How to create a actuator and sensor fault in Open FAST
Dear Jason
Thank you for the reply. how can I set pitch rate limit from -8 to 8 deg/s and pitch angle range from 0 to 90 degree? I am using open fast. thanks in advance .
Dear @Suresh.Nakkala,
The pitch rates and final angles of the override pitch maneuvers are inputs set directly in ServoDyn.
In the operational controller, pitch angle and pitch-rate limits would be set within the user-specified controller (not directly within OpenFAST).
Dear Jason
thank you. I am getting confused to know about type of fault. I think I did simulation for sensor fault (constant magnitude after fault occurrence at 200 sec).is this sensor fault right? I am attaching the fault I created.
1
can I use my own separate second order pitch system to the NREL 5MW (open fast) instead of creating fault in the open fast input files? thanks in advance.
Different wind turbines can experience different faults. Having the pitch angle get stuck at a certain angle is possible, as is a sudden ramp of the pitch angle to run (0deg) or feather (90deg). The actual faults possible will depend on the turbine / controller. For a reference wind turbine, such as the NREL 5-MW baseline wind turbine or IEA Wind 15-MW reference wind turbine, you should make your own assumptions for your own purposes.
I’m not sure I understand your second question.
Dear Jason
with one blade stuck( actuator fault) at 4 degree i.e BlPitchF(1)==4 condition on blade-1 , the generator speed is effected a little as in the results of generator speed I sent above. I tried BlPitchF(1)==0 on blade-1. but the generator speed is still not much effected for that fault .but blade root bending moments on the blades are much effected for the two conditions. How can I make more fault effect on generator speed with one pitch stuck at 0 i.e BlPitchF(1)==0.is there any other way to create blade pitch angle stuck fault on one blade to make generator speed response more effected? thanks in advance.
                       N suresh
I would guess the influence of the “stuck” blade would depend on the wind speed. At high speeds, I could foresee a blade being “stuck” to still maintain rated power and speed because enough power could be extracted by the two blades functioning normally.
That said, if a blade gets “stuck” due a fault, I would expect the protection system of the wind turbine to identify that fault and shut down the wind turbine. So, simulating a wind turbine operating through the fault does not seem correct to me.
