So, I have run into a weird problem. I run a batch of seismic simulations using the seismic version of FAST v7 with Aerodyn 13. And I notice that some simulations abort with an error of singular matrix encountered. And a few simulations show the start of the earthquakes at altered timings than what I set in the input files. Upon seeing the time series for blade displacements and tower top displacements I observe that these quantities show sudden unbounded responses.
Also, I used turbsim to generate the .bts wind fields. Kindly assist me to rectify the issues. I seem to be fairly unaware of whats wrong.
following are my turbsim and fast input files:
---------TurbSim v2.00.* Input File------------------------
Input File for Certification Test #3 (Kaimal Spectrum, formatted FF files).
True Echo - Echo input data to .ech (flag)
-699552916 RandSeed1 - First random seed (-2147483648 to 2147483647)
“RanLux” RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
False Clockwise - Clockwise rotation looking downwind? (used only for full-field binary files - not necessary for AeroDyn)
1500 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
1500 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds unless UsableTime is “ALL”)
89.56256 HubHt - Hub height [m] (should be > 0.5GridHeight)
150 GridHeight - Grid height [m]
150 GridWidth - Grid width [m] (should be >= 2(RotorRadius+ShaftLength))
“IECKAI” TurbModel - Turbulence model (“IECKAI”,“IECVKM”,“GP_LLJ”,“NWTCUP”,“SMOOTH”,“WF_UPW”,“WF_07D”,“WF_14D”,“TIDAL”,“API”,“USRINP”,“TIMESR”, or “NONE”)
“unused” UserFile - Name of the file that contains inputs for user-defined spectra or time series inputs (used only for “USRINP” and “TIMESR” models)
“1-ED3” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
“B” IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP model, not used for other models)
“2” ETMc - IEC Extreme Turbulence Model “c” parameter [m/s]
“PL” WindProfileType - Velocity profile type (“LOG”;“PL”=power law;“JET”;“H2L”=Log law for TIDAL model;“API”;“USR”;“TS”;“IEC”=PL on rotor disk, LOG elsewhere; or “default”)
“unused” ProfileFile - Name of the file that contains input profiles for WindProfileType=“USR” and/or TurbModel=“USRVKM” [-]
89.56256 RefHt - Height of the reference velocity (URef) [m]
24 URef - Mean (total) velocity at the reference height [m/s] (or “default” for JET velocity profile) [must be 1-hr mean for API model; otherwise is the mean over AnalysisTime seconds]
“default” ZJetMax - Jet height [m] (used only for JET velocity profile, valid 70-490 m)
“default” PLExp - Power law exponent [-] (or “default”)
“default” Z0 - Surface roughness length [m] (or “default”)
“default” Latitude - Site latitude [degrees] (or “default”)
0.05 RICH_NO - Gradient Richardson number [-]
“default” UStar - Friction or shear velocity [m/s] (or “default”)
“default” ZI - Mixing layer depth [m] (or “default”)
“default” PC_UW - Hub mean u’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“default” PC_UV - Hub mean u’v’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“default” PC_VW - Hub mean v’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“default” SCMod1 - u-component coherence model (“GENERAL”,“IEC”,“API”,“NONE”, or “default”)
“default” SCMod2 - v-component coherence model (“GENERAL”,“IEC”,“NONE”, or “default”)
“default” SCMod3 - w-component coherence model (“GENERAL”,“IEC”,“NONE”, or “default”)
“default” InCDec1 - u-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“default” InCDec2 - v-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“default” InCDec3 - w-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“default” CohExp - Coherence exponent for general model [-] (or “default”)
“.\EventData” CTEventPath - Name of the path where event data files are located
“RANDOM” CTEventFile - Type of event files (“LES”, “DNS”, or “RANDOM”)
1 DistScl - Disturbance scale [-] (ratio of event dataset height to rotor disk). (Ignored when Randomize = true.)
0.5 CTLy - Fractional location of tower centerline from right [-] (looking downwind) to left side of the dataset. (Ignored when Randomize = true.)
0.5 CTLz - Fractional location of hub height from the bottom of the dataset. [-] (Ignored when Randomize = true.)
30 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
! NOTE: Do not add or remove any lines in this file!
Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf); Compatible with FAST v6.0.
True Echo - Echo input data to “echo.out” (flag)
1 AnalMode - Analysis mode {1: Run a time-marching simulation, 2: create a periodic linearized model} (switch)
1500.00 TMax - Total run time (s)
0.005 DT - Integration time step (s)
0 YCMode - Yaw control mode {0: none, 1: user-defined from routine UserYawCont, 2: user-defined from Simulink} (switch)
1 PCMode - Pitch control mode {0: none, 1: user-defined from routine PitchCntrl, 2: user-defined from Simulink} (switch)
2 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 2: user-defined from routine UserVSCont, 3: user-defined from Simulink} (switch)
1 HSSBrMode - HSS brake model {1: simple, 2: user-defined from routine UserHSSBr} (switch)
9999.9 TiDynBrk - Time to initiate deployment of the dynamic generator brake [CURRENTLY IGNORED] (s)
9999.9 TTpBrDp(1) - Time to initiate deployment of tip brake 1 (s)
9999.9 TTpBrDp(2) - Time to initiate deployment of tip brake 2 (s)
9999.9 TTpBrDp(3) - Time to initiate deployment of tip brake 3 (s) [unused for 2 blades]
9999.9 TBDepISp(1) - Deployment-initiation speed for the tip brake on blade 1 (rpm)
9999.9 TBDepISp(2) - Deployment-initiation speed for the tip brake on blade 2 (rpm)
9999.9 TBDepISp(3) - Deployment-initiation speed for the tip brake on blade 3 (rpm) [unused for 2 blades]
9999.9 TYawManE - Time at which override yaw maneuver reaches final yaw angle (s)
0.0 NacYawF - Final yaw angle for yaw maneuvers (degrees)
9999.0 TPitManS(1) - Time to start override pitch maneuver for blade 1 and end standard pitch control (s)
9999.0 TPitManS(2) - Time to start override pitch maneuver for blade 2 and end standard pitch control (s)
9999.0 TPitManS(3) - Time to start override pitch maneuver for blade 3 and end standard pitch control (s) [unused for 2 blades]
9999.0 TPitManE(1) - Time at which override pitch maneuver for blade 1 reaches final pitch (s)
9999.0 TPitManE(2) - Time at which override pitch maneuver for blade 2 reaches final pitch (s)
9999.0 TPitManE(3) - Time at which override pitch maneuver for blade 3 reaches final pitch (s) [unused for 2 blades]
0.0 BlPitch(1) - Blade 1 initial pitch (degrees)
0.0 BlPitch(2) - Blade 2 initial pitch (degrees)
0.0 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
0.0 B1PitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 B1PitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 B1PitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
True YawDOF - Yaw DOF (flag)
12.1 RotSpeed - Initial or fixed rotor speed (rpm)
63.0 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.01910 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
18.4978 TwrRBHt - Tower rigid base height (meters)
-5.0 ShftTilt - Rotor shaft tilt angle (degrees)
240.00E3 NacMass - Nacelle mass (kg)
56.78E3 HubMass - Hub mass (kg)
0.0 TipMass(1) - Tip-brake mass, blade 1 (kg)
0.0 TipMass(2) - Tip-brake mass, blade 2 (kg)
0.0 TipMass(3) - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
2607.89E3 NacYIner - Nacelle inertia about yaw axis (kg m^2)
115.926E3 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
100.0 GBoxEff - Gearbox efficiency (%)
97.0 GBRatio - Gearbox ratio (-)
28.1162E3 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
DynBrkFi - File containing a mech-gen-torque vs HSS-speed curve for a dynamic brake [CURRENTLY IGNORED] (quoted string)
867.637E6 DTTorSpr - Drivetrain torsional spring (N-m/rad)
6.215E6 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
2 PtfmModel - Platform model {0: none, 1: onshore, 2: fixed bottom offshore, 3: floating offshore} (switch)
“NRELOffshrBsline5MW_Platform_Monopile_AF.dat” PtfmFile - Name of file containing platform properties (quoted string) [unused when PtfmModel=0]
99 TwrNodes - Number of tower nodes used for analysis (-)
“NRELOffshrBsline5MW_Tower_Monopile_AF.dat” TwrFile - Name of file containing tower properties (quoted string)
9028.32E6 YawSpr - Nacelle-yaw spring constant (N-m/rad)
19.16E6 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
0.0 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
0.0 TBDrConN - Tip-brake drag constant during normal operation, CdArea (m^2)
0.0 TBDrConD - Tip-brake drag constant during fully-deployed operation, CdArea (m^2)
0.0 TpBrDT - Time for tip-brake to reach full deployment once released (sec)
“NRELOffshrBsline5MW_Blade.dat” BldFile(1) - Name of file containing properties for blade 1 (quoted string)
“NRELOffshrBsline5MW_Blade.dat” BldFile(2) - Name of file containing properties for blade 2 (quoted string)
“NRELOffshrBsline5MW_Blade.dat” BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
“NRELOffshrBsline5MW_AeroDyn.ipt” ADFile - Name of file containing AeroDyn input parameters (quoted string)
NoiseFile - Name of file containing aerodynamic noise input parameters (quoted string) [used only when CompNoise=True]
“E:/Seismic/operating/NRELOffshrBsline5MW_ADAMSSpecific” ADAMSFile - Name of file containing ADAMS-specific input parameters (quoted string) [unused when ADAMSPrep=1]
“D:/Seismic/Examples/AF_Model/NRELOffshrBsline5MW_Linear.dat” LinFile - Name of file containing FAST linearization parameters (quoted string) [unused when AnalMode=1]
True SumPrint - Print summary data to “.fsm” (flag)
1 OutFileFmt - Format for tabular (time-marching) output file(s) (1: text file [.out], 2: binary file [.outb], 3: both) (switch)
True TabDelim - Generate a tab-delimited tabular output file. (flag)
“ES10.3E2” OutFmt - Format used for tabular output except time. Resulting field should be 10 characters. (quoted string) [not checked for validity!]
0.0 TStart - Time to begin tabular output (s)
1 DecFact - Decimation factor for tabular output {1: output every time step} (-)
1.0 SttsTime - Amount of time between screen status messages (sec)
9 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
10,20,30,40,50,60,70,80,90 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
4 NBlGages - Number of blade nodes that have strain gages for output [0 to 9] (-)
5,9,13,16 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
OutList - The next line(s) contains a list of output parameters. See OutList.txt for a listing of available output channels, (-)
“WindVxi , WindVyi , WindVzi” - Longitudinal, lateral, and vertical wind speeds
“WaveElev” - Wave elevation at the platform reference point
“TTDspFA , TTDspSS” - Tower fore-aft and side-to-side displacements
“GenPwr,RotSpeed”
“RotTorq, RotThrust”
“RootMyc1, TwrBsMyt”
“GenPwr” - Electrical generator power and torque
“BldPitch1”
“OoPDefl1 , IPDefl1, NcIMUTAxs, NcIMUTAys” - Blade 1 out-of-plane and in-plane deflections
“Azimuth” - Blade 1 azimuth angle
“YawPzn”
“GenTq,GenSpeed” - Low-speed shaft and high-speed shaft speeds
“Spn1MLxb1, Spn1MLyb1” - Blade 1 local edgewise and flapwise bending moments at span station 1 (R = 15.8500)
“Spn2MLxb1, Spn2MLyb1” - Blade 1 local edgewise and flapwise bending moments at span station 2 (R = 32.2500)
“Spn3MLxb1, Spn3MLyb1” - Blade 1 local edgewise and flapwise bending moments at span station 2 (R = 48.6500)
“Spn4MLxb1, Spn4MLyb1” - Blade 1 local edgewise and flapwise bending moments at span station 2 (R = 58.9000)
“RootFxc1 , RootFyc1 , RootFzc1” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 1
“RootMxc1 , RootMyc1 , RootMzc1” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 1
“LSSGagMya, LSSGagMza” - rotating moments low-speed shaft 0- and 90-bending moments at the main bearing
“LSSGagMys, LSSGagMzs” - lss non rotating bending moment
“LSShftFxa, LSShftFya, LSShftFza” - non rotating lss shear force
"TipClrnc1 ,TipClrnc2 ,TipClrnc3 "
“TipDxc1,TipDyc1”
“TipDxc2,TipDyc2”
“TipDxc3,TipDyc3”
“NcIMUTVxs, NcIMUTVys”
“YawBrTAxp, YawBrTAyp”
“YawBrFxp , YawBrFyp , YawBrFzp” - Fore-aft shear, side-to-side shear, and vertical forces at the top of the tower (not rotating with nacelle yaw)
“YawBrMxp , YawBrMyp , YawBrMzp” - Side-to-side bending, fore-aft bending, and yaw moments at the top of the tower (not rotating with nacelle yaw)
“TwHt1MLxt, TwHt1MLyt” - Local side-to-side and fore-aft bending moments at tower gage 1 j=10 near tower base
“TwHt2MLxt, TwHt2MLyt” - Local side-to-side and fore-aft bending moments at tower gage 2
“TwHt3MLxt, TwHt3MLyt” - Local side-to-side and fore-aft bending moments at tower gage 3
“TwHt4MLxt, TwHt4MLyt”
“TwHt5MLxt, TwHt5MLyt”
“TwHt6MLxt, TwHt6MLyt”
“TwHt7MLxt, TwHt7MLyt”
“TwHt8MLxt, TwHt8MLyt”
“TwHt9MLxt, TwHt9MLyt” - Local side-to-side and fore-aft bending moments at tower gage 9 j= 90 near tower top
“TwHt1FLxt, TwHt1FLyt”
“TwHt2FLxt, TwHt2FLyt”
“TwHt3FLxt, TwHt3FLyt”
“TwHt4FLxt, TwHt4FLyt”
“TwHt5FLxt, TwHt5FLyt”
“TwHt6FLxt, TwHt6FLyt”
“TwHt7FLxt, TwHt7FLyt”
“TwHt8FLxt, TwHt8FLyt”
“TwHt9FLxt, TwHt9FLyt”
