When running FAST.Farm, I used the IEA-15MW wind turbine model([url]https://github.com/IEAWindTask37/IEA-15-240-RWT/tree/openfast_dev[/url]), instead of 5-MW model. Because of the changing of the size of the two kinds of wind turbine model, I modify the size of low-resolution wind domain and high-resolution wind domains. But the running process will have some errors, so I want to konw if having some notes when modifying the parameters of low and high-resolution wind domains.
And I don’t know the significance of the parameters in the primary input .fstf file. Can you tell me where I could find the introduce about these parameters ? The parameters of Outlist as followings:
“RtAxsXT1 , RtAxsYT1 , RtAxsZT1”
“RtPosXT1 , RtPosYT1 , RtPosZT1”
“YawErrT1”
“TIAmbT1”
“CtT1N01 , CtT1N02 , CtT1N03 , CtT1N04 , CtT1N05 , CtT1N06 , CtT1N07 , CtT1N08 , CtT1N09 , CtT1N10 , CtT1N11 , CtT1N12 , CtT1N13 , CtT1N14 , CtT1N15 , CtT1N16 , CtT1N17 , CtT1N18 , CtT1N19 , CtT1N20”
“WkAxsXT1D1 , WkAxsXT1D2 , WkAxsXT1D3 , WkAxsXT1D4 , WkAxsXT1D5 , WkAxsXT1D6 , WkAxsXT1D7”
“WkAxsYT1D1 , WkAxsYT1D2 , WkAxsYT1D3 , WkAxsYT1D4 , WkAxsYT1D5 , WkAxsYT1D6 , WkAxsYT1D7”
“WkAxsZT1D1 , WkAxsZT1D2 , WkAxsZT1D3 , WkAxsZT1D4 , WkAxsZT1D5 , WkAxsZT1D6 , WkAxsZT1D7”
“WkPosXT1D1 , WkPosXT1D2 , WkPosXT1D3 , WkPosXT1D4 , WkPosXT1D5 , WkPosXT1D6 , WkPosXT1D7”
“WkPosYT1D1 , WkPosYT1D2 , WkPosYT1D3 , WkPosYT1D4 , WkPosYT1D5 , WkPosYT1D6 , WkPosYT1D7”
“WkPosZT1D1 , WkPosZT1D2 , WkPosZT1D3 , WkPosZT1D4 , WkPosZT1D5 , WkPosZT1D6 , WkPosZT1D7”
Jiaping.Cui
