Hi everyone,
I tried to create a turbsim file with user input time series. I used TubSim v2.00.07 with these files:
TurbSim Input:
---------TurbSim v2.00.* Input File------------------------
Example input file for TurbSim.
2316563 RandSeed1 - First random seed (-2147483648 to 2147483647)
RANLUX RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
True WrADTWR - Output tower time-series data? (Generates RootName.twr)
True WrACT - Output coherent turbulence time steps in AeroDyn form? (Generates RootName.cts)
1 ScaleIEC - Scale IEC turbulence models to exact target standard deviation? [0=no additional scaling; 1=use hub scale uniformly; 2=use individual scales]
0.01 TimeStep - Time step [seconds]
599.99 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
599.99 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds unless UsableTime is “ALL”)
108.0 HubHt - Hub height [m] (should be > 0.5GridHeight)
150.0 GridHeight - Grid height [m]
150.0 GridWidth - Grid width [m] (should be >= 2(RotorRadius+ShaftLength))
“TIMESR” TurbModel - Turbulence model (“IECKAI”,“IECVKM”,“GP_LLJ”,“NWTCUP”,“SMOOTH”,“WF_UPW”,“WF_07D”,“WF_14D”,“TIDAL”,“API”,“USRINP”,“TIMESR”, or “NONE”)
“userpath” UserFile - Name of the file that contains inputs for user-defined spectra or time series inputs (used only for “USRINP” and “TIMESR” models)
“1-Ed3” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
“B” IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP model, not used for other models)
default ETMc - IEC Extreme Turbulence Model “c” parameter [m/s]
default WindProfileType - Velocity profile type (“LOG”;“PL”=power law;“JET”;“H2L”=Log law for TIDAL model;“API”;“USR”;“TS”;“IEC”=PL on rotor disk, LOG elsewhere; or “default”)
“unused” ProfileFile - Name of the file that contains input profiles for WindProfileType=“USR” and/or TurbModel=“USRVKM” [-]
108.0 RefHt - Height of the reference velocity (URef) [m]
4.0 URef - Mean (total) velocity at the reference height [m/s] (or “default” for JET velocity profile) [must be 1-hr mean for API model; otherwise is the mean over AnalysisTime seconds]
default ZJetMax - Jet height [m] (used only for JET velocity profile, valid 70-490 m)
0.05 RICH_NO - Gradient Richardson number [-]
default PC_UW - Hub mean u’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
default PC_UV - Hub mean u’v’ Reynolds stress [m^2/s^2] (or “default” or “none”)
default PC_VW - Hub mean v’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
default SCMod1 - u-component coherence model (“GENERAL”, “IEC”, “API”, “NONE”, or “default”)
default SCMod2 - v-component coherence model (“GENERAL”, “IEC”, “NONE”, or “default”)
default SCMod3 - w-component coherence model (“GENERAL”, “IEC”, “NONE”, or “default”)
default InCDec1 - u-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default InCDec2 - v-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default InCDec3 - w-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default CohExp - Coherence exponent for general model [-] (or “default”)
“\PC-CWD070\alexander.krause\Studenten\Jakob Roth\05_Simulation\01_MKS\MKS\TurbSim\EventData” CTEventPath - Name of the path where event data files are located
“Random” CTEventFile - Type of event files (“LES”, “DNS”, or “RANDOM”)
1.0 DistScl - Disturbance scale [-] (ratio of event dataset height to rotor disk). (Ignored when Randomize = true.)
0.5 CTLy - Fractional location of tower centerline from right [-] (looking downwind) to left side of the dataset. (Ignored when Randomize = true.)
0.5 CTLz - Fractional location of hub height from the bottom of the dataset. [-] (Ignored when Randomize = true.)
30.0 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
! NOTE: Do not add or remove any lines in this file!
User Input:
--------------TurbSim v2.00.* User Time Series Input File-----------------------
Time series input generated by MATLAB script.
2 nComp - Number of velocity components in the file (1=u component only; 2=u & v components; 3=u,v,w) [if < 3 other components will be generated using values from input file]
1 nPoints - Number of time series points contained in this file (-)
1 RefPtID - Index of the reference point (1-nPoints)
Pointyi Pointzi ! listed in order of increasing height
(m) (m)
0.00000 108.00000
--------Time Series-------------------------------------------------------------
Elapsed Time Point01u_108m Point01v_108m
(s) (m/s) (m/s)
0.0000 4.7325 -0.0655
0.0100 4.7389 -0.0455
0.0200 4.7429 -0.0345
0.0300 4.7500 -0.0183
0.0400 4.7545 -0.0006
0.0500 4.7623 0.0205
0.0600 4.7787 0.0497
0.0700 4.7935 0.0807
0.0800 4.8084 0.1113
0.0900 4.8249 0.1406
0.1000 4.8374 0.1695
0.1100 4.8453 0.1938
0.1200 4.8548 0.2168
0.1300 4.8626 0.2416
0.1400 4.8705 0.2659
0.1500 4.8799 0.2912
0.1600 4.8874 0.3238
0.1700 4.8950 0.3562
0.1800 4.9042 0.3869
I get the following error message:
ERROR: CreateGrid:Delta frequency in the user-input time series must be the same as the delta frequency in the simulated series. Change AnalysisTime or number of rows entered in user-defined time series file.
The delta_time in the input and user time series files are matching so that should not be a problem. Where can I adjust the Delta frequency?
Thanks a lot!
Jakob
