I have a problem by running FASTv8 using Test18. This error appearsFAST (v8.15.00a-bjj, 12-Apr-2016)
Copyright (C) 2016 National Renewable Energy Laboratory
This program comes with ABSOLUTELY NO WARRANTY. See the “license.txt” file distr
ibuted with this
software for details.
Running FAST (v8.15.00a-bjj, 12-Apr-2016), compiled as a 32-bit application usi
ng single
precision
linked with NWTC Subroutine Library (v2.08.00, 5-Apr-2016)
Heading of the FAST input file:
FAST Certification Test #24: NREL 5.0 MW Baseline Wind Turbine with OC3 Hywin
d Configuration,
for use in offshore analysis
Running ElastoDyn (v1.03.02a-bjj, 8-Apr-2016).
Running AeroDyn (v15.02.03, 12-Apr-2016).
Running AirfoilInfo (v1.01.00a-bjj, 5-Apr-2016).
Running BEM (v1.01.00a, 12-Apr-2016).
Running InflowWind (v3.02.00a-bjj, 11-Apr-2016).
Opening InflowWind input file: .\5MW_Baseline/NRELOffshrBsline5MW_InflowWind.d
at
Reading a 20x20 grid (145 m wide, 17.5 m to 162.5 m above ground) with a char
acteristic wind
speed of 12 m/s. This full-field file was generated by TurbSim (v1.50, 25-Sep
-2009) on
01-Jun-2017 at 19:14:57.
Processed 72242 time steps of 20-Hz full-field data (3612.1 seconds).
Running ServoDyn (v1.05.00a-bjj, 11-Mar-2016).
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran f
or Windows,
14-Oct-2015).
Running HydroDyn (v2.05.00, 15-Mar-2016).
Reading in WAMIT output with root name “.\5MW_Baseline/HydroData/ssv”.
FAST_InitializeAll:MAP_Init:Cannot read the MAP input file.
Aborting FAST.
I:\SURAJ-PhD\FAST\FASTV8-Program\dcw1>FAST_win32 DeepCwind.fst
ibuted with this
ng single
precision
d Configuration,
at
acteristic wind
-2009) on
or Windows,
14-Oct-2015).
MAP++ environment properties (set externally)…
Gravity constant [m/s^2] : 9.81
Sea density [kg/m^3] : 1025.00
Water depth [m] : 200.00
Vessel reference position [m] : 0.00 , 0.00 , 0.00
Timestep: 0 of 3600 seconds.
FAST_Solution0:CalcOutputs_And_SolveForInputs:SolveOption2:SrvD_CalcOutput:Runni
ng with torque
and pitch control of the NREL offshore 5MW baseline wind turbine from DISCON.dll
as written by J.
Jonkman of NREL/NWTC for use in the IEA Annex XXIII OC3 studies. Includes modif
ications for the
Hywind spar.
CalcOutputs_And_SolveForInputs:SolveOption1:ED_HD_InputOutputSolve:LAPACK_SGETRF
: U( 11,
11)=0. Factor U is exactly singular.
FAST encountered an error during simulation initialization.
Aborting FAST.
