I’m new to OpenFAST and I’m trying to perform aeroelastic coupling analysis with BEMT and GEBT on NREL 5MW Baseline wind turbine with steady, rated operation condition, i.e. wind speed 11.4 m/s, rotating speed 12.1 rpm without considering the effect of wind shear, tower shadow, yawed inflow, etc. The result is to compare with Section 2.4 and 3.1 of the paper “Li Z, Wen B, Dong X, et al. Aerodynamic and aeroelastic characteristics of flexible wind turbine blades under periodic unsteady inflows[J]. Journal of Wind Engineering and Industrial Aerodynamics, 2020, 197: 104057.”
The input file for OpenFAST v3.5.0 is mainly based on the test case of “5MW_Land_BD_DLL_WTurb” in OpenFAST Github repository. I slightly modified the wind speed to make steady inflow. The simulation time is 30s with a time step of 0.0002s.
What I expected, as the paper reports, is that the aerodynamic loads can be significantly reduced by considering the aeroelastic coupling effect. As shown in the subplot (a) of Figure 1, when considering the aeroelastic coupling effect, the aerodynamic load F_N reduces with up to 2000 N/m at the blade span of around 54 m. For the deformation the blade tip flapwise deflection is reported to be around 4.5m.
Figure 1. Aerodynamic load distribution on the blade from the reference paper
However, what I obtained through AeroDyn and ElastoDyn+BeamDyn in OpenFAST is that the tip deflection is around 5.3~5.6m, much larger than the result of the paper. Also, the output Fx in AeroDyn at Node 16 (54.67m) of the blade span is around 6800-7400 N/m, which is also much larger compared with the result of flexible blade in Figure 1.
I compared the output of AeroDyn in both standalone mode (corresponding to rigid blade) and in OpenFAST (flexible blade), I found that the Vrel in both modes are almost the same, which may explain the deviation of the result in OpenFAST and the paper.
As the paper says, when calculating Vrel in aeroelastic analysis, the velocity of blade including the corresponding elastic vibrations should be considered, but maybe OpenFAST doesn’t consider it? Or maybe the difference between OpenFAST and other aeroelastic coupling methods is due to other reasons?
I’m sorry for such a long question, but I would appreciate it if anyone can help me solve this. It has puzzled me for a while.
Tongzhou Zhang
