Dear @Jason.Jonkman,
Thank you for your response. For your better understanding of my issue, here I attach the files of one simulation where the blades are set to assess free decay behavior. I changed NumCrctn to 5 this time, I also tried other values but unfortunately OpenFAST keeps crashing if I enable both BeamDyn and the structural controller. When I use this configuration and enable ElastoDyn instead however, I obtain reasonable blade responses, as observed in the next figure.
IEA 15 MW offshore reference model monopile configuration
False Echo - Echo input data to "<RootName>.ech" (flag)
"default" DT Integration time step (s)
False YawDOF - Yaw DOF (flag)
False PtfmSgDOF - Platform horizontal surge translation DOF (flag)
False PtfmSwDOF - Platform horizontal sway translation DOF (flag)
0 RotSpeed - Initial or fixed rotor speed (rpm)
0.0 PtfmSurge - Initial or fixed horizontal surge translational displacement of platform (meters)
0.0 PtfmSway - Initial or fixed horizontal sway translational displacement of platform (meters)
0.0 PtfmHeave - Initial or fixed vertical heave translational displacement of platform (meters)
0.0 PtfmRoll - Initial or fixed roll tilt rotational displacement of platform (degrees)
0.0 PtfmPitch - Initial or fixed pitch tilt rotational displacement of platform (degrees)
0.0 PtfmYaw - Initial or fixed yaw rotational displacement of platform (degrees)
120.97 TipRad - The distance from the rotor apex to the blade tip (meters)
3.97 HubRad - The distance from the rotor apex to the blade root (meters)
-4.0 PreCone(1) - Blade 1 cone angle (degrees)
-4.0 PreCone(2) - Blade 2 cone angle (degrees)
-4.0 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
-12.097571763912535 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
0.0 ShftGagL - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
0 ShftTilt - Rotor shaft tilt angle (degrees)
-5.125 NacCMxn - Downwind distance from the tower-top to the nacelle CM (meters)
4.315 NacCMzn - Vertical distance from the tower-top to the nacelle CM (meters)
0.0 NcIMUxn - Downwind distance from the tower-top to the nacelle IMU (meters)
0.0 NcIMUzn - Vertical distance from the tower-top to the nacelle IMU (meters)
4.349459414248071 Twr2Shft - Vertical distance from the tower-top to the rotor shaft (meters)
144.386 TowerHt - Height of tower above ground level [onshore] or MSL [offshore] (meters)
15. TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
0.0 PtfmCMxt - Downwind distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
0.0 PtfmCMyt - Lateral distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
15. PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
15. PtfmRefzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform reference point (meters)
0.0 TipMass(1) - Tip-brake mass, blade 1 (kg)
0.0 TipMass(2) - Tip-brake mass, blade 2 (kg)
0.0 TipMass(3) - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
69131 HubMass - Hub mass (kg)
969952 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
1836784 GenIner - Generator inertia about HSS (kg m^2)
644857 NacMass - Nacelle mass (kg)
32929058 NacYIner - Nacelle inertia about yaw axis (kg m^2)
28249 YawBrMass - Yaw bearing mass (kg)
0.0 PtfmMass - Platform mass (kg)
0.0 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
0.0 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
100000000.0 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
50 BldNodes - Number of blade nodes (per blade) used for analysis (-)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile1 - Name of file containing properties for blade 1 (quoted string)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile2 - Name of file containing properties for blade 2 (quoted string)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile3 - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
100.0 GBoxEff - Gearbox efficiency (%)
1.0 GBRatio - Gearbox ratio (-)
69737644900.0 DTTorSpr - Drivetrain torsional spring (N-m/rad)
49418406.0 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
"unused" FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
"../IEA-15-240-RWT-Monopile/IEA-15-240-RWT-Monopile_ElastoDyn_tower.dat" TwrFile - Name of file containing tower properties (quoted string)
True SumPrint - Print summary data to "<RootName>.sum" (flag)
"ES10.3E2" OutFmt - Format used for text tabular output (except time). Resulting field should be 10 characters. (quoted string) (currently unused)
0.0 TStart - Time to begin tabular output (s) (currently unused)
1 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
20 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0] TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0] TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
5, 9, 13 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0] BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0] BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
"Azimuth"
"BldPitch1"
"BldPitch2"
"BldPitch3"
"GenSpeed"
"IPDefl1"
"NacYaw"
"OoPDefl1"
"RotSpeed"
"RotThrust"
"RotTorq"
"TTDspTwst"
"TipDxb1"
"TipDyb1"
"TipDxb2"
"TipDyb2"
"TipDxb3"
"TipDyb3"
------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
False Echo - Echo input data to <RootName>.ech (flag)
"default" DT - Communication interval for controllers (s) (or "default")
0 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
2.0 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2.0 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2.0 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0.0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
0 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
1 GenModel - Generator model {1: simple, 2: Thevenin, 3: user-defined from routine UserGen} (switch) [used only when VSContrl=0]
95.756 GenEff - Generator efficiency [ignored by the Thevenin and user-defined generator models] (%)
7.559987120819503 VS_RtGnSp - Rated generator speed for simple variable-speed generator control (HSS side) (rpm) [used only when VSContrl=1]
19624046.66639 VS_RtTq - Rated generator torque/constant generator torque in Region 3 for simple variable-speed generator control (HSS side) (N-m) [used only when VSContrl=1]
343357.4355671095 VS_Rgn2K - Generator torque constant in Region 2 for simple variable-speed generator control (HSS side) (N-m/rpm^2) [used only when VSContrl=1]
2. VS_SlPc - Rated generator slip percentage in Region 2 1/2 for simple variable-speed generator control (%) [used only when VSContrl=1]
100 TEC_NPol - Number of poles [even integer > 0] (-) [used only when VSContrl=0 and GenModel=2]
0 THSSBrDp - Time to initiate deployment of the HSS brake (s)
9999.9 HSSBrDT - Time for HSS-brake to reach full deployment once initiated (sec) [used only when HSSBrMode=1]
0 TYCOn - Time to enable active yaw control (s) [unused when YCMode=0]
0.0 YawNeut - Neutral yaw position--yaw spring force is zero at this yaw (degrees)
8458453511.0 YawSpr - Nacelle-yaw spring constant (N-m/rad)
28561762.0 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
0.25 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
---------------------- Aerodynamic Flow Control -------------------------------------
0 AfCmode - Airfoil control mode {0- none, 1- cosine wave cycle, 4- user-defined from Simulink/Labview, 5- user-defined from Bladed-style DLL}
0.0 AfC_Mean - Mean level for sinusoidal cycling or steady value (-) [used only with AfCmode==1]
0.0 AfC_Amp - Amplitude for for cosine cycling of flap signal (AfC = AfC_Amp*cos(Azimuth+phase)+AfC_mean) (-) [used only with AfCmode==1]
0.0 AfC_phase - Phase relative to the blade azimuth (0 is vertical) for for cosine cycling of flap signal (deg) [used only with AfCmode==1]
---------------------- STRUCTURAL CONTROL ---------------------------------------
1 NumBStC - Number of blade structural controllers (integer)
"FDT_wTMD_15MW_98_mLoc_0.03_massRatio_StC15MW.dat" BStCfiles - Name of the file for blade tuned mass damper (quoted string) [unused when CompNTMD is false]
0 NumNStC - Number of nacelle structural controllers (integer)
"unused" NStCfiles - Name of the file for nacelle tuned mass damper (quoted string) [unused when CompNTMD is false]
0 NumTStC - Number of tower structural controllers (integer)
"unused" TStCfiles - Name of the file for tower tuned mass damper (quoted string) [unused when CompNTMD is false]
0 NumSStC - Number of sbustructure structural controllers (integer)
"unused" SStCfiles - Name of the file for sbustructure tuned mass damper (quoted string) [unused when CompNTMD is false]
---------------------- CABLE CONTROL ----------------------------------------
0 CCmode - Cable control mode {0- none, 4- user-defined from Simulink/Labview, 5- user-defineAfC_phased from Bladed-style DLL}
"../IEA-15-240-RWT/ServoData/libdiscon.dll" DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
"IEA-15-240-RWT-Monopile_DISCON.IN" DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
"DISCON" DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
"default" DLL_DT - Communication interval for dynamic library (s) (or "default") [used only with Bladed Interface]
False DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
9999.9 BPCutoff - Cuttoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0.0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0.0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0.0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0.0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0.0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0.0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0.0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0.0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0.0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0.0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0.0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0.0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
True SumPrint - Print summary data to <RootName>.sum (flag) (currently unused)
"GenPwr"
"GenTq"
"BStC1_B1_XQ"
"BStC1_B1_YQ"
"BStC1_B2_XQ"
"BStC1_B2_YQ"
"BStC1_B3_XQ"
"BStC1_B3_YQ"
------- STRUCTURAL CONTROL (StC) INPUT FILE ----------------------------
Input file for tuned mass damper, module by Matt Lackner, Meghan Glade, and Semyung Park (UMass)
True Echo - Echo input data to <RootName>.ech (flag)
---------------------- StC DEGREES OF FREEDOM ----------------------------------
1 StC_DOF_MODE - DOF mode (switch) {0: No StC or TLCD DOF; 1: StC_X_DOF, StC_Y_DOF, and/or StC_Z_DOF (three independent StC DOFs); 2: StC_XY_DOF (Omni-Directional StC); 3: TLCD; 4: Prescribed force/moment time series; 5: Force determined by external DLL}
false StC_X_DOF - DOF on or off for StC X (flag) [Used only when StC_DOF_MODE=1]
true StC_Y_DOF - DOF on or off for StC Y (flag) [Used only when StC_DOF_MODE=1]
false StC_Z_DOF - DOF on or off for StC Z (flag) [Used only when StC_DOF_MODE=1]
---------------------- StC LOCATION ------------------------------------------- [relative to the reference origin of component attached to]
0 StC_P_X - At rest X position of StC (m)
0 StC_P_Y - At rest Y position of StC (m)
98 StC_P_Z - At rest Z position of StC (m)
---------------------- StC INITIAL CONDITIONS --------------------------------- [used only when StC_DOF_MODE=1 or 2]
0 StC_X_DSP - StC X initial displacement (m) [relative to at rest position]
0 StC_Y_DSP - StC Y initial displacement (m) [relative to at rest position]
0 StC_Z_DSP - StC Z initial displacement (m) [relative to at rest position; used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
"gravity" StC_Z_PreLd - StC Z pre-load (N) {"gravity" to offset for gravity load; "none" or 0 to turn off} [used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
---------------------- StC CONFIGURATION -------------------------------------- [used only when StC_DOF_MODE=1 or 2]
0 StC_X_PSP - Positive stop position (maximum X mass displacement) (m)
0 StC_X_NSP - Negative stop position (minimum X mass displacement) (m)
0 StC_Y_PSP - Positive stop position (maximum Y mass displacement) (m)
0 StC_Y_NSP - Negative stop position (minimum Y mass displacement) (m)
0 StC_Z_PSP - Positive stop position (maximum Z mass displacement) (m) [used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
0 StC_Z_NSP - Negative stop position (minimum Z mass displacement) (m) [used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
---------------------- StC MASS, STIFFNESS, & DAMPING ------------------------- [used only when StC_DOF_MODE=1 or 2]
0 StC_X_M - StC X mass (kg) [must equal StC_Y_M for StC_DOF_MODE = 2]
75 StC_Y_M - StC Y mass (kg) [must equal StC_X_M for StC_DOF_MODE = 2]
0 StC_Z_M - StC Z mass (kg) [used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
0 StC_XY_M - StC XY mass (kg) [used only when StC_DOF_MODE=2]
0 StC_X_K - StC X stiffness (N/m)
1534.3398 StC_Y_K - StC Y stiffness (N/m)
0 StC_Z_K - StC Z stiffness (N/m) [used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
0 StC_X_C - StC X damping (N/(m/s))
56.5307 StC_Y_C - StC Y damping (N/(m/s))
0 StC_Z_C - StC Z damping (N/(m/s)) [used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
0 StC_X_KS - Stop spring X stiffness (N/m)
0 StC_Y_KS - Stop spring Y stiffness (N/m)
0 StC_Z_KS - Stop spring Z stiffness (N/m) [used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
0 StC_X_CS - Stop spring X damping (N/(m/s))
0 StC_Y_CS - Stop spring Y damping (N/(m/s))
0 StC_Z_CS - Stop spring Z damping (N/(m/s)) [used only when StC_DOF_MODE=1 and StC_Z_DOF=TRUE]
Note that no major changes were made in the DISCON.IN file, compared to the one provided on the repository (https://github.com/IEAWindSystems/IEA-15-240-RWT/blob/master/OpenFAST/IEA-15-240-RWT-Monopile/IEA-15-240-RWT-Monopile_DISCON.IN)
Now, if I only change NumBStC to 0 (no structural control), OpenFAST runs normally and the response of the blade with BeamDyn is:
The discrepancy here is that I do get free decay oscillation response from the blades with ElastoDyn (observe first image), but BeamDyn gives me a flat number (for all 3 blades) or no free decay response as I see it (second image for blade 3). That is why I tried changing the initial in-plane deflection but now I understand, thanks to your explanation, that it is not an input used by BeamDyn. Does this mean the blades are not affected by gravity when BeamDyn is used, as opposed to ElastoDyn?
I greatly appreciate your input on this matter.
Best,
Fanny
