Faster v2
This is to inform you that I`ve developed a software to manipulate the input files to Openfast/Turbsim and to automatically run the analyses in parallel. The software also include features to display the results from the analyses in a user friendly manner.
The software is a standalone console application that runs under windows with no need for any third party libraries or other external services.
The software is called Faster and the binary along with a user manual can be cloned/downloaded from
github.com/Ry8ics/Faster
Check it out and let me know what you think.
Bjørn Melhus
Thanks for sharing! Looks like a useful utility for manipulating OpenFAST/TurbSim input files.
Just uploaded the user manual and the binary to the releases tag on Github.
It was previously located directly in the repo folder which is not a good idea.
If you’re opting to just downloading the binary (Faster.exe), instead of cloning that will require both Visual Studio and a Fortran compiler, you will probably get a warning message from your anti-virus software when downloading. However, no cause for worry, Faster is quite harmless.
Start to test out the software by running the “minimalistic example” as given in the user manual.
Enjoy.
I’ve recompiled Faster to ensure that it can run on any windows 64 bit machine i.e. linked with static library. Please let me know if you run into issues. Post your query here or under the discussion tag of the Github repo.
Bjorn Melhus
I’ve done some refreshments. The software Faster will need access to the file libiomp5.dll that is needed to run several analyses in parallel. I’ve included this file as well as the user manual in a zip-file ready for download under «Releases», ref. Release Faster v2.0 · Ry8ics/Faster · GitHub.
The software should now work out of the box.
Bjørn Melhus
