How do specifie the translation direction of TMDs ?
Dear All
I recently read an article that mentioned that the translation direction of TMD is rotated by 45°about the vertical axis, forming an ‘‘X’’ . I am very interested in this. But after consulting the manual and the forum, no relevant problems were found. So ask everyone here.
Best
Laic.Wang
Dear Laic,
The current TMD model in FAST / OpenFAST allows for two independent TMDs in the fore-aft and side-side directions, or one omnidirectional TMD. You’d have to change the source code a bit if you want to rotate the two independent TMDs by 45 degrees about the vertical xis.
Thank you for your kind reminder. I will try to change the source code a bit.
Laic
