Hi All,
I get different Thrust values when I run the rated wind case in power production.
Everrything else remains same as in setup, just changing Discon.dll from libdiscon.dll controller gives ~4MNm instead of 2.78MNm as reported in the IEA 15MW report at rated wind speed.
Could anyone here explain the reason, please?
Ramesh
Dear @Ramesh.Kumar,
Can you clarify what two controllers you are comparing? Where did you obtain the Discon.dll and libdiscon.dll controllers you are using?
Dear @Jason.Jonkman
I did run the latest release IEA-15MW setup files- Monopile example
- Discon.dll available with latest [OpenFAST 3.5.3] gives ~ 4MNm of Thrust (Release v3.5.3 · OpenFAST/openfast · GitHub)
- libdiscon.dll available at ROSCO 2.8.0 with same OpenFAST executable and IEA 15MW gives ~ 2.8MNm
Ramesh
Dear @Ramesh.Kumar,
The DISCON.dll controller available with the release of OpenFAST is specifically set up for the NREL 5-MW baseline wind turbine; this controller should not be used with the IEA Wind 15-MW RWT without changing its parameters and recompiling the DLL.
The OpenFAST models of the IEA Wind 15-MW RWT by default use ROSCO for the controller.
