS\Source
REM -------- please note that all source files must have a blank line ----------
REM --------   at the end so that they can be concatenated properly   ----------
SET NWTC_Files=
SET NWTC_Files=%NWTC_Files%   “%NWTC_Lib_Loc%\SingPrec.f90”
SET NWTC_Files=%NWTC_Files% + “%A2AD_Loc%\SysIVF_ADAMS.f90”
SET NWTC_Files=%NWTC_Files% + “%NWTC_Lib_Loc%\NWTC_IO.f90”
SET NWTC_Files=%NWTC_Files% + “%NWTC_Lib_Loc%\NWTC_Num.f90”
SET NWTC_Files=%NWTC_Files% + “%NWTC_Lib_Loc%\NWTC_Aero.f90”
SET NWTC_Files=%NWTC_Files% + “%NWTC_Lib_Loc%\ModMesh.f90”
SET NWTC_Files=%NWTC_Files% + “%NWTC_Lib_Loc%\NWTC_Library.f90”
SET Wind_Files=
SET Wind_Files=%Wind_Files%   “%Wind_Loc%\SharedInflowDefs.f90”
SET Wind_Files=%Wind_Files% + “%Wind_Loc%\HHWind.f90”
SET Wind_Files=%Wind_Files% + “%Wind_Loc%\FFWind.f90”
SET Wind_Files=%Wind_Files% + “%Wind_Loc%\HAWCWind.f90”
SET Wind_Files=%Wind_Files% + “%Wind_Loc%\FDWind.f90”
SET Wind_Files=%Wind_Files% + “%Wind_Loc%\CTWind.f90”
SET Wind_Files=%Wind_Files% + “%Wind_Loc%\UserWind.f90”
SET Wind_Files=%Wind_Files% + “%Wind_Loc%\InflowWindMod.f90”
SET AeroDyn_Files=
SET AeroDyn_Files=%AeroDyn_Files%   “%AeroDyn_Loc%\SharedTypes.f90”
SET AeroDyn_Files=%AeroDyn_Files% + “%AeroDyn_Loc%\AeroMods.f90”
SET AeroDyn_Files=%AeroDyn_Files% + “%AeroDyn_Loc%\GenSubs.f90”
SET AeroDyn_Files=%AeroDyn_Files% + “%AeroDyn_Loc%\AeroSubs.f90”
SET AeroDyn_Files=%AeroDyn_Files% + “%AeroDyn_Loc%\AeroDyn.f90”
SET Fixed_Files =
SET Fixed_Files=%Fixed_Files%   “%FAST_Loc%\fftpack.f”
SET FAST_Files=
SET FAST_Files=%FAST_Files%   “%FAST_Loc%\FFTMod.f90”
SET FAST_Files=%FAST_Files% + “%FAST_Loc%\HydroCalc.f90”
SET FAST_Files=%FAST_Files% + “%A2AD_Loc%\FAST_params.f90”
IF /I “%1”==“DLL” GOTO dllFiles
SET FAST_Files=%FAST_Files% + “%FAST_Loc%\UserSubs.f90”
SET FAST_Files=%FAST_Files% + “%FAST_Loc%\UserVSCont_KP.f90”
SET FAST_Files=%FAST_Files% + “%FAST_Loc%\PitchCntrl_ACH.f90”
GOTO endFASTfiles
:dllFiles
SET FAST_Files=%FAST_Files% + “%FAST_LOC%\UserSubs_forBladedDLL.f90”
SET FAST_Files=%FAST_Files% + “%FAST_LOC%\UserVSCont_KP_forBladedDLL.f90”
SET FAST_Files=%FAST_Files% + “%FAST_LOC%\BladedDLLInterface.f90”
REM NOTE: UserSubs_forBladedDLL.f90 is a copy of UserSubs.f90 with SUBROUTINES UserHSSBr() and UserYawCont() commented out
REM       UserVSCont_KP_forBladedDLL.f90 is a copy of UserVSCont_KP.f90 with SUBROUTINE UserVSCont() commented out
:endFASTfiles
SET A2AD_Files=
SET A2AD_Files=%A2AD_Files%   “%A2AD_Loc%\A2AD_Mod.f90”
SET A2AD_Files=%A2AD_Files% + “%A2AD_Loc%\Adams_subs.f90”
REM echo File list
REM ----------- Concatenate them into one file for free-format -----------------
REM ----------- Fortran and one file for fixed-format Fortran  -----------------
COPY %NWTC_Files% + %Wind_Files% + %AeroDyn_Files% + %FAST_Files% + %A2AD_Files%  %ROOT_NAME%.f90
COPY %Fixed_Files% %ROOT_NAME%.f
REM ------- SET CREATE OBJECT FILE BASED ON SPECIFIED COMPILER -----------------
REM --------------------- Intel visual FORTRAN ---------------------------------
REM ---------------------   with Adams 2008R1  ---------------------------------
REM …
REM … set compiler options …
REM …
REM SET COPTS= /c /automatic /architecture:pn4 /Ob2 /MD /Gm /O1     /traceback /real_size:32 /assume:byterecl /stand:f95 /check:bounds
REM SET COPTS= /c /automatic /architecture:pn4 /Ob2 /MD /Gm /Ot /O3 /traceback /real_size:32 /assume:byterecl /stand:f95  /Qdiag-disable:5268
SET COPTS= /c /automatic /Ob2 /MD /Gm /traceback /Qzero /Qsave /real_size:32 /assume:byterecl  /Qdiag-disable:5268
REM …
REM … compile …
REM …
ECHO.
ECHO Compiling ADAMS2AD and AeroDyn routines to create ADAMS.obj:
ifort %COPTS% /object:%ROOT_NAME%.obj %ROOT_NAME%.f90
ifort %COPTS% /object:%ROOT_NAME%f.obj %ROOT_NAME%.f
REM …
REM … link with Adams …
REM …
ECHO Linking ADAMS2AD and AeroDyn routines with ADAMS 2008r1:
SET DLLName=%ROOT_NAME%08r1
IF /I “%1”==“DLL” SET DLLName=%DLLName%_forBladedDLL
CALL C:\MSC.Software\MD_Adams\R3\common\mdi.bat cr-user n %ROOT_NAME%.obj %ROOT_NAME%f.obj -n %DLLName%.dll exit < NewLine.txt
GOTO end
:end
REM ------------------------- CLEAR MEMORY -------------------------------------
REM ------------- and delete all .mod and .obj files ---------------------------
REM ECHO
DEL *.mod
DEL *.obj
SET MyCompiler=
SET DF_LOC=
SET IVF_LOC=
SET ROOT_NAME=
SET COPTS=
SET NWTC_Files=
SET Wind_Files=
SET AeroDyn_Files=
SET FAST_Files=
SET A2AD_Files=
SET Fixed_Files=
SET NWTC_Lib_Loc=
SET Wind_Loc=
SET AeroDyn_Loc=
SET A2AD_Loc=
SET FAST_Loc=
SET DLLName=[/code]
When I execute it in the cmd, I find this errors:
[code]C:\Documents and Settings\Lucia\Escritorio\PROYECTO\ADAMSADAMS\DLL>CompileLinkA2
AD.bat
Intel(R) Parallel Studio XE 2013
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
Intel(R) Composer XE 2013 Update 3 (package 171)
Setting environment for using Microsoft Visual Studio 2010 x86 tools.
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\NWTC_Lib\source\SingPrec.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\ADAMSADAMS\Source\SysIVF_ADA
MS.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\NWTC_Lib\source\NWTC_IO.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\NWTC_Lib\source\NWTC_Num.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\NWTC_Lib\source\NWTC_Aero.f9
0
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\NWTC_Lib\source\ModMesh.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\NWTC_Lib\source\NWTC_Library
.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source\SharedInfl
owDefs.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source\HHWind.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source\FFWind.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source\HAWCWind.f
90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source\FDWind.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source\CTWind.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source\UserWind.f
90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\inflowWind\Source\InflowWind
Mod.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\AERODYN\Source\SharedTypes.f
90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\AERODYN\Source\AeroMods.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\AERODYN\Source\GenSubs.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\AERODYN\Source\AeroSubs.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\AERODYN\Source\AeroDyn.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\FAST\Source\FFTMod.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\FAST\Source\HydroCalc.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\ADAMSADAMS\Source\FAST_Param
s.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\FAST\Source\UserSubs.f90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\FAST\Source\UserVSCont_KP.f9
0
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\FAST\Source\PitchCntrl_ACH.f
90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\ADAMSADAMS\Source\A2AD_Mod.f
90
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\ADAMSADAMS\Source\Adams_Subs
.f90
1 archivos copiados.
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 1
3.1.1.171 Build 20130313
ifort: command line remark #10010: option ‘/automatic’ is deprecated and will be
removed in a future release. See ‘/help deprecated’
ifort: command line warning #10121: overriding ‘/automatic’ with ‘/Qsave’
30 DAY EVALUATION LICENSE
ifort: NOTE: The evaluation period for this product ends on 7-jun-2013 UTC.
ADAMS.f90(996): error #6848: This attribute specification is valid only in the s
pecification part of a module.   [PUBLIC]
TYPE, PUBLIC :: ProgDesc
ADAMS.f90(1002): error #6848: This attribute specification is valid only in the
specification part of a module.   [PUBLIC]
TYPE, PUBLIC :: FASTdataType
! The derived type for holding FAST binary output data.
ADAMS.f90(1159): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLCARY1]
SUBROUTINE AllCAry1 ( Ary, AryDim, Descr, ErrStat )
ADAMS.f90(1192): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLCARY2]
SUBROUTINE AllCAry2 ( Ary, AryDim1, AryDim2, Descr, ErrStat )
ADAMS.f90(1225): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLCARY3]
SUBROUTINE AllCAry3 (  Ary, AryDim1, AryDim2, AryDim3, Descr, ErrStat )
ADAMS.f90(1261): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLIARY1]
SUBROUTINE AllIAry1 ( Ary, AryDim, Descr, ErrStat )
ADAMS.f90(1293): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLIARY2]
SUBROUTINE AllIAry2 (  Ary, AryDim1, AryDim2, Descr, ErrStat )
ADAMS.f90(1326): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLIARY3]
SUBROUTINE AllIAry3 (  Ary, AryDim1, AryDim2, AryDim3, Descr, ErrStat )
ADAMS.f90(1361): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLLARY1]
SUBROUTINE AllLAry1 ( Ary, AryDim, Descr, ErrStat )
ADAMS.f90(1395): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLLARY2]
SUBROUTINE AllLAry2 (  Ary, AryDim1, AryDim2, Descr, ErrStat )
ADAMS.f90(1430): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLLARY3]
SUBROUTINE AllLAry3 (  Ary, AryDim1, AryDim2, AryDim3, Descr, ErrStat )
ADAMS.f90(1466): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLRARY1]
SUBROUTINE AllRAry1 ( Ary, AryDim, Descr, ErrStat )
ADAMS.f90(1500): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLRARY2]
SUBROUTINE AllRAry2 (  Ary, AryDim1, AryDim2, Descr, ErrStat )
ADAMS.f90(1535): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLRARY3]
SUBROUTINE AllRAry3 (  Ary, AryDim1, AryDim2, AryDim3, Descr, ErrStat )
ADAMS.f90(1571): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [ALLRARY4]
SUBROUTINE AllRAry4 (  Ary, AryDim1, AryDim2, AryDim3, AryDim4, Descr, ErrSta
t )
ADAMS.f90(1998): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [DISPNVD0]
SUBROUTINE DispNVD0
ADAMS.f90(2012): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [DISPNVD1]
SUBROUTINE DispNVD1 ( ProgInfo )
ADAMS.f90(2030): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [DISPNVD2]
SUBROUTINE DispNVD2 ( Name, Ver )
ADAMS.f90(2357): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [INT2LSTR]
FUNCTION Int2LStr ( Intgr )
ADAMS.f90(2990): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [R2LSTR4]
FUNCTION R2LStr4 ( FltNum )
ADAMS.f90(3025): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [R2LSTR8]
FUNCTION R2LStr8 ( FltNum )
ADAMS.f90(3060): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [R2LSTR16]
FUNCTION R2LStr16 ( FltNum )
ADAMS.f90(3096): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [READCARY]
SUBROUTINE ReadCAry ( UnIn, Fil, CharAry, AryLen, AryName, AryDescr, ErrStat
ADAMS.f90(3140): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [READCARYLINES]
SUBROUTINE ReadCAryLines ( UnIn, Fil, CharAry, AryLen, AryName, AryDescr, Err
Stat )
ADAMS.f90(3226): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [READCVAR]
SUBROUTINE ReadCVar ( UnIn, Fil, CharVar, VarName, VarDescr, ErrStat )
ADAMS.f90(3570): error #6275: This statement is invalid for an internal procedur
e
CONTAINS
ADAMS.f90(3616): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [READIARY]
SUBROUTINE ReadIAry ( UnIn, Fil, IntAry, AryLen, AryName, AryDescr, ErrStat )
ADAMS.f90(3662): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [READIVAR]
SUBROUTINE ReadIVar ( UnIn, Fil, IntVar, VarName, VarDescr, ErrStat )
ADAMS.f90(3712): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [READLARY]
SUBROUTINE ReadLAry ( UnIn, Fil, LogAry, AryLen, AryName, AryDescr, ErrStat )
ADAMS.f90(3759): error #8095: The name of the internal procedure conflicts with
a procedure name in the MODULE PROCEDURE statement.   [READLVAR]
SUBROUTINE ReadLVar ( UnIn, Fil, LogVar, VarName, VarDescr, ErrStat )
ADAMS.f90(4574): catastrophic error: Too many errors, exiting
compilation aborted for ADAMS.f90 (code 1)
*** Error:  File ADA not found.
Enter name of next user object or source file (=none),  or EXIT:
forrtl: severe (24): end-of-file during read, unit -4, file CONIN$
Image              PC        Routine            Line        Source
libifcoremd.dll    1003E1F6  Unknown               Unknown  Unknown
libifcoremd.dll    1003B480  Unknown               Unknown  Unknown
libifcoremd.dll    100034F6  Unknown               Unknown  Unknown
libifcoremd.dll    10003109  Unknown               Unknown  Unknown
libifcoremd.dll    1006648A  Unknown               Unknown  Unknown
cru.exe            004038AA  Unknown               Unknown  Unknown
cru.exe            00407350  Unknown               Unknown  Unknown
cru.exe            00405545  Unknown               Unknown  Unknown
kernel32.dll       7C81776F  Unknown               Unknown  Unknown
[/code]
I don’t know if the error could be of the Compiler, if the IVF 2013 version it’s not compatible with the ADAMS 2008. Could help me, please?
In the other hand, in other older post, you said me:
If you can use Adams 2008 and aren’t making changes to any of the A2AD source code, you can use the dlls supplied in the A2AD archive instead of trying to compile them.
Well, I try to do in this way. I follow this steps:
1- run “ADAMS - Commnad”
2- choose “ru-user”
3- User DLL: “\ADAMS08r1.dll”
4- Adams command file: “\Test01_ADAMS.acf”
The command window closes quickly, and I could not see any error message on it. But I run the normal cmd, and I call the Test01_ADAMS.acf to see the errors and I get:
[code]C:\Documents and Settings\Lucia\Escritorio\PROYECTO\PRUEBA>test01_ADAMS.acf
                    LEGAL INFORMATION                         *
- Warning:  This computer  program is protected  by copyright law  *
- and  international  treaties.    Unauthorized  reproduction  or  *
- distribution  of this  computer program, or any  portion of it,  *
- may result in severe civil and criminal penalties.               *
- Copyright (C) 2008 MSC.Software Corporation and  its licensors.  *
                   All rights reserved.                       *
- This computer program may contain certain  third-party software  *
- that is protected by  copyright and licensed from  MSC.Software  *
- suppliers.  Portions of this  software are owned by UGS Corp.    *
- (C)  Copyright  1997.    All  Rights  Reserved.    Portions,     *
- (C) 1998 Spacetec IMC Corporation (“Spacetec”).                  *
- The  MSC.Software logo,  MSC,  MSC Adams,  MD Adams,  Adams and  *
- Adams/  are trademarks or registered trademarks of MSC.Software  *
- Corporation  or its  subsidiaries in  the United States  and/or  *
- other   countries.   FLEXlm  is  a   registered   trademark  of  *
- Macrovision Corporation. Parasolid is a registered trademark of  *
- UGS  Corp.   All  other trademarks are  the property  of  their  *
- respective owners.                                               *
                 A d a m s / S o l v e r                      *
 2013-05-30 11:17:47              Version MD R3               *
 Customer Entitlement ID:         56943D12-BC5G45FC           *
Enter ADAMS model file name or Carriage Return or ? (or STOP):
C:\Documents and Settings\Lucia\Escritorio\PROYECTO\PRUEBA\test01_ADM.adm
Enter ADAMS output file name or ? (default is same as input):
 Adams model file ..
 adm
Default file names for output files
 Tabular output file:
 out
 Diagnostic file    :
 msg
 Message Database file    :
 mdb
 Graphics file      :
 gra
 Request file       :
 req
 Results file       :
 res
Input Phase - Reading in Model
Adams/Solver dataset Title:
!ADAMS/View model name: FAST certification Test #01: AWT-27CR2 with many DOFs
wi
Reading of model complete.
Input Phase - Populating Solver database
---- WARNING ----
IP data specified for PART test01_ADM.Nacelle_P is not physically
meaningful, since it does not satisfy the requirement
that Ixx + Iyy must be greater than or equal to Izz.
The moments of inertia about the Center of Mass are:
Ixx = 9.9990E-04, Iyy = 9.9990E-04, Izz = 4418.0
---- WARNING ----
IP data specified for PART test01_ADM.Generator_P is not physically
that Iyy + Izz must be greater than or equal to Ixx.
Ixx = 30000., Iyy = 9.9990E-04, Izz = 9.9990E-04
Input Phase Complete.
CPU time is 4.68750E-02 seconds.
---- ERROR ----
Subroutine SFOSUB is not supplied for SFORCE test01_ADM.Generator_SF.
  Adams/Solver execution terminated by subprogram NO_USERSUB
CPU time used = 4.68750E-02 seconds
[/code]
I don’t know if the error here it’s about de dll.
Please I need your help, I’m very stressed becuase when I can overcome a mistake, I find another.
Thanks of all. Lucia
