I am using NERL 5MW wind turbine(test18)and I found Drivetrain Properties in your article “the Definition of a 5-MW Reference Wind Turbine for Offshore System Development”,Some parameters are shown in the attached image.e.g.Generator Inertia about High-Speed Shaft is available(534.116kg.m^2),I want to confirm whether this value is the value Jg in the attached figure.
I also want to find the value of the rotor inertia about the low-speed Shaft,Is this an undisclosed parameter?
BTW,Is there anything to do with the values of Equivalent Drive-Shaft Torsional-Damping Constant and Kg(or Kr) in the seconde attached figure?
Thank you in advance!
![U{}LZLEG%LUZ@BD]GRT(ESL.png|520x530](upload://kSQVBkeUtQQwIoxJEU7J7MT4y7i.png)
