Data Version 1.24
I have updated the met tower processing code to version 1.24.
What’s new in version 1.24?
  • Changed one variable name on the M4 tower from Sonic_temp_41 to Sonic_Temp_41 to match the other variables.
  • Added the mean precipitation sensor value to the text files (Precip_Mean_0m). This is a float, where dry = 3 and wet = 0. There is no way that I am aware of to convert this in to a rate (i.e. mm/hour, or similar), but the numbers may be useful for filtering to remove odd data from sonics.
  • Data processing has NOT been changed.
You should start to see this in data with modification dates from about April 24. Over the next week I expect all of the old data will be reprocessed using this version.
If you see any issues, please report them here. Thanks!
