Dear NREL team,
I am running an openFAST simulation of the 15-MW offshore reference turbine in an under rated, rated and above rated turbulent condition (8, 10.6 and 14 m/s) generated with the use of Turbsim (V2.00.08 64-bit). For verification purposes, I fixed all translations and rotations of the floater, as well as I am ignoring structural deformation of the wind turbine tower and wind turbine blades.
When using the DISCON.dll wind turbine controller (+ DISCON-UMaineSemi.IN obtained from GitHub) with correction for the floating application, only the wind turbine responses for the rated condition (10.6 m/s) seem to behave incorrect with respect to the steady state value (see figure). The turbine responses for the under (8.0 m/s) and above rated (14 m/s) conditions behave like expected around the steady-state values.
Is there a reason for this control behavior at rated wind speed?
Peter Veldman
